> Seat Belt Interlock Relay, Late 74-76’ - how does it work?
Superhawk996
post May 15 2025, 09:57 AM
For those of you that despise the seatbelt / starter interlock and the horrific screeching noise the seat belt buzzer makes - let me say I understand completely. As I’ve been playing with this on the bench my wife now hates the noise just as much as I do.
This thread is going to explain how it works and how to bench test it over the coming days.
Credit is owed to @JeffBowlsby , @Bdstone914 , and @Montreal914 for providing me with donor parts that will make this thread possible.
Eventually I will post the schematic of this ridiculous conglomeration of components. I hope to eventually put the circuit in LTSpice to help verify its theoretical operation. I make no warranty as to the accuracy of the schematic - this is just me satisfying my own curiosity.
If you have no interest in my personality defects that would lead me to take on this little project; ignore this thread.
If you have a late car with an in-op system and eventually want to get it working - this thread is for you.
Toward the end I’ll share some ideas on how to get rid of or to change that horrific buzzer noise.
friethmiller
post May 16 2025, 07:30 AM
Great thread, Phil. (IMG:style_emoticons/default/popcorn[1].gif) On my red '74 I rewired everything based on the following diagram (Jeff's?). I never plugged any of the "relays" in to even test it out. I wonder if it would work? This thread has me thinking. I know the passenger seat has the wiring (IMG:style_emoticons/default/idea.gif)
I know I have the smaller relay (see arrow). Not sure about the big one. I remember it being pretty bad inside.
Superhawk996
post May 16 2025, 12:54 PM
QUOTE(friethmiller @ May 16 2025, 09:30 AM) *
(IMG:style_emoticons/default/biggrin.gif) good catch!
Jeff has shared that wiring info and small conventional cube relay with me. We haven’t quite figured out how what plays into this - the cube relay appears to be undocumented in any of the Haynes or factory wiring diagrams
I’m sure I’ll be asking for help from some folks to verify wiring on that - my car is a 73’.
I’ve decided to ignore the cube relay in the short term and just document the interlock relay 1st. Once that is documented - then I think we can better figure out what the cube relay is doing.
barefoot
post May 16 2025, 01:29 PM
QUOTE(Superhawk996 @ May 16 2025, 02:54 PM) *
I’ve got to apologize in advance - have some commitments with the wife that I have to take care of during the day - will try to post the cushion and belt latch info later tonight
You must have a lot of free time on your hands, is this a retirement project ? (IMG:style_emoticons/default/stirthepot.gif)
A lot of work for a tiny return to the 914 community.
Barefoot
Superhawk996
post May 16 2025, 02:00 PM
QUOTE(barefoot @ May 16 2025, 03:29 PM) *
Barefoot
Yup. Personal enrichment - want to understand it and how it works. I mentioned I had character flaws right up front (IMG:style_emoticons/default/happy11.gif)
Stated as a challenge from another member that shares a hatred of the buzzer but doesn’t want to disable and bypass the Fasten Seat Belt light functionality completely.
ClayPerrine
post May 16 2025, 02:49 PM
QUOTE(Superhawk996 @ May 16 2025, 03:00 PM) *
Barefoot
I would just build a small electronic circuit with a 555 timer that would turn the light on when the ignition was switched on, and shut of 15 seconds later. Then wire it to the back of the light.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.circuits-diy.com-1143-1747428580.1.png)
Replace the resistor and the buzzer with the fasten seat belt light. Instead of the push button switch, wire it to fuse 9 on the fuse box.
Now the light comes on, but no buzzer and no failed starts due to the interlock relay.
Superhawk996   Seat Belt Interlock Relay   May 15 2025, 09:57 AM
Superhawk996   My curiosity in this part is the result of the Hay...   May 15 2025, 10:05 AM
Superhawk996   Let’s start with how this thing is supposed to w...   May 15 2025, 10:06 AM
ClayPerrine   While I am curious to know how it works, I am stil...   May 15 2025, 11:09 AM
Superhawk996   While I am curious to know how it works, I am sti...   May 15 2025, 11:34 AM
914werke   [url=http://www.914world.com/bbs2/index.php?s=...   May 15 2025, 11:44 AM
Superhawk996   [url=http://www.914world.com/bbs2/index.php?s=...   May 15 2025, 11:59 AM
Superhawk996   So this is where things start to go astray. I ca...   May 15 2025, 11:57 AM
fiacra   The one thing I haven’t been able to find is a...   May 15 2025, 04:51 PM
Superhawk996   Here you go. From my 1975 Owner's manual. ...   May 15 2025, 06:52 PM
rjames   Following :popcorn: I've thought about tryi...   May 15 2025, 12:53 PM
Root_Werks   Following :popcorn: I've thought about try...   May 15 2025, 01:06 PM
Superhawk996   Let’s start with the Haynes / factory manual bla...   May 15 2025, 02:47 PM
Superhawk996   The PIN ID’s are clearly labeled on the interloc...   May 15 2025, 02:59 PM
Superhawk996   The Fasten Seat Belt light is powered by 12v suppl...   May 15 2025, 03:03 PM
Superhawk996   So let’s talk about the horrific buzzer If a s...   May 15 2025, 03:39 PM
rjames   F that buzzer. :lol:   May 15 2025, 06:01 PM
Superhawk996   F that buzzer. :lol: :lol4: for sure! Iâ...   May 15 2025, 06:38 PM
Artfrombama   Interesting, appreciate the research! P. O. di...   May 15 2025, 07:05 PM
JeffBowlsby   This is awesome Phil! Chipping away at one of...   May 15 2025, 09:51 PM
StarBear   :popcorn: Enjoying this immensely. Disconnected m...   May 16 2025, 06:53 AM
flipb   Just checked my 1974 manual and it's pretty mu...   May 16 2025, 07:08 AM
friethmiller   Great thread, Phil. :popcorn: On my red '74 ...   May 16 2025, 07:30 AM
Superhawk996   I know I have the smaller relay (see arrow). N...   May 16 2025, 12:54 PM
barefoot   I know I have the smaller relay (see arrow). ...   May 16 2025, 01:29 PM
Superhawk996   You must have a lot of free time on your hands, ...   May 16 2025, 02:00 PM
ClayPerrine   [quote name='barefoot' post='3205819' date='May 1...   May 16 2025, 02:49 PM
Superhawk996   I would just build a small electronic circuit wi...   May 16 2025, 05:37 PM
ClayPerrine   I can remember taking the seat cushion out of Bett...   May 16 2025, 09:16 AM
Superhawk996   I can remember taking the seat cushion out of Bet...   May 16 2025, 12:56 PM
davep   Just saw this thread. I worked on this about 3 yea...   May 16 2025, 03:18 PM
Superhawk996   The two minute restart delay comes from the oil ...   May 16 2025, 05:31 PM
Superhawk996   Driver side seat circuits The driver side seat c...   May 16 2025, 07:22 PM
Superhawk996   Here’s how the situation looks on the bench with...   May 16 2025, 07:32 PM
Superhawk996   And again with the seat belt fastened where the op...   May 16 2025, 07:34 PM
Superhawk996   So at this point we are though the sit down & ...   May 16 2025, 08:06 PM
Superhawk996   I know almost no one cares about the internal deta...   May 16 2025, 08:26 PM
Superhawk996   Oh - here’s which relays are which The starter...   May 16 2025, 09:03 PM
Superhawk996   More coming on observed anomalies and how the oil ...   May 16 2025, 09:07 PM
Superhawk996   This video shows behavior of the relay under a cou...   May 19 2025, 11:44 AM
Superhawk996   OK. Been sidelined for a little while but time to...   Aug 25 2025, 09:32 AM
Superhawk996   If there is interest, I’ll post more on the LTSp...   Aug 25 2025, 09:36 AM
Superhawk996   Here’s the situation where LTspice is capturing ...   Aug 25 2025, 09:53 AM
Superhawk996   So maybe it's an appropriate time to come back...   Aug 25 2025, 10:26 AM
- Lo-Fi Version Time is now: 10th April 2026 - 04:47 AM
