> 1976 2.0L D-jet, distributor vacuum
Ron914
post Mar 24 2025, 05:21 PM
@emerygt350
I was asked my a member helping me with my high idle /vacuum leak problem how I currently have it hooked up .This is the diagram I am using .
rjames
post May 7 2025, 09:03 AM
I'm made of metal
If the MPS won’t hold vacuum or is set way too lean, your idle will likely hunt no matter what else you do.
Fix the MPS first.
Ron914   1976 2.0L D-jet   Mar 24 2025, 05:21 PM
emerygt350   How high is the idle currently?   Mar 24 2025, 05:28 PM
Ron914   How high is the idle currently? still around 140...   Mar 24 2025, 06:19 PM
Ron914   I think I might have a bad decel valve but others ...   Mar 24 2025, 06:20 PM
IronHillRestorations   You might want to make sure the advance mechanism ...   Mar 24 2025, 08:12 PM
porschetub   [quote name='IronHillRestorations' date=...   May 8 2025, 06:46 PM
emerygt350   That was my first thought. But you don't have...   Mar 25 2025, 05:31 AM
Ron914   That was my first thought. But you don't hav...   Mar 25 2025, 07:59 AM
emerygt350   That was my first thought. But you don't ha...   Mar 25 2025, 08:48 AM
emerygt350   Also ... 1400 just happens to be where the aar put...   Mar 25 2025, 05:34 AM
Ron914   Good morning Emery , I purchased these last night ...   Mar 26 2025, 08:00 AM
emerygt350   Oh the trouble we go through ;). Someday I hope...   Mar 26 2025, 08:45 AM
Ron914   Great to hear you have family in Huntington Beach ...   Mar 26 2025, 10:02 AM
emerygt350   Very cool. Nothing bike related going on for anot...   Mar 26 2025, 10:32 AM
Ron914   Very cool. Nothing bike related going on for ano...   Mar 26 2025, 10:58 AM
emerygt350   If there is salt she hides in the garage. Otherwi...   Mar 26 2025, 12:18 PM
Ron914   Good morning Emery @emerygt350 , I finally had a ...   Apr 5 2025, 07:25 AM
Ron914   Good morning Emery [b]@[url=http://www.914world....   Apr 5 2025, 07:27 AM
Ron914   Good morning Emery [b]@[url=http://www.914world...   Apr 5 2025, 07:50 AM
emerygt350   Let me see if I understand what you posted. When ...   Apr 5 2025, 08:13 AM
Ron914   Let me see if I understand what you posted. When...   Apr 5 2025, 01:19 PM
emerygt350   Definitely check the vacuum before you go breaking...   Apr 5 2025, 02:34 PM
Ron914   Definitely check the vacuum before you go breakin...   Apr 5 2025, 03:43 PM
Ron914   Definitely check the vacuum before you go breaki...   Apr 5 2025, 03:46 PM
Ron914   [quote name='Ron914' post='3199804' date='Apr 5 2...   Apr 5 2025, 03:48 PM
fiacra   [quote name='Ron914' post='3199804' date='Apr 5 2...   Apr 5 2025, 04:14 PM
emerygt350   That interval is what I shoot for, and I drive my ...   Apr 5 2025, 05:13 PM
Ron914   Emery , If the flaps are working and nothing has ...   Apr 7 2025, 07:29 AM
Ron914   Before I left for AZ I took photos of a couple of ...   Apr 10 2025, 06:25 PM
Superhawk996   Part on the left is the oil pressure switch for th...   Apr 11 2025, 04:19 AM
emerygt350   I would hate to be changing the cht sender at the ...   Apr 11 2025, 07:07 AM
Superhawk996   Hopefully what you have installed is the right o...   Apr 11 2025, 08:11 AM
Ron914   Hello Emery, Finally had time to look at my car t...   Apr 22 2025, 08:42 PM
emerygt350   Definitely don't use the retard till you are g...   Apr 23 2025, 06:09 AM
emerygt350   The more I think about the more I suspect your diz...   Apr 23 2025, 06:15 AM
Superhawk996   :agree: Gauge measures oil temp. Vehicle shoul...   Apr 23 2025, 07:38 AM
Ron914   I was probably idling and driving 30-40 minutes. I...   Apr 23 2025, 07:58 AM
Superhawk996   “ I assumed the thermo would pull them if w...   Apr 23 2025, 08:57 AM
ClayPerrine   “ I assumed the thermo would pull them if ...   Apr 23 2025, 10:03 AM
Ron914   “ I assumed the thermo would pull them if...   Apr 24 2025, 12:04 PM
Ron914   @emerygt350 ,Superhawk996, I pulled my car out thi...   Apr 24 2025, 01:38 PM
Superhawk996   MPS should not be bleeding down noticeably Redo ...   Apr 24 2025, 01:44 PM
Ron914   MPS should not be bleeding down noticeably Redo...   Apr 24 2025, 04:49 PM
emerygt350   And your car should start with the vacuum hose off...   Apr 24 2025, 02:18 PM
Superhawk996   I am not sure if anyone has the diaphragms. Tr...   Apr 24 2025, 02:48 PM
Ron914   And your car should start with the vacuum hose of...   Apr 24 2025, 04:55 PM
emerygt350   Hmmm... I put a new to me fan on mine when I rebu...   Apr 24 2025, 07:02 PM
Superhawk996   And your mps should hold air much longer than th...   Apr 24 2025, 07:19 PM
Ron914   Hmmm... I put a new to me fan on mine when I reb...   Apr 24 2025, 07:57 PM
Ron914   If I can find parts I will need some coaching on r...   Apr 24 2025, 08:05 PM
Ron914   Nothing on Patrick's site I just found this bu...   Apr 24 2025, 08:11 PM
emerygt350   That's part of it. On a 76 if you have the ori...   Apr 24 2025, 08:21 PM
Superhawk996   Was revisiting a previous thread Found this: ...   Apr 24 2025, 08:23 PM
Ron914   Was revisiting a previous thread Found this: ...   Apr 24 2025, 08:28 PM
Superhawk996   I’m getting old - I don’t remember seeing that...   Apr 24 2025, 08:45 PM
Ron914   I’m getting old - I don’t remember seeing tha...   Apr 24 2025, 09:11 PM
Superhawk996   [quote name='Superhawk996' post='3202614' date='A...   Apr 25 2025, 07:26 AM
emerygt350   That's tough. The rebuild kit plus the tuning...   Apr 25 2025, 04:24 AM
Ron914   That's tough. The rebuild kit plus the tunin...   Apr 25 2025, 06:47 AM
Ron914   I found this AFR on a website ,What do you think ?...   Apr 25 2025, 06:56 AM
TJB/914   Hi Ron, I sent you a PM this morning. I have what ...   Apr 25 2025, 07:03 AM
Ron914   @Superhawk996 , [b]@[url=http://www.914world.com/b...   Apr 25 2025, 07:45 AM
Superhawk996   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 25 2025, 07:56 AM
JeffBowlsby   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 25 2025, 08:29 AM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php?...   Apr 25 2025, 08:32 AM
TJB/914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 25 2025, 09:00 AM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php?...   Apr 25 2025, 09:10 AM
JeffBowlsby   Sincere apologies Ron, did not realize your engine...   Apr 25 2025, 09:03 AM
Ron914   What else do you have in that box of junk(just kid...   Apr 25 2025, 09:13 AM
Ron914   @emerygt350 , [b]@[url=http://www.914world.com/bbs...   Apr 25 2025, 10:39 AM
emerygt350   I suggest an aem O2 sensor and gauge, I have tried...   Apr 25 2025, 11:15 AM
Ron914   I suggest an aem O2 sensor and gauge, I have trie...   Apr 25 2025, 12:21 PM
emerygt350   In this video my I am cruising down the highway at...   Apr 25 2025, 11:20 AM
Ron914   In this video my I am cruising down the highway a...   Apr 25 2025, 07:58 PM
Ron914   @emerygt350 , [b]@[url=http://www.914world.com/bbs...   Apr 25 2025, 04:25 PM
Ron914   @emerygt350 I found these online ,would they be w...   Apr 25 2025, 07:56 PM
Ron914   I can actually buy this set up on Amazon with free...   Apr 25 2025, 08:15 PM
Ron914   I forgot this one , and these choices look like my...   Apr 25 2025, 08:24 PM
emerygt350   Yes, those look good. Make sure the cables are lo...   Apr 25 2025, 08:27 PM
Ron914   Yes, those look good. Make sure the cables are l...   Apr 25 2025, 09:11 PM
emerygt350   If there is a 12 you may want that instead.   Apr 26 2025, 04:19 AM
Ron914   If there is a 12 you may want that instead. @em...   Apr 26 2025, 07:00 AM
emerygt350   I bought the 18 and it was way too much. I just l...   Apr 26 2025, 02:04 PM
Ron914   I bought the 18 and it was way too much. I just ...   Apr 26 2025, 04:48 PM
Ron914   @emerygt350 Update: Where I am as of today . I k...   May 6 2025, 05:13 PM
rjames   I have lost track of some of this thread, and I kn...   May 6 2025, 05:37 PM
Ron914   I have lost track of some of this thread, and I k...   May 6 2025, 06:06 PM
emerygt350   That looks like some good progress. I couldn...   May 6 2025, 06:11 PM
Ron914   That looks like some good progress. I couldn...   May 6 2025, 06:47 PM
emerygt350   The only thing you will be playing with are the id...   May 7 2025, 05:14 AM
rjames   If the MPS won’t hold vacuum or is set way too l...   May 7 2025, 09:03 AM
emerygt350   If the MPS won’t hold vacuum or is set way too ...   May 7 2025, 09:39 AM
rjames   If the MPS won’t hold vacuum or is set way too...   May 7 2025, 10:32 AM
Ron914   Still working on my D-Jet issues I ran my motor an...   May 7 2025, 02:14 PM
emerygt350   Very good idea. You have the chart for that temp ...   May 7 2025, 04:42 PM
Ron914   Very good idea. You have the chart for that temp...   May 7 2025, 05:00 PM
emerygt350   One is for the supplementary heater on my afr (doe...   May 7 2025, 07:36 PM
Ron914   One is for the supplementary heater on my afr (do...   May 7 2025, 09:50 PM
emerygt350   You may want the afr up top and the cht down low w...   May 7 2025, 07:37 PM
emerygt350   The instructions are online, not sure what model y...   May 8 2025, 04:19 AM
- Lo-Fi Version Time is now: 26th October 2026 - 10:11 AM
