| roundtwo |
May 5 2025, 11:16 PM
Member ![]() ![]() Group: Members Posts: 345 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California
Hello, needing a compact spare for my 914 six with flares. Currently, I’m running 15 inch wheels but I think in a pinch this could work. I think my rears are 225/ 60 17. Front 195 65 15 Pirelli cn36.
See pictures for rim and Tire six. To get me out of the boonies and back to civilization do you think this wheel would work? Very reasonably priced under 100 bucks and basically new. |
| Cairo94507 |
May 7 2025, 05:25 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,590 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
@roundtwo - Let me measure mine and take a couple photos this morning. But, I believe it should easily fit height wise. My concern is making sure the cooler shroud does not extend back so far towards the gas tank that the tire sits on the shroud. (IMG:style_emoticons/default/beerchug.gif)
| roundtwo |
May 7 2025, 09:53 AM
@roundtwo - Let me measure mine and take a couple photos this morning. But, I believe it should easily fit height wise. My concern is making sure the cooler shroud does not extend back so far towards the gas tank that the tire sits on the shroud. (IMG:style_emoticons/default/beerchug.gif) Agreed, that the money spot. The shroud taper is pretty thin as it approaches the tank area. Thanks for the tech support! oh...did you buy your wheel mount premade and then weld it the the tank wall bulkhead? |
roundtwo Collapsable spare tire question- will it fit? 914-6 with flares May 5 2025, 11:16 PM
roundtwo
Hello, needing a compact spare for my 914 six wit... May 5 2025, 11:28 PM
burton73 Yes it will work,
5.5 wide wheel, take a pump wi... May 6 2025, 01:33 PM
Cairo94507 I agree. I have a collapsable spare in my trunk a... May 6 2025, 02:03 PM
sb914 :agree: beautiful car ! May 6 2025, 02:34 PM
RiqueMar Remember, you can install laying flat in the front... May 6 2025, 02:41 PM
roundtwo @burton73
[b]@[url=http://www.914world.com/bbs2/... May 6 2025, 10:41 PM
ClayPerrine I am going to say this again.
The collapsible s... May 7 2025, 05:44 AM
roundtwo
The collapsible ... May 7 2025, 09:57 AM
roundtwo something like this?
https://www.tomsforeign.com/... May 7 2025, 10:01 AM
ClayPerrine
https://www.tomsforeign.com... May 7 2025, 02:46 PM
roundtwo only finding 17" rims
https://www.ebay.com/i... May 7 2025, 10:03 AM
burton73 @roundtwo
My factory 6 with front oil cooling an... May 7 2025, 11:57 AM
Steve I have the boxster spare laying flat in the front ... May 7 2025, 04:01 PM
porschetub
I have the boxster spare laying flat in the front... May 8 2025, 01:12 PM
Cairo94507 @roundtwo - Here are a few of the way my spare fi... May 8 2025, 01:31 PM
East coaster I’ll start by saying I had a space save spare in... May 8 2025, 03:58 PM
I’ll start by saying I had a space save spare i... May 8 2025, 04:14 PM
Cairo94507 So long as the trunk is empty, lay it in the rear ... May 8 2025, 05:22 PM
VegasRacer 205 will fit in the rear trunk. 225 will not.
(Th... May 8 2025, 05:41 PM
VaccaRabite Clay already said it, but I'll say it again an... May 8 2025, 05:46 PM
ClayPerrine Take your pick:
Boxster Spare Tire on Ebay
You ... May 8 2025, 11:00 PM
Justinp71 I need to replace my spare. The collapsible spare ... May 9 2025, 09:33 AM
roundtwo
I need to replace my spare. The collapsible spare... May 16 2025, 08:31 AM
roundtwo @cairo94507
[b]@[url=http://www.914world.com/bbs... May 16 2025, 08:29 AM
ClayPerrine Referring to "where do you put a wide, flat t... May 16 2025, 09:00 AM
roundtwo
Referring to "where do you put a wide, flat ... May 17 2025, 12:30 AM
ClayPerrine
Referring to "where do you put a wide, flat... May 18 2025, 05:43 AM
brant I have a space saver fit in the front
But it’s ... May 18 2025, 09:24 AM
Graydingo I've inflated 3 of these old Porsche space sav... May 18 2025, 09:40 AM
mlindner I also run 7 x 15 fronts with spacer and 8 x 15 re... May 18 2025, 11:32 AM
ClayPerrine
I also run 7 x 15 fronts with spacer and 8 x 15 r... May 18 2025, 01:55 PM
mlindner
I also run 7 x 15 fronts with spacer and 8 x 15 ... May 18 2025, 04:27 PM
sixnotfour Show Us how those headlights work .... interested. May 18 2025, 02:27 PM
mlindner
Show Us how those headlights work .... interested... May 18 2025, 04:42 PM
roundtwo Ideally, I’d like a spare that can hold 7 gallon... May 18 2025, 06:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 03:38 PM |
