| torakki |
May 9 2025, 08:01 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
A while back, I asked about how hot a 914 should run on a VDO gage with no numbers. Responses said, I need to look at the sender to see if it matches the gage. I had a chance to get the sender out so here it is.
After a high reving drive on a warm day, the temp went close to the red zone. Maybe a needle or twos width to the red. Do I have a matching gage with sender? Thanks! |
| Superhawk996 |
May 13 2025, 09:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
(IMG:style_emoticons/default/agree.gif) More or less. Don’t get too freaked - Emery is exaggerating bit when he says melting. (IMG:style_emoticons/default/biggrin.gif)
Something isn’t right for it to be getting oil that hot that quickly at those ambient temps and loads. Agree plugs look fine. What size is the engine? Any idea what size oil pump is in it? As was suggested early by Cabman - if possible a quick double check of the sump with an IR temp gauge would tell you if there is massive gauge error due to coincident electrical issues. Great looking underbody - you’ve been a great custodian of it! (IMG:style_emoticons/default/smilie_pokal.gif) I’m betting the solution isn’t costly, something overlooked. You’ve said you’ve confirmed flaps and no blockage of oil cooler. Also sounds like engine has been in/out & obviously cleaned and worked on. Did you check the fan to make sure there isn’t something in it? So here’s a crazy theory: you sure your oil pressure relief valve (piston & spring) is installed correctly and/or not hung up and bypassing the oil cooler? |
torakki VDO Oil gage and temp sender question May 9 2025, 08:01 PM
Superhawk996 Yes - correct 200C sender.
May 9 2025, 08:09 PM
914Sixer The ONLY factory sender for all years was 0-200. ... May 10 2025, 06:09 AM
torakki I just checked my gauge and it matches the sender ... May 10 2025, 11:52 AM
Superhawk996
Why is my engine running so warm? It's very... May 10 2025, 12:16 PM
Superhawk996
So, my car, if your drive it briskly, is running ... May 10 2025, 12:27 PM
porschetub
So, my car, if your drive it briskly, is running... May 10 2025, 05:43 PM
jim_hoyland What does your temp gauge read in stop and go traf... May 10 2025, 12:31 PM
930cabman Can always check with an infrared point/shoot May 10 2025, 04:36 PM
Geezer914 I would consider installing a remote oil cooler... May 11 2025, 04:18 AM
torakki Looks like there are quite a few things that lead ... May 11 2025, 07:03 PM
Superhawk996
After the quick drive, I did a slow drive home (... May 12 2025, 08:44 AM
Superhawk996 10w40 certainly isn’t too high of a viscosity. ... May 11 2025, 07:15 PM
Montreal914 The CHT comment related to an "under the spar... May 11 2025, 08:34 PM
Superhawk996 :agree: good references
The other thing about t... May 12 2025, 08:35 AM
porschetub
The other thing about ... May 12 2025, 05:27 PM
torakki Today's update: I'll try and add more deta... May 13 2025, 06:38 PM
930cabman
Today's update: I'll try and add more det... May 14 2025, 04:57 AM
emerygt350 Have you checked your voltage at the battery? Has... May 13 2025, 07:45 PM
torakki I know I keep forgetting to say the engine size. I... May 15 2025, 01:11 AM
Superhawk996 Yeah, that’s certainly hot for a 2.0l under the ... May 15 2025, 06:13 AM
torakki I finally got out to check for blockages in the fa... May 17 2025, 12:02 PM
930cabman
I finally got out to check for blockages in the f... May 17 2025, 02:52 PM
torakki Last Update, finally: I ordered a laser temp gauge... May 24 2025, 02:05 PM
porschetub
Last Update, finally: I ordered a laser temp gaug... May 24 2025, 06:21 PM
FlacaProductions shoot it right at/around the oil drain plug and se... May 24 2025, 04:59 PM
930cabman I have ran my 2056 up to 220 for extended road tri... May 24 2025, 05:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:12 AM |
