| BillC |
Apr 18 2025, 05:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 745 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
I have an idle adjustment question for all you D-Jet gurus:
I can adjust the idle air screw on the throttle body so the car idles at 1600 RPM, and it will happily idle at 1600 all day long. If I turn in the screw just a little bit, like 1/4 turn, the car will slowly drop idle speed down slower and slower until it stalls. I can blip the throttle to keep it running, but it just wants to slow down and stall. This is all when the car is fully warmed up. How do I get the car to idle steady around 1000-1200 RPM? 1600 is just too high. Car is a '73 2.0 with factory D-Jet. I installed new Standard Products FJ67 injectors, and the fuel pressure is 29 psi. There are no leaks in the intake side, and the idle adjustment screw is about 2 turns out (so there's plenty of adjustment available in both directions). The MPS hasn't been messed with, and the ECU looks like the correct unit. All new vacuum lines, fuel lines, pump & filter, and fresh gas. New @JeffBowlsby engine and alternator wiring harnesses. Known issues: it has the wrong CHT sensor (it's the one that's commonly available) and I think the TPS board has worn traces. I finally found the right CHT and ballast resistor, and I also have a 914Rubber replacement TPS board, and I will install both of them when I get a chance. However, I don't think either of those should keep it from idling at a reasonable RPM. |
| emerygt350 |
May 3 2025, 03:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,695 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Have you tried playing with your timing while you are at it? I would be interested to know if retarding the timing a hair would bring it down. Remember these cars had a vacuum retard at idle of almost 10 degrees.
Did you try plugging the hole for the idle screw inside the TB venturi with your thumb? Sometimes those leak as well. Screw will be full in but it will still draw air through there. |
| BillC |
May 3 2025, 04:32 PM
Have you tried playing with your timing while you are at it? I would be interested to know if retarding the timing a hair would bring it down. Remember these cars had a vacuum retard at idle of almost 10 degrees. Did you try plugging the hole for the idle screw inside the TB venturi with your thumb? Sometimes those leak as well. Screw will be full in but it will still draw air through there. I did check the timing at idle while I was playing with the MPS, but it was idling at about 25 degrees advanced. Which makes sense since the vacuum in the intake was so low. I realized later that I could have rigged up vacuum hoses and tees, to put 17" of vacuum on the distributor and the MPS simultaneously, but I'll wait for the "new" throttle body before I worry about that. |
BillC Idle adjustment question Apr 18 2025, 05:10 PM
Sea Rooster Following....I have the same issue. Apr 18 2025, 05:17 PM
JeffBowlsby Im no guru, but the air screw is doing what its su... Apr 18 2025, 05:44 PM
BillC
Im no guru, but the air screw is doing what its s... Apr 18 2025, 06:14 PM
Ron914
Im no guru, but the air screw is doing what its ... Apr 18 2025, 07:10 PM
Superhawk996
Known issues: it has the wrong CHT sensor (it... Apr 18 2025, 07:17 PM
emerygt350 That's what I was thinking too. Although it s... Apr 18 2025, 08:34 PM
Superhawk996
That's what I was thinking too. Although it ... Apr 18 2025, 09:02 PM
Superhawk996 I guess I am also assuming the vehicle has a 73’... Apr 18 2025, 09:43 PM
emerygt350 Yeah, we need verification it's all 037. The ... Apr 19 2025, 03:12 PM
BillC So, I installed the 017 CHT and 270 ohm ballast re... Apr 19 2025, 03:58 PM
Olympic 914 Part of your problem may be that the tuning on the... Apr 19 2025, 06:29 PM
emerygt350 Yes, and that is exactly what I would do.
And als... Apr 19 2025, 04:50 PM
Robarabian Test your MPS.. this sounds MPS related to me... a... Apr 19 2025, 05:33 PM
BillC And ... it appears to be solved! :Qarl: :ch... Apr 20 2025, 09:48 AM
JeffBowlsby Shazzam! Amazing what the right parts will do... Apr 20 2025, 09:59 AM
emerygt350 That is great. And inexpensive! Apr 20 2025, 10:51 AM
BillC Aarrrrrgggh!!!! It is not fixed. ... Apr 20 2025, 04:20 PM
Superhawk996
The previous owner had the engine rebuilt a year... Apr 20 2025, 09:31 PM
BillC Thinking about it, do I have the distributor set c... Apr 20 2025, 04:20 PM
emerygt350 Absolutely change that to the rear facing port. Apr 20 2025, 08:07 PM
BillC Update: I heard back from Ed Madak at 123Ignition,... Apr 21 2025, 06:25 AM
emerygt350 You want it on the advance setting. If you have i... Apr 20 2025, 08:18 PM
rjames Does either of your MPSs hold vacuum? Apr 21 2025, 12:26 AM
emerygt350 And do put a vacuum gauge or mighty vac on the ple... Apr 21 2025, 06:22 AM
brant I had the same idle down problem a few years back.... Apr 21 2025, 10:19 AM
BillC So, more frustration this afternoon, but a small s... Apr 21 2025, 04:45 PM
Superhawk996
I did hook up a vacuum gauge. When running at ... Apr 21 2025, 05:47 PM
BillC
[quote name='BillC' post='3202140' date='Apr 21 2... Apr 21 2025, 07:10 PM
Superhawk996
However, the throttle does stick just a little bi... Apr 21 2025, 05:48 PM
emerygt350 I agree with your assessment. You could measure t... Apr 21 2025, 08:16 PM
BillC
How did you adjust them last time? Crusty method... Apr 22 2025, 05:44 AM
emerygt350 I am a fan of the crusty method. No chance of a mi... Apr 22 2025, 06:19 AM
Superhawk996 Pull plugs - betting they are black given how litt... Apr 22 2025, 10:34 AM
BillC
Pull plugs - betting they are black given how lit... Apr 22 2025, 03:28 PM
emerygt350 You can just use your mighty vac as a vacuum gauge Apr 22 2025, 05:44 PM
BillC I finally heard back from the shop that built the ... Apr 25 2025, 11:53 AM
JamesM
Now I just need to figure out which way to go. ... Apr 26 2025, 12:11 AM
Superhawk996 Assuming you are correct about the cam - micro/meg... Apr 25 2025, 12:55 PM
emerygt350 I agree, we are all going to have to go that way e... Apr 25 2025, 12:59 PM
Superhawk996
I agree, we are all going to have to go that way ... Apr 25 2025, 02:03 PM
BillC <sigh> The mystery continues.... :headbang... Apr 26 2025, 05:02 PM
Superhawk996 FWIW - Djet (and general plenum vacuum) isn’t g... Apr 26 2025, 10:18 PM
BillC I spent some time playing with the car this aftern... Apr 27 2025, 04:53 PM
emerygt350 Did you check the timing when it was at 1600? If ... Apr 27 2025, 06:54 PM
BillC
Did you check the timing when it was at 1600? If... Apr 28 2025, 08:00 AM
Superhawk996
I did a quick check of the valve adjustment whi... Apr 28 2025, 09:04 AM
BillC
Don’t take this the wrong way but we recently h... Apr 28 2025, 11:03 AM
Superhawk996
Edit:
I wonder if I might have a valve seat com... Apr 28 2025, 11:29 AM
emerygt350 Ahh, forgot you had the 123. You are not using th... Apr 28 2025, 02:59 PM
BillC I did more testing this morning, and I'm comin... May 3 2025, 10:13 AM
Superhawk996 :agree: Good job testing and being data driven. May 3 2025, 10:55 AM
emerygt350
Have you tried playing with your timing while yo... May 3 2025, 09:20 PM
JamesM
[quote name='BillC' post='3203872' date='May 3 20... May 26 2025, 03:43 PM
BillC I received the rebuilt throttle body and installed... May 25 2025, 03:00 PM
emerygt350 Put the dizzy on 1 but don't bother hooking up... May 26 2025, 04:33 AM
rhodyguy Have you closely examined the stacked elbow? The s... May 26 2025, 01:19 PM
BillC
Have you closely examined the stacked elbow? The ... May 26 2025, 03:31 PM
emerygt350
Have you closely examined the stacked elbow? The... May 26 2025, 03:46 PM
BillC
[quote name='emerygt350' post='3207219' date='Ma... May 29 2025, 04:27 PM
emerygt350 What vacuum is the engine making while it is doing... May 29 2025, 06:18 PM
BillC
What vacuum is the engine making while it is doin... May 29 2025, 06:32 PM
emerygt350 I don't need to know what it's set at, we ... May 30 2025, 04:24 AM
Superhawk996 I’m sorry that you’re still struggling with th... May 30 2025, 10:10 AM
rjames So you can drive the car, but it idles high and th... May 30 2025, 10:33 AM
emerygt350 Last I knew the engine had little vacuum across th... May 30 2025, 01:43 PM
Superhawk996
Last I knew the engine had little vacuum across t... May 30 2025, 02:40 PM
emerygt350
Last I knew the engine had little vacuum across ... May 31 2025, 11:28 AM
Superhawk996
I suspect it's still a valve/timing combo. ... May 31 2025, 11:33 AM
rhodyguy In case I missed it, how long, in minutes, will yo... May 31 2025, 01:11 PM
BillC This thread has gotten too long and there's to... Jun 2 2025, 06:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th August 2026 - 06:24 PM |
