> CFR MPS rebuild, Copy of instructions
Ron914
post Apr 28 2025, 10:52 PM
I needed to rebuild my MPS but Chris Foley is out of the kits due to no longer having a supplier of the BE-CU diaphragms . I was lucky enough to have a member here offer to sell me his spare parts kit from Chris (Thanks Tom). His kit did not have the instructions with it so I am wondering if anyone has a copy of those instructions?
ChrisFoley
post May 2 2025, 05:57 AM
I am Tangerine Racing
Its a good idea to test the mityvac on a dead ended hose to make certain it doesn't contribute to leakdown rate. I installed a shutoff valve on my setup, between the vacuum pump and the tee.
When I test a MPS unit I pump it down to about 18", close the valve, and expect 5+ minutes with only 1-2" of loss. It's not uncommon for a unit to pass a test at 10-12" of vacuum, but fail during operation in the car. It usually means there is a cracked diaphragm.
Ron914   CFR MPS rebuild   Apr 28 2025, 10:52 PM
MDTerp   RE: CFR MPS rebuild   Apr 29 2025, 04:26 AM
Ron914   Thank you Michael. @[url=http://www.914world.c...   Apr 29 2025, 08:27 AM
rjames   The hex tool is used in conjunction with the screw...   Apr 29 2025, 08:50 AM
Ron914   The hex tool is used in conjunction with the scre...   Apr 29 2025, 09:31 AM
ChrisFoley   The reason I recommend using those smaller taps as...   Apr 29 2025, 08:54 AM
ChrisFoley   That's an old tool set pictured. Currently, I ...   Apr 29 2025, 08:57 AM
ChrisFoley   Hi Ron, I was just on the phone with Tom yesterday...   Apr 29 2025, 09:05 AM
Ron914   Hi Ron, I was just on the phone with Tom yesterda...   Apr 29 2025, 09:34 AM
emerygt350   Those look like good improvements on an already gr...   Apr 29 2025, 09:49 AM
rjames   Don't overthink it. If both sizes are in the...   Apr 29 2025, 10:10 AM
ChrisFoley   I've been including M4 screws & nuts for a...   Apr 29 2025, 10:37 AM
MDTerp   For me it was also very helpful to install a vacuu...   Apr 29 2025, 01:05 PM
emerygt350   For me it was also very helpful to install a vacu...   Apr 29 2025, 03:20 PM
Ron914   For me it was also very helpful to install a vac...   May 1 2025, 07:35 AM
emerygt350   [quote name='emerygt350' post='3203360' date='Apr...   May 1 2025, 09:34 AM
Ron914   [quote name='emerygt350' post='3203360' date='Ap...   May 1 2025, 11:37 AM
TargaToy   Well crap. I didn’t realize there was no longer...   Apr 29 2025, 07:09 PM
Ron914   Well crap. I didn’t realize there was no longe...   Apr 29 2025, 07:47 PM
emerygt350   I believe Chris is looking for a replacement.   Apr 29 2025, 07:29 PM
Ron914   After reading a bit of Paul Anders MPS Diagnosis I...   Apr 29 2025, 08:48 PM
JeffBowlsby   After reading a bit of Paul Anders MPS Diagnosis ...   Apr 29 2025, 10:08 PM
emerygt350   I agree. I think anders is really doing the deep...   Apr 30 2025, 04:33 AM
Ron914   I agree. I think anders is really doing the dee...   Apr 30 2025, 06:18 PM
worn   I needed to rebuild my MPS but Chris Foley is out...   Apr 30 2025, 05:30 PM
Ron914   I needed to rebuild my MPS but Chris Foley is ou...   Apr 30 2025, 05:41 PM
emerygt350   Don't worry, the mps is all self contained. T...   Apr 30 2025, 06:49 PM
Ron914   Don't worry, the mps is all self contained. ...   Apr 30 2025, 07:20 PM
emerygt350   Your favorite FLAPS. Cheap plastic t works fine. ...   May 1 2025, 01:46 PM
MDTerp   Agree, I use a cheap plastic T connection. Here...   May 1 2025, 07:47 PM
ChrisFoley   Its a good idea to test the mityvac on a dead ende...   May 2 2025, 05:57 AM
Ron914   Its a good idea to test the mityvac on a dead end...   May 2 2025, 07:46 AM
- Lo-Fi Version Time is now: 15th December 2025 - 12:38 AM
