> Was looking for parasitic loss…, Tested today
jim_hoyland
post May 12 2025, 08:24 PM
Get that VIN ?
Bob and I tested for a parasitic drain today; about a week ago engine wouldn’t turn over Hadn’t left anything on.
Today’s test we got 3.28 micro amps . The meter was connected to the battery neg post and system ground.
Seemed ok ?
Dave_Darling
post May 13 2025, 07:21 PM
914 Idiot
Did you just put the probes on the negative battery post and the engine ground? With the battery ground strap connected?
Doing this will give you a very low reading that is basically meaningless. You need to disconnect the battery ground, then put the ammeter in between the battery post and a chassis ground. The most convenient one being the negative battery terminal.
Unless you're using a very fancy "amp clamp" type of meter, an ammeter will only measure the current that is passing through it.
--DD
jim_hoyland
post May 13 2025, 07:47 PM
Get that VIN ?
QUOTE(Dave_Darling @ May 13 2025, 06:21 PM) *
--DD
OK; the battery ground was disconnected 1st, one probe was set on battery neg post, the other probe was attached to the battery’s ground cable.
Root_Werks
post May 14 2025, 05:07 PM
Village Idiot
QUOTE(jim_hoyland @ May 13 2025, 06:47 PM) *
--DD
Yup, that's correct. Make sure NOT to turn on headlights or other large draw items. You'll either pop the fuse in your multimeter or burn it. It should say what max amp it can read.
Had a parasitic drain on an L-Jet 2.0 many years ago. Wound up being the double relay. Just had to unplug relays and remove fuses one at a time until the drain went away.
jim_hoyland   Was looking for parasitic loss…   May 12 2025, 08:24 PM
worn   Bob and I tested for a parasitic drain today; abo...   May 12 2025, 08:40 PM
dtmehall   i think that a lot more background info would help...   May 12 2025, 08:43 PM
jim_hoyland   Typo : CDR, meant car engine The car normally get ...   May 12 2025, 08:52 PM
L-Jet914   How old is the battery? Was the battery fully char...   May 12 2025, 10:41 PM
ctc911ctc   How old is the battery? Was the battery fully cha...   May 13 2025, 06:47 AM
jim_hoyland   Optima 34R, at least 10 yr old, test was done on f...   May 13 2025, 05:51 AM
L-Jet914   Optima 34R, at least 10 yr old, test was done on ...   May 13 2025, 07:32 PM
Superhawk996   Just not enough info. Details matter.   May 13 2025, 07:57 AM
76-914   Jim, This is what LJet914 was describing but with ...   May 13 2025, 08:31 AM
jim_hoyland   Thanks Kent :) The second uTube is very good; it ...   May 13 2025, 08:56 AM
davep   Considering a 10 year old battery, I would guess t...   May 13 2025, 09:21 AM
mgp4591   Considering a 10 year old battery, I would guess ...   May 23 2025, 12:43 AM
JOEPROPER   When tested correctly anything below 0.05 Amps is ...   May 13 2025, 10:05 AM
jim_hoyland   Good tips( thank you :)   May 13 2025, 10:53 AM
Dave_Darling   Did you just put the probes on the negative batter...   May 13 2025, 07:21 PM
jim_hoyland   Did you just put the probes on the negative batte...   May 13 2025, 07:47 PM
Root_Werks   Did you just put the probes on the negative batt...   May 14 2025, 05:07 PM
jim_hoyland   Got my battery tester today and made a their preli...   May 14 2025, 05:31 PM
ClayPerrine   I made this for an Okteenerfest tech session. It ...   May 15 2025, 11:20 AM
ClayPerrine   If you want the MS Word copy of the document, PM m...   May 15 2025, 11:25 AM
Root_Werks   Any multimeter should be able to run this test and...   May 15 2025, 01:11 PM
ThinAir   I was very excited to try RootWerks approach since...   May 22 2025, 02:12 PM
Superhawk996   So... since disconnecting things never made a d...   May 22 2025, 07:54 PM
Root_Werks   Oh boy, well, there's the starter and alternat...   May 22 2025, 03:19 PM
ThinAir   Oh boy, well, there's the starter and alterna...   May 27 2025, 04:27 PM
- Lo-Fi Version Time is now: 15th December 2025 - 12:58 PM
