| Ron914 |
Mar 24 2025, 05:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 562 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
@emerygt350
I was asked my a member helping me with my high idle /vacuum leak problem how I currently have it hooked up .This is the diagram I am using . |
| rjames |
May 7 2025, 09:03 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,482 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
If the MPS won’t hold vacuum or is set way too lean, your idle will likely hunt no matter what else you do.
Fix the MPS first. |
| emerygt350 |
May 7 2025, 09:39 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,794 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Ron914 1976 2.0L D-jet Mar 24 2025, 05:21 PM
emerygt350 How high is the idle currently? Mar 24 2025, 05:28 PM
Ron914
still around 140... Mar 24 2025, 06:19 PM
Ron914 I think I might have a bad decel valve but others ... Mar 24 2025, 06:20 PM
IronHillRestorations You might want to make sure the advance mechanism ... Mar 24 2025, 08:12 PM
porschetub [quote name='IronHillRestorations' date=... May 8 2025, 06:46 PM
emerygt350 That was my first thought. But you don't have... Mar 25 2025, 05:31 AM
Ron914
That was my first thought. But you don't hav... Mar 25 2025, 07:59 AM
emerygt350
That was my first thought. But you don't ha... Mar 25 2025, 08:48 AM
emerygt350 Also ... 1400 just happens to be where the aar put... Mar 25 2025, 05:34 AM
Ron914 Good morning Emery ,
I purchased these last night ... Mar 26 2025, 08:00 AM
emerygt350 Oh the trouble we go through ;).
Someday I hope... Mar 26 2025, 08:45 AM
Ron914 Great to hear you have family in Huntington Beach ... Mar 26 2025, 10:02 AM
emerygt350 Very cool. Nothing bike related going on for anot... Mar 26 2025, 10:32 AM
Ron914
Very cool. Nothing bike related going on for ano... Mar 26 2025, 10:58 AM
emerygt350 If there is salt she hides in the garage. Otherwi... Mar 26 2025, 12:18 PM
Ron914 Good morning Emery @emerygt350 ,
I finally had a ... Apr 5 2025, 07:25 AM
Ron914
Good morning Emery [b]@[url=http://www.914world.... Apr 5 2025, 07:27 AM
Ron914
Good morning Emery [b]@[url=http://www.914world... Apr 5 2025, 07:50 AM
emerygt350 Let me see if I understand what you posted. When ... Apr 5 2025, 08:13 AM
Ron914
Let me see if I understand what you posted. When... Apr 5 2025, 01:19 PM
emerygt350 Definitely check the vacuum before you go breaking... Apr 5 2025, 02:34 PM
Ron914
Definitely check the vacuum before you go breakin... Apr 5 2025, 03:43 PM
Ron914
Definitely check the vacuum before you go breaki... Apr 5 2025, 03:46 PM
Ron914
[quote name='Ron914' post='3199804' date='Apr 5 2... Apr 5 2025, 03:48 PM
fiacra
[quote name='Ron914' post='3199804' date='Apr 5 2... Apr 5 2025, 04:14 PM
emerygt350 That interval is what I shoot for, and I drive my ... Apr 5 2025, 05:13 PM
Ron914 Emery ,
If the flaps are working and nothing has ... Apr 7 2025, 07:29 AM
Ron914 Before I left for AZ I took photos of a couple of ... Apr 10 2025, 06:25 PM
Superhawk996 Part on the left is the oil pressure switch for th... Apr 11 2025, 04:19 AM
emerygt350 I would hate to be changing the cht sender at the ... Apr 11 2025, 07:07 AM
Superhawk996
Hopefully what you have installed is the right o... Apr 11 2025, 08:11 AM
Ron914 Hello Emery,
Finally had time to look at my car t... Apr 22 2025, 08:42 PM
emerygt350 Definitely don't use the retard till you are g... Apr 23 2025, 06:09 AM
emerygt350 The more I think about the more I suspect your diz... Apr 23 2025, 06:15 AM
Superhawk996 :agree:
Gauge measures oil temp. Vehicle shoul... Apr 23 2025, 07:38 AM
Ron914 I was probably idling and driving 30-40 minutes. I... Apr 23 2025, 07:58 AM
Superhawk996
“ I assumed the thermo would pull them if w... Apr 23 2025, 08:57 AM
ClayPerrine
“ I assumed the thermo would pull them if ... Apr 23 2025, 10:03 AM
Ron914
“ I assumed the thermo would pull them if... Apr 24 2025, 12:04 PM
Ron914 @emerygt350 ,Superhawk996,
I pulled my car out thi... Apr 24 2025, 01:38 PM
Superhawk996 MPS should not be bleeding down noticeably
Redo ... Apr 24 2025, 01:44 PM
Ron914
Redo... Apr 24 2025, 04:49 PM
emerygt350 And your car should start with the vacuum hose off... Apr 24 2025, 02:18 PM
Superhawk996 I am not sure if anyone has the diaphragms.
Tr... Apr 24 2025, 02:48 PM
Ron914
And your car should start with the vacuum hose of... Apr 24 2025, 04:55 PM
emerygt350 Hmmm... I put a new to me fan on mine when I rebu... Apr 24 2025, 07:02 PM
Superhawk996
And your mps should hold air much longer than th... Apr 24 2025, 07:19 PM
Ron914
Hmmm... I put a new to me fan on mine when I reb... Apr 24 2025, 07:57 PM
Ron914 If I can find parts I will need some coaching on r... Apr 24 2025, 08:05 PM
Ron914 Nothing on Patrick's site
I just found this bu... Apr 24 2025, 08:11 PM
emerygt350 That's part of it. On a 76 if you have the ori... Apr 24 2025, 08:21 PM
Superhawk996 Was revisiting a previous thread
Found this:
... Apr 24 2025, 08:23 PM
Ron914
Found this:
... Apr 24 2025, 08:28 PM
Superhawk996 I’m getting old - I don’t remember seeing that... Apr 24 2025, 08:45 PM
Ron914
I’m getting old - I don’t remember seeing tha... Apr 24 2025, 09:11 PM
Superhawk996
[quote name='Superhawk996' post='3202614' date='A... Apr 25 2025, 07:26 AM
emerygt350 That's tough. The rebuild kit plus the tuning... Apr 25 2025, 04:24 AM
Ron914
That's tough. The rebuild kit plus the tunin... Apr 25 2025, 06:47 AM
Ron914 I found this AFR on a website ,What do you think ?... Apr 25 2025, 06:56 AM
TJB/914 Hi Ron,
I sent you a PM this morning.
I have what ... Apr 25 2025, 07:03 AM
Ron914 @Superhawk996 , [b]@[url=http://www.914world.com/b... Apr 25 2025, 07:45 AM
Superhawk996
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 25 2025, 07:56 AM
JeffBowlsby
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 25 2025, 08:29 AM
Ron914
[b]@[url=http://www.914world.com/bbs2/index.php?... Apr 25 2025, 08:32 AM
TJB/914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 25 2025, 09:00 AM
Ron914
[b]@[url=http://www.914world.com/bbs2/index.php?... Apr 25 2025, 09:10 AM
JeffBowlsby Sincere apologies Ron, did not realize your engine... Apr 25 2025, 09:03 AM
Ron914 What else do you have in that box of junk(just kid... Apr 25 2025, 09:13 AM
Ron914 @emerygt350 , [b]@[url=http://www.914world.com/bbs... Apr 25 2025, 10:39 AM
emerygt350 I suggest an aem O2 sensor and gauge, I have tried... Apr 25 2025, 11:15 AM
Ron914
I suggest an aem O2 sensor and gauge, I have trie... Apr 25 2025, 12:21 PM
emerygt350 In this video my I am cruising down the highway at... Apr 25 2025, 11:20 AM
Ron914
In this video my I am cruising down the highway a... Apr 25 2025, 07:58 PM
Ron914 @emerygt350 , [b]@[url=http://www.914world.com/bbs... Apr 25 2025, 04:25 PM
Ron914 @emerygt350
I found these online ,would they be w... Apr 25 2025, 07:56 PM
Ron914 I can actually buy this set up on Amazon with free... Apr 25 2025, 08:15 PM
Ron914 I forgot this one , and these choices look like my... Apr 25 2025, 08:24 PM
emerygt350 Yes, those look good. Make sure the cables are lo... Apr 25 2025, 08:27 PM
Ron914
Yes, those look good. Make sure the cables are l... Apr 25 2025, 09:11 PM
emerygt350 If there is a 12 you may want that instead. Apr 26 2025, 04:19 AM
Ron914
@em... Apr 26 2025, 07:00 AM
emerygt350 I bought the 18 and it was way too much. I just l... Apr 26 2025, 02:04 PM
Ron914
I bought the 18 and it was way too much. I just ... Apr 26 2025, 04:48 PM
Ron914 @emerygt350
Update: Where I am as of today . I k... May 6 2025, 05:13 PM
rjames I have lost track of some of this thread, and I kn... May 6 2025, 05:37 PM
Ron914
I have lost track of some of this thread, and I k... May 6 2025, 06:06 PM
emerygt350 That looks like some good progress. I couldn... May 6 2025, 06:11 PM
Ron914
That looks like some good progress. I couldn... May 6 2025, 06:47 PM
emerygt350 The only thing you will be playing with are the id... May 7 2025, 05:14 AM
rjames
If the MPS won’t hold vacuum or is set way too... May 7 2025, 10:32 AM
Ron914 Still working on my D-Jet issues I ran my motor an... May 7 2025, 02:14 PM
emerygt350 Very good idea. You have the chart for that temp ... May 7 2025, 04:42 PM
Ron914
Very good idea. You have the chart for that temp... May 7 2025, 05:00 PM
emerygt350 One is for the supplementary heater on my afr (doe... May 7 2025, 07:36 PM
Ron914
One is for the supplementary heater on my afr (do... May 7 2025, 09:50 PM
emerygt350 You may want the afr up top and the cht down low w... May 7 2025, 07:37 PM
emerygt350 The instructions are online, not sure what model y... May 8 2025, 04:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 26th October 2026 - 10:10 AM |
