| Shivers |
Sep 8 2024, 06:47 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,640 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Because the port is almost straight, with little long side short side concerns, with what there is , do you find it necessary to slow the flow down on the “short side” to get good flow out of the valve. I was reading about something mepstein posted a picture of. Small divots, like a golf ball. So I’m going to do that on the long side, just wondering if there is any reason not to also do it on the short side. Thanks guy’s (IMG:style_emoticons/default/smile.gif)
| HAM Inc |
May 14 2025, 07:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
It's true that there aren't many 200hp 2.0's out there. But back in 2006 Jake and I collaborated on a SCCA EP engine that made 206hp at around 7500rpm's. It was legal, reliable and raced well. Was a turd under about 5K RPM's but it didn't see those revs in a race.
We also had 1.8 FP engine that made 186HP. It too was legal, reliable and raced well. 100hp/liter is doable with a N.A. T4 but it wouldn't be streetable. |
| Charles Freeborn |
May 14 2025, 11:20 PM
Member ![]() ![]() Group: Members Posts: 345 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
It's true that there aren't many 200hp 2.0's out there. But back in 2006 Jake and I collaborated on a SCCA EP engine that made 206hp at around 7500rpm's. It was legal, reliable and raced well. Was a turd under about 5K RPM's but it didn't see those revs in a race. We also had 1.8 FP engine that made 186HP. It too was legal, reliable and raced well. 100hp/liter is doable with a N.A. T4 but it wouldn't be streetable. I’d be interested in the specs of an FP / VP1 legal 1.8. I believe the max carb size is 40mm? |
| HAM Inc |
May 16 2025, 06:54 AM
It's true that there aren't many 200hp 2.0's out there. But back in 2006 Jake and I collaborated on a SCCA EP engine that made 206hp at around 7500rpm's. It was legal, reliable and raced well. Was a turd under about 5K RPM's but it didn't see those revs in a race. We also had 1.8 FP engine that made 186HP. It too was legal, reliable and raced well. 100hp/liter is doable with a N.A. T4 but it wouldn't be streetable. I’d be interested in the specs of an FP / VP1 legal 1.8. I believe the max carb size is 40mm? The FP rules allowed 38mm venturis in 40mm carbs (we ran Dels), 42 x 34mm valves, any port work, any cam, 94mm x 66mm bore & stroke. LN Engineering was on board with the development too and supplied Nickies and JE Pistons. Foley exhaust. I spent a tremendous amount of time on the heads. Jake assembled and tuned it. Nothing run-of-the-mill about either of the engines. |
Shivers Porting a type 4 head Sep 8 2024, 06:47 PM
Brett W The Intake port isn't the problem. You can ea... Apr 23 2025, 08:34 AM
Shivers
The Intake port isn't the problem. You can e... Apr 23 2025, 10:44 AM
technicalninja Exh port is where the restriction lives IMO.
Does... Apr 23 2025, 10:52 AM
Shivers
Doe... Apr 23 2025, 06:36 PM
brant You really need a flow bench to measure whether yo... Apr 23 2025, 02:19 PM
914sgofast2 just polish the exhust port and leave the intake p... Apr 23 2025, 09:26 PM
Shivers
just polish the exhust port and leave the intake ... Apr 24 2025, 09:13 AM
HAM Inc Hey all. It's been a while since I jumped into... Apr 30 2025, 07:58 AM
Shivers
Hey all. It's been a while since I jumped int... Apr 30 2025, 08:03 PM
Charles Freeborn The heads on my previous race car built by Allen J... May 6 2025, 11:21 PM
Shivers
The heads on my previous race car built by Allen ... May 7 2025, 05:45 AM
brant I used to run the same AJRS heads in the 1990... May 7 2025, 10:21 AM
Shivers
I used to run the same AJRS heads in the 1990... May 7 2025, 05:24 PM
Charles Freeborn
I used to run the same AJRS heads in the 1990... May 9 2025, 11:14 AM
Shivers
I used to run the same AJRS heads in the 1990... May 9 2025, 02:58 PM
Charles Freeborn
[quote name='Charles Freeborn' post='3204716' dat... May 10 2025, 09:40 AM
brant The GT classes in PCA were designed to run 110hp p... May 10 2025, 10:42 AM
Charles Freeborn
The GT classes in PCA were designed to run 110hp ... May 10 2025, 03:47 PM
stownsen914
The GT classes in PCA were designed to run 110hp ... May 11 2025, 08:57 PM
brant
The GT classes in PCA were designed to run 110hp... May 12 2025, 10:30 PM
Charles Freeborn
[quote name='stownsen914' post='3205073' date='Ma... May 13 2025, 09:34 AM
Shivers Thanks everybody, I am motivated. :) May 10 2025, 03:05 PM
Charles Freeborn
[quote name='Charles Freeborn' post='3205549' dat... May 19 2025, 09:55 AM
brant Those are numbers I didn’t know about
Amazing May 14 2025, 07:38 PM
ClayPerrine Is there anything in the rules that says you canno... May 16 2025, 09:21 AM
HAM Inc EFI was only legal with the O.E. system back then.... May 16 2025, 02:45 PM
ClayPerrine
EFI was only legal with the O.E. system back then... May 16 2025, 02:53 PM
Charles Freeborn
EFI was only legal with the O.E. system back the... May 19 2025, 09:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 11:41 PM |
