> Lifters, solid or not solid?
Kemo
post May 8 2025, 12:52 PM
All,
i have the top end off my 73 1.7 and im going to the 1.9 slip fit from Auto Atlanta and i was wondering about the different lifter options. the ones i have look really good without any visual damage. But im a little worried about how "springy" they are. i took a push rod and just pressed down a few of the lifters and was wondering if this is something i should address while things are apart.
Should i buy new stock lifters? What is a "solid" lifter? (sounds dangerous)
not sure what a hydraulic lifter is...any info is very helpful.
this is my first go round with a 4cylinder 914 motor.
thanks!!
Steve
914sgofast2
post May 8 2025, 05:52 PM
Test them by putting a lifter in a plastic cup with enough oil in it to cover the top of the lifter. Push the top of the lifter down a few times with the pushrod. That should pre-load the hydraulic section of the lifter with oil and the resistance should become stronger after you have pushed down on the pushrod a half dozen times. If the resistance doesn't increase, then the lifter is worn out and needs replacement.
Test each lifter in the same manner to see if they build up resistance. If they all do, you can re-use them with that cam. However, as others have stated, you will be leaving a lot of the performance to be derived from the larger displacement pistons and cylinders on the table.
- Lo-Fi Version Time is now: 9th May 2025 - 07:08 PM
