| jesse7flying |
Apr 28 2025, 06:03 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None
As I go through the somewhat butchered wiring harness on my new to me '73 2.0L, I've run across a green with white stripe wire which has been lengthened with some butt connectors running along the center of the car. It looks like the wire is connected to the heater control lever. Can someone explain what this does? The only green/white wire I find referenced in the Prospero Garage drawing goes from the heater fan switch to pin 9 regulator plate in the engine compartment. Thx for the help.
Jesse |
| ThinAir |
May 19 2025, 12:36 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
When I connected my fan to the connector in the engine bay, it started running regardless of the heater switch position. I ended running a separate wire with a switch that I can turn on when I want, but I've never been comfortable with this arrangement.
It seems that the wire must be grounded somewhere, but I'm wondering if it is just because of the way the heater lever is installed. Is it supposed to have any kind of insulation or a way to prevent the fan being grounded until the lever is all the way up? |
jesse7flying Heater control lever wire Apr 28 2025, 06:03 PM
Ron914
As I go through the somewhat butchered wiring har... Apr 28 2025, 07:25 PM
Ron914
As I go through the somewhat butchered wiring ha... Apr 28 2025, 07:33 PM
Ron914
[quote name='Ron914' post='3203216' date='Apr 28 ... Apr 28 2025, 07:47 PM
Ron914 looking at the diagram (Haynes doesn't make th... Apr 28 2025, 08:03 PM
Dave_Darling No, you've got it right.
This wire gets groun... Apr 28 2025, 11:55 PM
Ron914
This wire gets grou... Apr 29 2025, 01:23 PM
jim_hoyland Where on the Heat-lever does the wire attach ? May 16 2025, 08:58 PM
914sgofast2 It attaches to a male spade type connection on the... May 16 2025, 09:19 PM
jim_hoyland Thanks; I’ll have to look deeper :) May 17 2025, 08:39 AM
jim_hoyland How / where is the little square Defrost light att... May 19 2025, 04:07 PM
jim_hoyland How / where is the little square Defrost light att... May 19 2025, 04:08 PM
jim_hoyland How / where is the little square Defrost light att... May 19 2025, 04:12 PM
BillC
How / where is the little square Defrost light at... May 19 2025, 06:31 PM
jim_hoyland :) I see it, thanks… May 19 2025, 08:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 12:36 AM |
