| Ron914 |
Apr 28 2025, 10:52 PM
Member ![]() ![]() Group: Members Posts: 468 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
I needed to rebuild my MPS but Chris Foley is out of the kits due to no longer having a supplier of the BE-CU diaphragms . I was lucky enough to have a member here offer to sell me his spare parts kit from Chris (Thanks Tom). His kit did not have the instructions with it so I am wondering if anyone has a copy of those instructions?
| ChrisFoley |
May 2 2025, 05:57 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,016 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Its a good idea to test the mityvac on a dead ended hose to make certain it doesn't contribute to leakdown rate. I installed a shutoff valve on my setup, between the vacuum pump and the tee.
When I test a MPS unit I pump it down to about 18", close the valve, and expect 5+ minutes with only 1-2" of loss. It's not uncommon for a unit to pass a test at 10-12" of vacuum, but fail during operation in the car. It usually means there is a cracked diaphragm. |
| Ron914 |
May 2 2025, 07:46 AM
Its a good idea to test the mityvac on a dead ended hose to make certain it doesn't contribute to leakdown rate. I installed a shutoff valve on my setup, between the vacuum pump and the tee. When I test a MPS unit I pump it down to about 18", close the valve, and expect 5+ minutes with only 1-2" of loss. It's not uncommon for a unit to pass a test at 10-12" of vacuum, but fail during operation in the car. It usually means there is a cracked diaphragm. Thanks Chris, I agree my MPS still has a leaky diaphragm that needs. replacement . I am still going to replace the diaphragm in my MPS , I get my TB back today from rebuild and was just going to see if I could pass a smog test here in California with my current MPS so I can start driving my car in the mean time . I still have some time to complete the installation of the three gauges needed to tune my MPS afterwards . |
Ron914 CFR MPS rebuild Apr 28 2025, 10:52 PM
MDTerp RE: CFR MPS rebuild Apr 29 2025, 04:26 AM
Ron914
Thank you Michael. @[url=http://www.914world.c... Apr 29 2025, 08:27 AM
rjames The hex tool is used in conjunction with the screw... Apr 29 2025, 08:50 AM
Ron914
The hex tool is used in conjunction with the scre... Apr 29 2025, 09:31 AM
ChrisFoley The reason I recommend using those smaller taps as... Apr 29 2025, 08:54 AM
ChrisFoley That's an old tool set pictured. Currently, I ... Apr 29 2025, 08:57 AM
ChrisFoley Hi Ron,
I was just on the phone with Tom yesterday... Apr 29 2025, 09:05 AM
Ron914
Hi Ron,
I was just on the phone with Tom yesterda... Apr 29 2025, 09:34 AM
emerygt350 Those look like good improvements on an already gr... Apr 29 2025, 09:49 AM
rjames
Don't overthink it. If both sizes are in the... Apr 29 2025, 10:10 AM
ChrisFoley I've been including M4 screws & nuts for a... Apr 29 2025, 10:37 AM
MDTerp For me it was also very helpful to install a vacuu... Apr 29 2025, 01:05 PM
emerygt350
For me it was also very helpful to install a vacu... Apr 29 2025, 03:20 PM
Ron914
For me it was also very helpful to install a vac... May 1 2025, 07:35 AM
emerygt350
[quote name='emerygt350' post='3203360' date='Apr... May 1 2025, 09:34 AM
Ron914
[quote name='emerygt350' post='3203360' date='Ap... May 1 2025, 11:37 AM
TargaToy Well crap. I didn’t realize there was no longer... Apr 29 2025, 07:09 PM
Ron914
Well crap. I didn’t realize there was no longe... Apr 29 2025, 07:47 PM
emerygt350 I believe Chris is looking for a replacement. Apr 29 2025, 07:29 PM
Ron914 After reading a bit of Paul Anders MPS Diagnosis I... Apr 29 2025, 08:48 PM
JeffBowlsby
After reading a bit of Paul Anders MPS Diagnosis ... Apr 29 2025, 10:08 PM
emerygt350 I agree. I think anders is really doing the deep... Apr 30 2025, 04:33 AM
Ron914
I agree. I think anders is really doing the dee... Apr 30 2025, 06:18 PM
worn
I needed to rebuild my MPS but Chris Foley is out... Apr 30 2025, 05:30 PM
Ron914
I needed to rebuild my MPS but Chris Foley is ou... Apr 30 2025, 05:41 PM
emerygt350 Don't worry, the mps is all self contained. T... Apr 30 2025, 06:49 PM
Ron914
Don't worry, the mps is all self contained. ... Apr 30 2025, 07:20 PM
emerygt350 Your favorite FLAPS. Cheap plastic t works fine. ... May 1 2025, 01:46 PM
MDTerp Agree, I use a cheap plastic T connection. Here... May 1 2025, 07:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 12:39 AM |
