| Ron914 |
May 8 2025, 05:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 562 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Hello to all who have helped me with this project . @emerygt350 ,@TJB/914, @Superhawk996 , @ChrisFoley , @rjames , @MDTerp
I am in the middle of rebuilding my MPS and have a couple of comments and questions . First when I opened up the unit I found the most difficult job was removing the rivets holding the two halves together. When I removed the retainer plate to take out the old diaphragm it was in two pieces . I needed to take two measurements since I was replacing the stop screw , I needed to measure the the stop screw protrusion into the housing . The instruction sheet sent to me by a member had the measurements he must have made when rebuilding his MPS . His stop screw protrusion was 1.97mm and mine only measured 1.72mm. His inner/outer screw assembly depth in the old diaphragm measured 6.51mm . Here's one of my questions ? when I measured mine I got two measurements depth to inner/outer screw assembly was 4.03 and depth to the washer outside the inner/outer screw assembly was 5.46mm. Again there is a difference and since mine was never accessed before (epoxy over screw was not disturbed) is the difference in measurements ok and which measurement should I use I will try to attach a photo or two to help with my question. this one . I have not touched either of these measurements yet and awaiting any help/comments. I think it's this one to the washer on diaphragm . |
| Superhawk996 |
May 13 2025, 08:37 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,104 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I would open the MPS back up. I can post time lapse video of my MPS if necessary. It doesn’t leak down. I may have reused the OEM rubber seal - can’t remember for sure. I know from experience experience they leak if not assembled properly.
I wouldn’t worry about changing the plugs yet. Get it running better 1st. I’m old school - the way to test plugs is remove them, hook to spark plug wire, use insulated gloves or tools, hold metal part of the plug to the engine / ground, cranks the engine and watch for a bright, hot blue/white spark. Intermittent, weak yellow spark is bad news. Spark not jumping cleanly from the center electrode to the ground electrode is bad news. Seeing the spark as it jumps the gap gives you a lot of information. SAFETY NOTE: don’t do this right in the vicinity of the cylinder bore where fuel vapor may be. Fan housing is a good ground and a safe distance from cylinder opening. Better yet - disable fuel pump while doing this by pulling the pump relay. With respect to the ECU trigger points - just rotate the engine about 1 revolution and verify both sets of trigger points are working. They alternate. One set open, once set closed. The more important thing is to be sure your electrical spade connectors from the wiring are right on the trigger points and making good contact. I doubt anything in the points themselves has changed from when it was runnning last. Check your FI grounds. That Pertronix box looks old, shop worn, annd doesn’t indicate igniter 2 or 3 so I’m going to assume that’s an original subject to burn out and flaky operation if ignition left on. Personally, I would stick with points for now while troubleshooting. The original Pertronix is a deeply flawed design in my opinion given that it can be damaged by leaving the ignition on. It’s a black box - you can’t see or measure what’s going on inside. If you do the visual spark plug test and have a good strong spark with the Pertronix in place - then leave it. Just be aware of its flaws and keep the ignition off while you are doing other troubleshooting lest it go bad in the middle of the troubleshooting and cause more confusion. |
| Ron914 |
May 13 2025, 10:19 AM
I would open the MPS back up. I can post time lapse video of my MPS if necessary. It doesn’t leak down. I may have reused the OEM rubber seal - can’t remember for sure. I know from experience experience they leak if not assembled properly. I wouldn’t worry about changing the plugs yet. Get it running better 1st. I’m old school - the way to test plugs is remove them, hook to spark plug wire, use insulated gloves or tools, hold metal part of the plug to the engine / ground, cranks the engine and watch for a bright, hot blue/white spark. Intermittent, weak yellow spark is bad news. Spark not jumping cleanly from the center electrode to the ground electrode is bad news. Seeing the spark as it jumps the gap gives you a lot of information. SAFETY NOTE: don’t do this right in the vicinity of the cylinder bore where fuel vapor may be. Fan housing is a good ground and a safe distance from cylinder opening. Better yet - disable fuel pump while doing this by pulling the pump relay. With respect to the ECU trigger points - just rotate the engine about 1 revolution and verify both sets of trigger points are working. They alternate. One set open, once set closed. The more important thing is to be sure your electrical spade connectors from the wiring are right on the trigger points and making good contact. I doubt anything in the points themselves has changed from when it was runnning last. Check your FI grounds. That Pertronix box looks old, shop worn, annd doesn’t indicate igniter 2 or 3 so I’m going to assume that’s an original subject to burn out and flaky operation if ignition left on. Personally, I would stick with points for now while troubleshooting. The original Pertronix is a deeply flawed design in my opinion given that it can be damaged by leaving the ignition on. It’s a black box - you can’t see or measure what’s going on inside. If you do the visual spark plug test and have a good strong spark with the Pertronix in place - then leave it. Just be aware of its flaws and keep the ignition off while you are doing other troubleshooting lest it go bad in the middle of the troubleshooting and cause more confusion. I appreciate your information . I figured that was how I should test the plugs but wanted confirmation . Good idea about the fuel pump ,don't want to start a fire . I unfortunately already put the Pertronix back in . Because of what I read I jump to turn off the ignition while I am in the engine bay if motors shuts off while I am messing around so I will be careful. I do carry a set of points/condenser/feeler gauge in my cars tool bag just incase, I will recheck the trigger points I did verify the markings on the wires go to the correct terminals on the dizzy and good connection is being made . I need to reconnect the ECU and reinstall in its location today before anymore testing ,I also will use the old plugs ,I really did not want to put my new plugs in just yet until I get this problem figured out . I will need to order a new set for my tool bag .I will need to find someone to crank the motor over for me so I can test the plugs , I do not have one of those remote starter switches but that sure would make this easier because I usually only have myself for these things . I was thinking of opening up the MPS later today ( I really didn't expect to see so much leak down after replacing the diaphragm . I am almost 99% certain I replaced everything correctly in order . Paper gasket went in first then diaphragm then metal ring . The only suspect to me was using the new round rubber gasket over the old square edged gasket .The small ring was replaced on the big screw as shown in the diagram. Should I reapply more bearing grease to the paper gasket? I wouldn't think the settings I took and used for reassembly would cause a leak ? I will update this post as soon as I can get to these new things to do . |
Ron914 MPS May 8 2025, 05:06 PM
Superhawk996 There you have it, now you know why it was a leake... May 8 2025, 06:36 PM
Ron914
There you have it, now you know why it was a leak... May 8 2025, 06:58 PM
MDTerp
There you have it, now you know why it was a leak... May 8 2025, 08:17 PM
Ron914 Well all done . I must say it was easier than I th... May 8 2025, 08:30 PM
JeffBowlsby Another documented case of a completely fractured ... May 8 2025, 10:15 PM
emerygt350 Way to go. I mean you are disassembling the most ... May 9 2025, 06:57 AM
rjames Crazy that it could hold vacuum at all! May 9 2025, 10:01 AM
Superhawk996
Mine... May 9 2025, 01:24 PM
Ron914 Well I was optimistic that my car was going to run... May 9 2025, 05:37 PM
emerygt350 You can pull the wires one at a time till you find... May 9 2025, 06:09 PM
Superhawk996 This is going to be a tough love post.
When you ... May 9 2025, 07:26 PM
Ron914
When you... May 12 2025, 03:17 PM
Superhawk996 I’m going to post this over here
This is anoth... May 9 2025, 07:53 PM
rjames What Hawk said.
And you just rebuilt your MPS, so... May 9 2025, 08:17 PM
Ron914 Thank you Superhawk and emery ,You are correct in... May 9 2025, 08:27 PM
emerygt350 Once it is all back together, remember that inner ... May 10 2025, 04:22 AM
emerygt350 Don't worry about TDC, the distributor only go... May 12 2025, 05:50 PM
Ron914
Don't worry about TDC, the distributor only g... May 12 2025, 06:57 PM
fiacra
If only I didn't live in California I would b... May 12 2025, 08:03 PM
Ron914
If only I didn't live in California I would ... May 12 2025, 09:46 PM
Superhawk996 First on the to do list
MPS is leaking down too ... May 12 2025, 06:57 PM
Ron914
MPS is leaking down too... May 12 2025, 09:44 PM
Superhawk996 Aren’t other guys in CA running 123’s?
Regard... May 12 2025, 07:00 PM
Superhawk996 Also with respect to the dizzy vs timing
Yes - s... May 12 2025, 07:19 PM
Ron914 As far as putting a 123 in my California car I was... May 12 2025, 09:11 PM
emerygt350 I agree with hawk. The first time I rebuilt mine ... May 13 2025, 10:02 AM
fiacra Ron got that Pertronix from me, and yes it is olde... May 13 2025, 01:34 PM
Ron914
Ron got that Pertronix from me, and yes it is old... May 13 2025, 03:25 PM
fiacra
If I was to eventually pass a smog test I could t... May 13 2025, 07:00 PM
Superhawk996 Remote stater switch is about $15 and pricele... May 13 2025, 01:35 PM
Superhawk996 Z0n2aTFRMiI?si=W8rg02X2Kwp4r_54
I cut this off at... May 13 2025, 02:40 PM
rjames There is an art (and likely some luck) in getting ... May 13 2025, 03:00 PM
Ron914
There is an art (and likely some luck) in getting... May 13 2025, 03:10 PM
SVG223 Good luck with this, my MPS is leaking too, watchi... May 13 2025, 04:18 PM
Ron914 [quote name='SVG223' post='3205335... May 13 2025, 09:01 PM
JeffBowlsby Just a heads up, there are other places the MPS ca... May 13 2025, 06:18 PM
JeffBowlsby dbl dbl. May 13 2025, 06:18 PM
Ron914 Well I opened my MPS and found that the order in w... May 14 2025, 07:57 AM
ChrisFoley I switched from a round o-ring to square in my kit... May 14 2025, 10:45 AM
Ron914
I switched from a round o-ring to square in my ki... May 14 2025, 12:07 PM
emerygt350 I think that is exactly what I did the first time ... May 14 2025, 11:54 AM
Ron914
I think that is exactly what I did the first time... May 14 2025, 12:08 PM
Ron914
I think that is exactly what I did the first time... May 14 2025, 04:36 PM
emerygt350
I think that is exactly what I did the first tim... May 14 2025, 04:48 PM
emerygt350 Although no leak is best. That leak is pretty slow... May 14 2025, 12:29 PM
Superhawk996 Get rid of the adapters
Go straight from vacuum ... May 14 2025, 01:41 PM
Ron914
Go straight from vacuum... May 14 2025, 04:32 PM
Superhawk996
[quote name='Superhawk996' post='3205480' date='M... May 14 2025, 05:58 PM
rjames
[quote name='Superhawk996' post='3205480' date='... May 14 2025, 06:20 PM
Ron914
[quote name='Superhawk996' post='3205480' date='... May 15 2025, 12:29 PM
SVG223 Mine takes 45 seconds to leak from 10 in/hg to 5 i... May 14 2025, 03:12 PM
emerygt350
Mine takes 45 seconds to leak from 10 in/hg to 5 ... May 14 2025, 04:18 PM
ChrisFoley Problem with the old square o-ring is that it will... May 15 2025, 08:57 AM
Ron914
Problem with the old square o-ring is that it wil... May 18 2025, 01:41 PM
Superhawk996 :trophy: you’re getting there! May 18 2025, 02:17 PM
rjames No need to crack it open again to adjust if you ha... May 18 2025, 03:12 PM
Ron914 Well after putting the old square O ring back in ... May 24 2025, 08:40 AM
rjames Put the ecu knob back in the middle and adjust onl... May 24 2025, 09:16 AM
Ron914
Put the ecu knob back in the middle and adjust on... May 24 2025, 10:27 AM
rjames
Put the ecu knob back in the middle and adjust o... May 27 2025, 06:30 PM
Superhawk996
I need to add that I must set my timing still , ... May 28 2025, 05:36 AM
Ron914
I need to add that I must set my timing still ,... May 29 2025, 06:25 PM
JeffBowlsby Of those three pairs of wires, one is grounds for ... May 24 2025, 10:49 AM
Ron914
Of those three pairs of wires, 1 iz grounds did t... May 24 2025, 11:09 AM
Superhawk996 Those grounds are mighty crispy and corroded and a... May 28 2025, 05:31 AM
Superhawk996 My bad Ron
I completely forgot you were running P... May 30 2025, 04:15 AM
Ron914 Hello to all that have been helping me getting my ... Aug 19 2025, 03:10 PM
Superhawk996 Hi Ron,
Glad you haven’t given up.
Two thi... Aug 19 2025, 04:35 PM
Superhawk996 Here’s a little experiment you can do before the... Aug 19 2025, 04:46 PM
Ron914 I will try your suggestions later today and post t... Aug 19 2025, 05:03 PM
emerygt350
I will try your suggestions later today and post ... Aug 19 2025, 05:20 PM
Ron914
I will try your suggestions later today and post... Aug 19 2025, 05:30 PM
Superhawk996
I will try your suggestions later today and post ... Aug 19 2025, 07:50 PM
Ron914 @Superhawk996 I made the checks you requested and... Aug 19 2025, 10:39 PM
ctc911ctc Audio engineers Fluke!
[b]@[url=http://www.... Aug 20 2025, 09:52 AM
Superhawk996 Good job and report out on the testing Ron. :head... Aug 19 2025, 11:33 PM
Ron914
Good job and report out on the testing Ron. :hea... Aug 20 2025, 08:12 AM
Ron914 I made the tool needed to remove my CHT and I noti... Aug 25 2025, 12:30 PM
Ron914 I decided to verify the condition of the CHT wire ... Aug 25 2025, 12:46 PM
Superhawk996 Flukes rarely go bad
New leads are much cheaper ... Aug 25 2025, 12:59 PM
ctc911ctc
:agree:... Aug 25 2025, 01:27 PM
Ron914 Yes the car is still stalling after 5-10 minutes o... Aug 25 2025, 01:44 PM
Superhawk996
Yes the car is still stalling after 5-10 minutes ... Aug 25 2025, 03:54 PM
Ron914
Yes the car is still stalling after 5-10 minutes... Aug 25 2025, 05:39 PM
emerygt350 Your not at a higher altitude are you?
16 isnt en... Aug 25 2025, 02:04 PM
Ron914
16 isnt e... Aug 25 2025, 02:32 PM
emerygt350 At the least you can resell it. Just remember, th... Aug 25 2025, 03:22 PM
cgnj I'm curious where these diaphragms are being s... Aug 25 2025, 03:29 PM
emerygt350 Go for it! I love a carb too but this is like ... Aug 25 2025, 03:44 PM
Superhawk996 Ah - OK so you have a good wire from sensor to ECU... Aug 25 2025, 07:03 PM
emerygt350 I always do a visual before hand as well. Mps vac... Aug 26 2025, 05:37 AM
Puebloswatcop Where can I obtain a MPS re-build kit with a new d... Aug 26 2025, 06:46 AM
FlacaProductions Unless someone is going to sell you from their sta... Aug 26 2025, 07:17 AM
Ron914 Getting back to my D-Jet issue , walking away is w... Sep 8 2025, 12:05 PM
rjames I'm confused (happens often).
On August 19th y... Sep 8 2025, 12:38 PM
Ron914
On August 19th ... Sep 8 2025, 03:00 PM
emerygt350 A 2 psi drop would lean the mix quite a bit.
That... Sep 8 2025, 02:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 09:46 PM |
