> First ride of the season = oil leak!
PaIsa
post May 14 2025, 04:55 AM
So after the long winter, warmer weather is back. I finally completed all the work on the car and was able to get it out of the garage for a quick ride.
First here is the list of what I did on the car during the winter:
- Took the engine and transmission out of the car
- Replace most of the seals on the tail shift transmission
- Replace most of the shifter linkage balls & bushing
- Valves adjustment on the engine
- Push rod tube seal replacement
- Some push rods were replace since I destroyed some while trying to get them out.
- Valve cover gaskets replacement
- Front main shaft seal replacement (the fan side)
- Oil cooler seal replacement
- Refurbishing of the rear suspension (torsion bar, bushings, springs, shocks, etc.)
- New pedal set
- New muffler
and I am probably missing some small items.
Car runs great. Much quieter with the new muffler. Shifts very well. Pulls like it use to. No complaints, but...
When I got back from the quick ride (10 km), I found out that there is what appears to be an oil leak on the left side of the engine. There was smoke coming from oil that was sprayed on the left side and that dripped over the hot heat exchangers.
With all the work that I have done, I guess that I did something wrong since the car did not leaked there last summer. So what do you think that I did wrong and that I should look at?
The oil (appears to be engine oil) can be seen on the valve cover and was sprayed on the chassis of the car (I saw oil on the inside torsion bar attachment, on the parking brake cable, on the heat exchanger, etc.). Can it be a leaking cover gasket or a badly install push rod tube seals??
I will go out again tonight and after the ride I will get the car on the lift and take some pictures to try to better explain the situation. In the meantime, I am open to any comment or advice.
The engine is a 1.8L.
jcd914
post May 15 2025, 09:34 PM
I use gask-a-cinch on cover side and light coat of grease on the head side.
It allows the cover to move around a little and does not stick to the head next valve adjustment.
PaIsa   First ride of the season = oil leak!   May 14 2025, 04:55 AM
Geezer914   My first guess is that the valve cover gasket shif...   May 14 2025, 06:23 AM
PaIsa   My first guess is that the valve cover gasket shi...   May 14 2025, 06:40 AM
930cabman   My first guess is that the valve cover gasket sh...   May 14 2025, 09:22 AM
930cabman   [quote name='PaIsa' post='3205420' date='May 14 2...   May 14 2025, 12:39 PM
rjames   Hopefully it's just the valve cover gasket, bu...   May 14 2025, 10:13 AM
PaIsa   Hopefully it's just the valve cover gasket, b...   May 14 2025, 10:30 AM
Osnabruck914   I just had oil on top of my left side heat exchang...   May 14 2025, 11:03 AM
Jack Standz   Best wishes with stopping the leaks. It's r...   May 14 2025, 05:25 PM
Dave_Darling   Another possibility could be that the breather hos...   May 14 2025, 06:32 PM
nivekdodge   Something I remember when the car pees a little on...   May 14 2025, 06:54 PM
PaIsa   So I started the car yesterday. Ran it for a few ...   May 15 2025, 05:06 AM
rjames   I don't know what material the Reinz gaskets a...   May 15 2025, 09:01 AM
PaIsa   I font know what material the Reinz gaskets are m...   May 15 2025, 09:17 AM
930cabman   I font know what material the Reinz gaskets are ...   May 15 2025, 09:29 AM
rjames   [quote name='PaIsa' post='3205601' date='May 15 2...   May 15 2025, 09:42 AM
PaIsa   [quote name='PaIsa' post='3205601' date='May 15 2...   May 15 2025, 10:14 AM
FlacaProductions   I use gask-a-cinch on the cover side only. Dry on...   May 15 2025, 03:55 PM
930cabman   I use gask-a-cinch on the cover side only. Dry o...   May 15 2025, 04:06 PM
Geezer914   Permatex Avaition gasket sealer #3 on the valve co...   May 15 2025, 09:00 PM
jcd914   :agree: I use gask-a-cinch on cover side and lig...   May 15 2025, 09:34 PM
PaIsa   Thanks for all the advice. I will look what produ...   May 16 2025, 06:47 AM
PaIsa   Repair done using Permatex Aviation sealer #3 and ...   May 18 2025, 03:08 PM
PaIsa   Finally was able to find a somewhat decent weather...   May 26 2025, 05:59 AM
rhodyguy   Cinch-A-Gasket on the valve cover side of the CORK...   May 26 2025, 01:12 PM
- Lo-Fi Version Time is now: 21st July 2025 - 12:06 AM
