> Fog light wiring, Are these the right ones?
Chad911sc
post May 17 2025, 12:49 PM
Spent the last week refinishing the ground effects and the bumpers. Next step is to put fog lights back into the factory spot. I have the new 914 Rubber fog lights grilles and led lights to fit, but need to know if these are the right wires. And also if they are, how are they operated? Not sure if this car came with them from the factory, the car already had aftermarket plastic grilles in it and they were cracked and broken. My interior only has one light switch that is a pull switch that activates the headlights. I put my volt meter on the brown ground and the white/yellow positive, and no voltage going to them when light switch is pulled out. Are these the factory wires, or something else?
Chad911sc
post May 18 2025, 08:04 PM
Well that makes it a bit easier. Just order a factory switch that has all the needed relays built into it. That looks much better than an aftermarket switch. I’ll look online and see what they have to offer.
Shivers
post May 19 2025, 04:53 AM
QUOTE(Chad911sc @ May 18 2025, 07:04 PM) *
This is just a switch leg. No relay. I swear all I had to do is install the lights and plug the switch into the stock wiring for the fog lights that is under the dash. I did not need to mess with the relay that is already in place. Plug and play. I put in a console…Plug and play…Added a second horn…wait for it…Plug and play.
- Lo-Fi Version Time is now: 14th July 2025 - 08:04 PM
