ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
1970 916-6 all original
I rebuilt the Marelli distro, it was caked in grease and the shaft was sticking because of the shaft grease had turned into glue,,,,,,,typical stuff. Purchased the rebuild kit from one of our best vendors, and when I went to replace the springs I noticed that one was very different from within the kit. Sooooo, either the kit is wrong or the previous owner/mechanic/factory used a different spring formula. ![]() The ones on the left are the same, each are in good shape, the ones on the right are VERY different. My guess is that the advance curve is designed to be smoother through the arc of the engine RPMs, where one side of the two weights advances first and then the other. My concern is that the stiffer spring is really stiff, even on a log scale there is a long way between these two. Any ideas as to which is the correct one? (Yes I did triple check that I had ordered the correct kit.) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,353 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
It is the bigger spring on the right. Marelli distributors use two different springs. If they are the same, it alters the advance curve and will cause detonation due to too much advance at low rpms.
Make sure you check the top of the shaft where the advance weights push against the square plate. The plate gets worn, and a ridge will form that keeps the advance weights from returning fully to the closed position. That will give you an issue where the engine won't come back to idle until you drag the motor down with the clutch. I fought this for months before replacing the distributor with another that had no wear on the plate. |
Lo-Fi Version | Time is now: 23rd May 2025 - 12:31 AM |
