| torakki |
May 9 2025, 08:01 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
A while back, I asked about how hot a 914 should run on a VDO gage with no numbers. Responses said, I need to look at the sender to see if it matches the gage. I had a chance to get the sender out so here it is.
After a high reving drive on a warm day, the temp went close to the red zone. Maybe a needle or twos width to the red. Do I have a matching gage with sender? Thanks! |
| torakki |
May 10 2025, 11:52 AM
I just checked my gauge and it matches the sender according to the diagram. So, my car, if your drive it briskly, is running at around 280 C. Maybe, a longer drive, it would keep going into the red. I don't know.
Why is my engine running so warm? It's very clean, no crude blocking anything, new carbs, fresh oil. All tins in place. Thanks for the responses. |
| Superhawk996 |
May 10 2025, 12:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
torakki VDO Oil gage and temp sender question May 9 2025, 08:01 PM
Superhawk996 Yes - correct 200C sender.
May 9 2025, 08:09 PM
914Sixer The ONLY factory sender for all years was 0-200. ... May 10 2025, 06:09 AM
Superhawk996
Why is my engine running so warm? It's very... May 10 2025, 12:16 PM
porschetub
So, my car, if your drive it briskly, is running... May 10 2025, 05:43 PM
jim_hoyland What does your temp gauge read in stop and go traf... May 10 2025, 12:31 PM
930cabman Can always check with an infrared point/shoot May 10 2025, 04:36 PM
Geezer914 I would consider installing a remote oil cooler... May 11 2025, 04:18 AM
torakki Looks like there are quite a few things that lead ... May 11 2025, 07:03 PM
Superhawk996
After the quick drive, I did a slow drive home (... May 12 2025, 08:44 AM
Superhawk996 10w40 certainly isn’t too high of a viscosity. ... May 11 2025, 07:15 PM
Montreal914 The CHT comment related to an "under the spar... May 11 2025, 08:34 PM
Superhawk996 :agree: good references
The other thing about t... May 12 2025, 08:35 AM
porschetub
The other thing about ... May 12 2025, 05:27 PM
torakki Today's update: I'll try and add more deta... May 13 2025, 06:38 PM
930cabman
Today's update: I'll try and add more det... May 14 2025, 04:57 AM
emerygt350 Have you checked your voltage at the battery? Has... May 13 2025, 07:45 PM
Superhawk996 :agree: More or less. Don’t get too freaked - E... May 13 2025, 09:56 PM
torakki I know I keep forgetting to say the engine size. I... May 15 2025, 01:11 AM
Superhawk996 Yeah, that’s certainly hot for a 2.0l under the ... May 15 2025, 06:13 AM
torakki I finally got out to check for blockages in the fa... May 17 2025, 12:02 PM
930cabman
I finally got out to check for blockages in the f... May 17 2025, 02:52 PM
torakki Last Update, finally: I ordered a laser temp gauge... May 24 2025, 02:05 PM
porschetub
Last Update, finally: I ordered a laser temp gaug... May 24 2025, 06:21 PM
FlacaProductions shoot it right at/around the oil drain plug and se... May 24 2025, 04:59 PM
930cabman I have ran my 2056 up to 220 for extended road tri... May 24 2025, 05:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:46 PM |
