| jim_hoyland |
May 12 2025, 08:24 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,962 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Bob and I tested for a parasitic drain today; about a week ago engine wouldn’t turn over Hadn’t left anything on.
Today’s test we got 3.28 micro amps . The meter was connected to the battery neg post and system ground. Seemed ok ? |
| Dave_Darling |
May 13 2025, 07:21 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,301 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Did you just put the probes on the negative battery post and the engine ground? With the battery ground strap connected?
Doing this will give you a very low reading that is basically meaningless. You need to disconnect the battery ground, then put the ammeter in between the battery post and a chassis ground. The most convenient one being the negative battery terminal. Unless you're using a very fancy "amp clamp" type of meter, an ammeter will only measure the current that is passing through it. --DD |
| jim_hoyland |
May 13 2025, 07:47 PM
Did you just put the probes on the negative battery post and the engine ground? With the battery ground strap connected? Doing this will give you a very low reading that is basically meaningless. You need to disconnect the battery ground, then put the ammeter in between the battery post and a chassis ground. The most convenient one being the negative battery terminal. Unless you're using a very fancy "amp clamp" type of meter, an ammeter will only measure the current that is passing through it. --DD OK; the battery ground was disconnected 1st, one probe was set on battery neg post, the other probe was attached to the battery’s ground cable. |
jim_hoyland Was looking for parasitic loss… May 12 2025, 08:24 PM
worn
Bob and I tested for a parasitic drain today; abo... May 12 2025, 08:40 PM
dtmehall i think that a lot more background info would help... May 12 2025, 08:43 PM
jim_hoyland Typo : CDR, meant car engine
The car normally get ... May 12 2025, 08:52 PM
L-Jet914 How old is the battery? Was the battery fully char... May 12 2025, 10:41 PM
ctc911ctc
How old is the battery? Was the battery fully cha... May 13 2025, 06:47 AM
jim_hoyland Optima 34R, at least 10 yr old, test was done on f... May 13 2025, 05:51 AM
L-Jet914
Optima 34R, at least 10 yr old, test was done on ... May 13 2025, 07:32 PM
Superhawk996 Just not enough info. Details matter. May 13 2025, 07:57 AM
76-914 Jim, This is what LJet914 was describing but with ... May 13 2025, 08:31 AM
jim_hoyland Thanks Kent :)
The second uTube is very good; it ... May 13 2025, 08:56 AM
davep Considering a 10 year old battery, I would guess t... May 13 2025, 09:21 AM
mgp4591
Considering a 10 year old battery, I would guess ... May 23 2025, 12:43 AM
JOEPROPER When tested correctly anything below 0.05 Amps is ... May 13 2025, 10:05 AM
jim_hoyland Good tips( thank you :) May 13 2025, 10:53 AM
Root_Werks
Did you just put the probes on the negative batt... May 14 2025, 05:07 PM
jim_hoyland Got my battery tester today and made a their preli... May 14 2025, 05:31 PM
ClayPerrine I made this for an Okteenerfest tech session. It ... May 15 2025, 11:20 AM
ClayPerrine If you want the MS Word copy of the document, PM m... May 15 2025, 11:25 AM
Root_Werks Any multimeter should be able to run this test and... May 15 2025, 01:11 PM
ThinAir I was very excited to try RootWerks approach since... May 22 2025, 02:12 PM
Superhawk996
So... since disconnecting things never made a d... May 22 2025, 07:54 PM
Root_Werks Oh boy, well, there's the starter and alternat... May 22 2025, 03:19 PM
ThinAir
Oh boy, well, there's the starter and alterna... May 27 2025, 04:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 01:00 PM |
