> 1976 2.0L D-jet, distributor vacuum
Ron914
post Mar 24 2025, 05:21 PM
@emerygt350
I was asked my a member helping me with my high idle /vacuum leak problem how I currently have it hooked up .This is the diagram I am using .
emerygt350
post May 7 2025, 07:37 PM
You may want the afr up top and the cht down low while you are tuning.
Ron914   1976 2.0L D-jet   Mar 24 2025, 05:21 PM
emerygt350   How high is the idle currently?   Mar 24 2025, 05:28 PM
Ron914   How high is the idle currently? still around 140...   Mar 24 2025, 06:19 PM
Ron914   I think I might have a bad decel valve but others ...   Mar 24 2025, 06:20 PM
IronHillRestorations   You might want to make sure the advance mechanism ...   Mar 24 2025, 08:12 PM
porschetub   [quote name='IronHillRestorations' date=...   May 8 2025, 06:46 PM
emerygt350   That was my first thought. But you don't have...   Mar 25 2025, 05:31 AM
Ron914   That was my first thought. But you don't hav...   Mar 25 2025, 07:59 AM
emerygt350   That was my first thought. But you don't ha...   Mar 25 2025, 08:48 AM
emerygt350   Also ... 1400 just happens to be where the aar put...   Mar 25 2025, 05:34 AM
Ron914   Good morning Emery , I purchased these last night ...   Mar 26 2025, 08:00 AM
emerygt350   Oh the trouble we go through ;). Someday I hope...   Mar 26 2025, 08:45 AM
Ron914   Great to hear you have family in Huntington Beach ...   Mar 26 2025, 10:02 AM
emerygt350   Very cool. Nothing bike related going on for anot...   Mar 26 2025, 10:32 AM
Ron914   Very cool. Nothing bike related going on for ano...   Mar 26 2025, 10:58 AM
emerygt350   If there is salt she hides in the garage. Otherwi...   Mar 26 2025, 12:18 PM
Ron914   Good morning Emery @emerygt350 , I finally had a ...   Apr 5 2025, 07:25 AM
Ron914   Good morning Emery [b]@[url=http://www.914world....   Apr 5 2025, 07:27 AM
Ron914   Good morning Emery [b]@[url=http://www.914world...   Apr 5 2025, 07:50 AM
emerygt350   Let me see if I understand what you posted. When ...   Apr 5 2025, 08:13 AM
Ron914   Let me see if I understand what you posted. When...   Apr 5 2025, 01:19 PM
emerygt350   Definitely check the vacuum before you go breaking...   Apr 5 2025, 02:34 PM
Ron914   Definitely check the vacuum before you go breakin...   Apr 5 2025, 03:43 PM
Ron914   Definitely check the vacuum before you go breaki...   Apr 5 2025, 03:46 PM
Ron914   [quote name='Ron914' post='3199804' date='Apr 5 2...   Apr 5 2025, 03:48 PM
fiacra   [quote name='Ron914' post='3199804' date='Apr 5 2...   Apr 5 2025, 04:14 PM
emerygt350   That interval is what I shoot for, and I drive my ...   Apr 5 2025, 05:13 PM
Ron914   Emery , If the flaps are working and nothing has ...   Apr 7 2025, 07:29 AM
Ron914   Before I left for AZ I took photos of a couple of ...   Apr 10 2025, 06:25 PM
Superhawk996   Part on the left is the oil pressure switch for th...   Apr 11 2025, 04:19 AM
emerygt350   I would hate to be changing the cht sender at the ...   Apr 11 2025, 07:07 AM
Superhawk996   Hopefully what you have installed is the right o...   Apr 11 2025, 08:11 AM
Ron914   Hello Emery, Finally had time to look at my car t...   Apr 22 2025, 08:42 PM
emerygt350   Definitely don't use the retard till you are g...   Apr 23 2025, 06:09 AM
emerygt350   The more I think about the more I suspect your diz...   Apr 23 2025, 06:15 AM
Superhawk996   :agree: Gauge measures oil temp. Vehicle shoul...   Apr 23 2025, 07:38 AM
Ron914   I was probably idling and driving 30-40 minutes. I...   Apr 23 2025, 07:58 AM
Superhawk996   “ I assumed the thermo would pull them if w...   Apr 23 2025, 08:57 AM
ClayPerrine   “ I assumed the thermo would pull them if ...   Apr 23 2025, 10:03 AM
Ron914   “ I assumed the thermo would pull them if...   Apr 24 2025, 12:04 PM
Ron914   @emerygt350 ,Superhawk996, I pulled my car out thi...   Apr 24 2025, 01:38 PM
Superhawk996   MPS should not be bleeding down noticeably Redo ...   Apr 24 2025, 01:44 PM
Ron914   MPS should not be bleeding down noticeably Redo...   Apr 24 2025, 04:49 PM
emerygt350   And your car should start with the vacuum hose off...   Apr 24 2025, 02:18 PM
Superhawk996   I am not sure if anyone has the diaphragms. Tr...   Apr 24 2025, 02:48 PM
Ron914   And your car should start with the vacuum hose of...   Apr 24 2025, 04:55 PM
emerygt350   Hmmm... I put a new to me fan on mine when I rebu...   Apr 24 2025, 07:02 PM
Superhawk996   And your mps should hold air much longer than th...   Apr 24 2025, 07:19 PM
Ron914   Hmmm... I put a new to me fan on mine when I reb...   Apr 24 2025, 07:57 PM
Ron914   If I can find parts I will need some coaching on r...   Apr 24 2025, 08:05 PM
Ron914   Nothing on Patrick's site I just found this bu...   Apr 24 2025, 08:11 PM
emerygt350   That's part of it. On a 76 if you have the ori...   Apr 24 2025, 08:21 PM
Superhawk996   Was revisiting a previous thread Found this: ...   Apr 24 2025, 08:23 PM
Ron914   Was revisiting a previous thread Found this: ...   Apr 24 2025, 08:28 PM
Superhawk996   I’m getting old - I don’t remember seeing that...   Apr 24 2025, 08:45 PM
Ron914   I’m getting old - I don’t remember seeing tha...   Apr 24 2025, 09:11 PM
Superhawk996   [quote name='Superhawk996' post='3202614' date='A...   Apr 25 2025, 07:26 AM
emerygt350   That's tough. The rebuild kit plus the tuning...   Apr 25 2025, 04:24 AM
Ron914   That's tough. The rebuild kit plus the tunin...   Apr 25 2025, 06:47 AM
Ron914   I found this AFR on a website ,What do you think ?...   Apr 25 2025, 06:56 AM
TJB/914   Hi Ron, I sent you a PM this morning. I have what ...   Apr 25 2025, 07:03 AM
Ron914   @Superhawk996 , [b]@[url=http://www.914world.com/b...   Apr 25 2025, 07:45 AM
Superhawk996   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 25 2025, 07:56 AM
JeffBowlsby   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 25 2025, 08:29 AM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php?...   Apr 25 2025, 08:32 AM
TJB/914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Apr 25 2025, 09:00 AM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php?...   Apr 25 2025, 09:10 AM
JeffBowlsby   Sincere apologies Ron, did not realize your engine...   Apr 25 2025, 09:03 AM
Ron914   What else do you have in that box of junk(just kid...   Apr 25 2025, 09:13 AM
Ron914   @emerygt350 , [b]@[url=http://www.914world.com/bbs...   Apr 25 2025, 10:39 AM
emerygt350   I suggest an aem O2 sensor and gauge, I have tried...   Apr 25 2025, 11:15 AM
Ron914   I suggest an aem O2 sensor and gauge, I have trie...   Apr 25 2025, 12:21 PM
emerygt350   In this video my I am cruising down the highway at...   Apr 25 2025, 11:20 AM
Ron914   In this video my I am cruising down the highway a...   Apr 25 2025, 07:58 PM
Ron914   @emerygt350 , [b]@[url=http://www.914world.com/bbs...   Apr 25 2025, 04:25 PM
Ron914   @emerygt350 I found these online ,would they be w...   Apr 25 2025, 07:56 PM
Ron914   I can actually buy this set up on Amazon with free...   Apr 25 2025, 08:15 PM
Ron914   I forgot this one , and these choices look like my...   Apr 25 2025, 08:24 PM
emerygt350   Yes, those look good. Make sure the cables are lo...   Apr 25 2025, 08:27 PM
Ron914   Yes, those look good. Make sure the cables are l...   Apr 25 2025, 09:11 PM
emerygt350   If there is a 12 you may want that instead.   Apr 26 2025, 04:19 AM
Ron914   If there is a 12 you may want that instead. @em...   Apr 26 2025, 07:00 AM
emerygt350   I bought the 18 and it was way too much. I just l...   Apr 26 2025, 02:04 PM
Ron914   I bought the 18 and it was way too much. I just ...   Apr 26 2025, 04:48 PM
Ron914   @emerygt350 Update: Where I am as of today . I k...   May 6 2025, 05:13 PM
rjames   I have lost track of some of this thread, and I kn...   May 6 2025, 05:37 PM
Ron914   I have lost track of some of this thread, and I k...   May 6 2025, 06:06 PM
emerygt350   That looks like some good progress. I couldn...   May 6 2025, 06:11 PM
Ron914   That looks like some good progress. I couldn...   May 6 2025, 06:47 PM
emerygt350   The only thing you will be playing with are the id...   May 7 2025, 05:14 AM
rjames   If the MPS won’t hold vacuum or is set way too l...   May 7 2025, 09:03 AM
emerygt350   If the MPS won’t hold vacuum or is set way too ...   May 7 2025, 09:39 AM
rjames   If the MPS won’t hold vacuum or is set way too...   May 7 2025, 10:32 AM
Ron914   Still working on my D-Jet issues I ran my motor an...   May 7 2025, 02:14 PM
emerygt350   Very good idea. You have the chart for that temp ...   May 7 2025, 04:42 PM
Ron914   Very good idea. You have the chart for that temp...   May 7 2025, 05:00 PM
emerygt350   One is for the supplementary heater on my afr (doe...   May 7 2025, 07:36 PM
Ron914   One is for the supplementary heater on my afr (do...   May 7 2025, 09:50 PM
emerygt350   You may want the afr up top and the cht down low w...   May 7 2025, 07:37 PM
emerygt350   The instructions are online, not sure what model y...   May 8 2025, 04:19 AM
- Lo-Fi Version Time is now: 26th October 2026 - 10:07 AM
