> VDO Oil gage and temp sender question
torakki
post May 9 2025, 08:01 PM
A while back, I asked about how hot a 914 should run on a VDO gage with no numbers. Responses said, I need to look at the sender to see if it matches the gage. I had a chance to get the sender out so here it is.
After a high reving drive on a warm day, the temp went close to the red zone. Maybe a needle or twos width to the red.
Do I have a matching gage with sender?
Thanks!
Attached Image Attached ImageAttached Image
torakki
post May 13 2025, 06:38 PM
Today's update: I'll try and add more detail. I took out a spark plug, and it appeared, to me, as within normal range. Maybe slightly rich. I followed up with a drive and I was incorrect before about puffing out the intake. It's actually puffing out the exhaust so maybe too rich.
The drive the other day was about 20 minutes, and many shifts were close to redline. Temp in mid 80's and mostly level roads. Temp got close to the red, so it was a 3-mile drive home, a handful of red lights and I shifted maybe in the 3k area and tried to keep it in a taller gear thinking, slower engine speed, more outside air going over the engine.
Today was a test drive. All flat roads, shifting between 3k to 4.5k rpm's. A few quick little accelerations but long flat straightaways in 4th and 5th gear around 3k steady rpm's. Temp still crept up very close to the red. I pulled over and let it idle for maybe 5 minutes with not much change. If I shifted at higher rpm's or lower, it didn't seem to make much difference. Total drive was 35 to 40 minutes. I did notice, when I turned the headlights on, the temp pegged to red. And, the voltmeter went to zero (wasn't working right anyway). Unrelated, I'm sure. I don't have oil pressure gauge so no idea.
I'll do a compression test in the next day or so. I was in the process of selling it but I want this resolved first and wasn't planning on spending more $$.
Thank you and updates soon...
Attached ImageAttached ImageAttached Image
torakki   VDO Oil gage and temp sender question   May 9 2025, 08:01 PM
Superhawk996   Yes - correct 200C sender.   May 9 2025, 08:09 PM
914Sixer   The ONLY factory sender for all years was 0-200. ...   May 10 2025, 06:09 AM
torakki   I just checked my gauge and it matches the sender ...   May 10 2025, 11:52 AM
Superhawk996   Why is my engine running so warm? It's very...   May 10 2025, 12:16 PM
Superhawk996   So, my car, if your drive it briskly, is running ...   May 10 2025, 12:27 PM
porschetub   So, my car, if your drive it briskly, is running...   May 10 2025, 05:43 PM
jim_hoyland   What does your temp gauge read in stop and go traf...   May 10 2025, 12:31 PM
930cabman   Can always check with an infrared point/shoot   May 10 2025, 04:36 PM
Geezer914   I would consider installing a remote oil cooler...   May 11 2025, 04:18 AM
torakki   Looks like there are quite a few things that lead ...   May 11 2025, 07:03 PM
Superhawk996   After the quick drive, I did a slow drive home (...   May 12 2025, 08:44 AM
Superhawk996   10w40 certainly isn’t too high of a viscosity. ...   May 11 2025, 07:15 PM
Montreal914   The CHT comment related to an "under the spar...   May 11 2025, 08:34 PM
Superhawk996   :agree: good references The other thing about t...   May 12 2025, 08:35 AM
porschetub   :agree: good references The other thing about ...   May 12 2025, 05:27 PM
torakki   Today's update: I'll try and add more deta...   May 13 2025, 06:38 PM
930cabman   Today's update: I'll try and add more det...   May 14 2025, 04:57 AM
emerygt350   Have you checked your voltage at the battery? Has...   May 13 2025, 07:45 PM
Superhawk996   :agree: More or less. Don’t get too freaked - E...   May 13 2025, 09:56 PM
torakki   I know I keep forgetting to say the engine size. I...   May 15 2025, 01:11 AM
Superhawk996   Yeah, that’s certainly hot for a 2.0l under the ...   May 15 2025, 06:13 AM
torakki   I finally got out to check for blockages in the fa...   May 17 2025, 12:02 PM
930cabman   I finally got out to check for blockages in the f...   May 17 2025, 02:52 PM
torakki   Last Update, finally: I ordered a laser temp gauge...   May 24 2025, 02:05 PM
porschetub   Last Update, finally: I ordered a laser temp gaug...   May 24 2025, 06:21 PM
FlacaProductions   shoot it right at/around the oil drain plug and se...   May 24 2025, 04:59 PM
930cabman   I have ran my 2056 up to 220 for extended road tri...   May 24 2025, 05:10 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:59 PM
