hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
![]() The flappers Should be closed when the red lever on heater controls is all the way to drive side.... I had the air box out awhile ago and when I got ready to reinstall I (thought) that I set the rod underneath so that they closed and opened on both side at the same time. HA HA on me. One side closes and the other opens. HUMMMM no wonder I get blasted by heat no matter when the dang slider is. How to I adjust this with the cable? or that damn rod? that is a pic I grabbed from the interweb, Mine is in the car. Help Please feeling not so Hndyhrr right now. Thanks |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,273 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
The dash heater controls do not control whether or not you get heat. They only control where the heat comes out of; above the dash or at your feet.
To allow or block heat from entering the cab, you use the lever that's located on top of the center tunnel to open /close the heat flapper boxes. The boxes are located right behind each long on each corner of the rear firewall. |
Lo-Fi Version | Time is now: 4th June 2025 - 11:50 AM |
