> MPS, Rebuilding the MPS
Ron914
post May 8 2025, 05:06 PM
Hello to all who have helped me with this project . @emerygt350 ,@TJB/914, @Superhawk996 , @ChrisFoley , @rjames , @MDTerp
I am in the middle of rebuilding my MPS and have a couple of comments and questions .
First when I opened up the unit I found the most difficult job was removing the rivets holding the two halves together.
When I removed the retainer plate to take out the old diaphragm it was in two pieces .
I needed to take two measurements since I was replacing the stop screw , I needed to measure the the stop screw protrusion into the housing . The instruction sheet sent to me by a member had the measurements he must have made when rebuilding his MPS . His stop screw protrusion was 1.97mm and mine only measured 1.72mm.
His inner/outer screw assembly depth in the old diaphragm measured 6.51mm .
Here's one of my questions ?
when I measured mine I got two measurements depth to inner/outer screw assembly was 4.03
and depth to the washer outside the inner/outer screw assembly was 5.46mm.
Again there is a difference and since mine was never accessed before (epoxy over screw was not disturbed) is the difference in measurements ok and which measurement should I use I will try to attach a photo or two to help with my question.
this one .
I have not touched either of these measurements yet and awaiting any help/comments.
I think it's this one to the washer on diaphragm .
rjames
post May 18 2025, 03:12 PM
I'm made of metal
No need to crack it open again to adjust if you have the adjustment tools. And you’ll ll need them for fine tuning after reinstalling the MPS in the car anyway.
Ron914   MPS   May 8 2025, 05:06 PM
Superhawk996   There you have it, now you know why it was a leake...   May 8 2025, 06:36 PM
Ron914   There you have it, now you know why it was a leak...   May 8 2025, 06:58 PM
MDTerp   There you have it, now you know why it was a leak...   May 8 2025, 08:17 PM
Ron914   Well all done . I must say it was easier than I th...   May 8 2025, 08:30 PM
JeffBowlsby   Another documented case of a completely fractured ...   May 8 2025, 10:15 PM
emerygt350   Way to go. I mean you are disassembling the most ...   May 9 2025, 06:57 AM
rjames   Crazy that it could hold vacuum at all!   May 9 2025, 10:01 AM
Superhawk996   Crazy that it could hold vacuum at all! Mine...   May 9 2025, 01:24 PM
Ron914   Well I was optimistic that my car was going to run...   May 9 2025, 05:37 PM
emerygt350   You can pull the wires one at a time till you find...   May 9 2025, 06:09 PM
Superhawk996   This is going to be a tough love post. When you ...   May 9 2025, 07:26 PM
Ron914   This is going to be a tough love post. When you...   May 12 2025, 03:17 PM
Superhawk996   I’m going to post this over here This is anoth...   May 9 2025, 07:53 PM
rjames   What Hawk said. And you just rebuilt your MPS, so...   May 9 2025, 08:17 PM
Ron914   Thank you Superhawk and emery ,You are correct in...   May 9 2025, 08:27 PM
emerygt350   Once it is all back together, remember that inner ...   May 10 2025, 04:22 AM
emerygt350   Don't worry about TDC, the distributor only go...   May 12 2025, 05:50 PM
Ron914   Don't worry about TDC, the distributor only g...   May 12 2025, 06:57 PM
fiacra   If only I didn't live in California I would b...   May 12 2025, 08:03 PM
Ron914   If only I didn't live in California I would ...   May 12 2025, 09:46 PM
Superhawk996   First on the to do list MPS is leaking down too ...   May 12 2025, 06:57 PM
Ron914   First on the to do list MPS is leaking down too...   May 12 2025, 09:44 PM
Superhawk996   Aren’t other guys in CA running 123’s? Regard...   May 12 2025, 07:00 PM
Superhawk996   Also with respect to the dizzy vs timing Yes - s...   May 12 2025, 07:19 PM
Ron914   As far as putting a 123 in my California car I was...   May 12 2025, 09:11 PM
Superhawk996   I would open the MPS back up. I can post time lap...   May 13 2025, 08:37 AM
Ron914   I would open the MPS back up. I can post time la...   May 13 2025, 10:19 AM
emerygt350   I agree with hawk. The first time I rebuilt mine ...   May 13 2025, 10:02 AM
fiacra   Ron got that Pertronix from me, and yes it is olde...   May 13 2025, 01:34 PM
Ron914   Ron got that Pertronix from me, and yes it is old...   May 13 2025, 03:25 PM
fiacra   If I was to eventually pass a smog test I could t...   May 13 2025, 07:00 PM
Superhawk996   Remote stater switch is about $15 and pricele...   May 13 2025, 01:35 PM
Superhawk996   Z0n2aTFRMiI?si=W8rg02X2Kwp4r_54 I cut this off at...   May 13 2025, 02:40 PM
rjames   There is an art (and likely some luck) in getting ...   May 13 2025, 03:00 PM
Ron914   There is an art (and likely some luck) in getting...   May 13 2025, 03:10 PM
SVG223   Good luck with this, my MPS is leaking too, watchi...   May 13 2025, 04:18 PM
Ron914   [quote name='SVG223' post='3205335...   May 13 2025, 09:01 PM
JeffBowlsby   Just a heads up, there are other places the MPS ca...   May 13 2025, 06:18 PM
JeffBowlsby   dbl dbl.   May 13 2025, 06:18 PM
Ron914   Well I opened my MPS and found that the order in w...   May 14 2025, 07:57 AM
ChrisFoley   I switched from a round o-ring to square in my kit...   May 14 2025, 10:45 AM
Ron914   I switched from a round o-ring to square in my ki...   May 14 2025, 12:07 PM
emerygt350   I think that is exactly what I did the first time ...   May 14 2025, 11:54 AM
Ron914   I think that is exactly what I did the first time...   May 14 2025, 12:08 PM
Ron914   I think that is exactly what I did the first time...   May 14 2025, 04:36 PM
emerygt350   I think that is exactly what I did the first tim...   May 14 2025, 04:48 PM
emerygt350   Although no leak is best. That leak is pretty slow...   May 14 2025, 12:29 PM
Superhawk996   Get rid of the adapters Go straight from vacuum ...   May 14 2025, 01:41 PM
Ron914   Get rid of the adapters Go straight from vacuum...   May 14 2025, 04:32 PM
Superhawk996   [quote name='Superhawk996' post='3205480' date='M...   May 14 2025, 05:58 PM
rjames   [quote name='Superhawk996' post='3205480' date='...   May 14 2025, 06:20 PM
Ron914   [quote name='Superhawk996' post='3205480' date='...   May 15 2025, 12:29 PM
SVG223   Mine takes 45 seconds to leak from 10 in/hg to 5 i...   May 14 2025, 03:12 PM
emerygt350   Mine takes 45 seconds to leak from 10 in/hg to 5 ...   May 14 2025, 04:18 PM
ChrisFoley   Problem with the old square o-ring is that it will...   May 15 2025, 08:57 AM
Ron914   Problem with the old square o-ring is that it wil...   May 18 2025, 01:41 PM
Superhawk996   :trophy: you’re getting there!   May 18 2025, 02:17 PM
rjames   No need to crack it open again to adjust if you ha...   May 18 2025, 03:12 PM
Ron914   Well after putting the old square O ring back in ...   May 24 2025, 08:40 AM
rjames   Put the ecu knob back in the middle and adjust onl...   May 24 2025, 09:16 AM
Ron914   Put the ecu knob back in the middle and adjust on...   May 24 2025, 10:27 AM
rjames   Put the ecu knob back in the middle and adjust o...   May 27 2025, 06:30 PM
Superhawk996   I need to add that I must set my timing still , ...   May 28 2025, 05:36 AM
Ron914   I need to add that I must set my timing still ,...   May 29 2025, 06:25 PM
JeffBowlsby   Of those three pairs of wires, one is grounds for ...   May 24 2025, 10:49 AM
Ron914   Of those three pairs of wires, 1 iz grounds did t...   May 24 2025, 11:09 AM
Superhawk996   Those grounds are mighty crispy and corroded and a...   May 28 2025, 05:31 AM
Superhawk996   My bad Ron I completely forgot you were running P...   May 30 2025, 04:15 AM
Ron914   Hello to all that have been helping me getting my ...   Aug 19 2025, 03:10 PM
Superhawk996   Hi Ron, Glad you haven’t given up. Two thi...   Aug 19 2025, 04:35 PM
Superhawk996   Here’s a little experiment you can do before the...   Aug 19 2025, 04:46 PM
Ron914   I will try your suggestions later today and post t...   Aug 19 2025, 05:03 PM
emerygt350   I will try your suggestions later today and post ...   Aug 19 2025, 05:20 PM
Ron914   I will try your suggestions later today and post...   Aug 19 2025, 05:30 PM
Superhawk996   I will try your suggestions later today and post ...   Aug 19 2025, 07:50 PM
Ron914   @Superhawk996 I made the checks you requested and...   Aug 19 2025, 10:39 PM
ctc911ctc   Audio engineers Fluke! [b]@[url=http://www....   Aug 20 2025, 09:52 AM
Superhawk996   Good job and report out on the testing Ron. :head...   Aug 19 2025, 11:33 PM
Ron914   Good job and report out on the testing Ron. :hea...   Aug 20 2025, 08:12 AM
Ron914   I made the tool needed to remove my CHT and I noti...   Aug 25 2025, 12:30 PM
Ron914   I decided to verify the condition of the CHT wire ...   Aug 25 2025, 12:46 PM
Superhawk996   Flukes rarely go bad New leads are much cheaper ...   Aug 25 2025, 12:59 PM
ctc911ctc   Flukes rarely go bad ^^^^^^^^^^^^^^^^ :agree:...   Aug 25 2025, 01:27 PM
Ron914   Yes the car is still stalling after 5-10 minutes o...   Aug 25 2025, 01:44 PM
Superhawk996   Yes the car is still stalling after 5-10 minutes ...   Aug 25 2025, 03:54 PM
Ron914   Yes the car is still stalling after 5-10 minutes...   Aug 25 2025, 05:39 PM
emerygt350   Your not at a higher altitude are you? 16 isnt en...   Aug 25 2025, 02:04 PM
Ron914   Your not at a higher altitude are you? 16 isnt e...   Aug 25 2025, 02:32 PM
emerygt350   At the least you can resell it. Just remember, th...   Aug 25 2025, 03:22 PM
cgnj   I'm curious where these diaphragms are being s...   Aug 25 2025, 03:29 PM
emerygt350   Go for it! I love a carb too but this is like ...   Aug 25 2025, 03:44 PM
Superhawk996   Ah - OK so you have a good wire from sensor to ECU...   Aug 25 2025, 07:03 PM
emerygt350   I always do a visual before hand as well. Mps vac...   Aug 26 2025, 05:37 AM
Puebloswatcop   Where can I obtain a MPS re-build kit with a new d...   Aug 26 2025, 06:46 AM
FlacaProductions   Unless someone is going to sell you from their sta...   Aug 26 2025, 07:17 AM
Ron914   Getting back to my D-Jet issue , walking away is w...   Sep 8 2025, 12:05 PM
rjames   I'm confused (happens often). On August 19th y...   Sep 8 2025, 12:38 PM
Ron914   I'm confused (happens often). On August 19th ...   Sep 8 2025, 03:00 PM
emerygt350   A 2 psi drop would lean the mix quite a bit. That...   Sep 8 2025, 02:21 PM
- Lo-Fi Version Time is now: 3rd October 2026 - 09:46 PM
