Chad911sc |
Member ![]() ![]() Group: Members Posts: 156 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States ![]() |
Spent the last week refinishing the ground effects and the bumpers. Next step is to put fog lights back into the factory spot. I have the new 914 Rubber fog lights grilles and led lights to fit, but need to know if these are the right wires. And also if they are, how are they operated? Not sure if this car came with them from the factory, the car already had aftermarket plastic grilles in it and they were cracked and broken. My interior only has one light switch that is a pull switch that activates the headlights. I put my volt meter on the brown ground and the white/yellow positive, and no voltage going to them when light switch is pulled out. Are these the factory wires, or something else?
Attached thumbnail(s) ![]() ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
There's a separate switch on the dashboard that operates the fog lights. The switch and relay (in later cars) are connected such that the fogs can only go on when the low beams are on, or if they're actually driving lights so that they can only go on when the high beams are on.
--DD |
Lo-Fi Version | Time is now: 14th July 2025 - 08:23 PM |
