Alden |
Newbie ![]() Group: Members Posts: 30 Joined: 7-November 06 From: Lower Providence Twp. (Eagleville), PA Member No.: 7,161 Region Association: MidAtlantic Region ![]() |
My Comp TA's are well past the "best by" date. I want to go larger in diameter to bring down the RPM's. If 205/50 fit (no rubbing) will 205/65 fit? The tire is just getting taller not wider, correct?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If 205/50 fit (no rubbing) will 205/65 fit? The tire is just getting taller not wider, correct? Yes. Ish. The numbers for tire sizes are all "nominal", but the actual measurements can vary from brand to brand and sometimes vary within a tire model! In theory the 205/65 should be no wider than 205/50. In practice, they may be wider or narrower. Hopefully if they are, it isn't enough to matter. --DD |
Lo-Fi Version | Time is now: 18th July 2025 - 01:10 AM |
