| slowrodent |
May 20 2025, 11:37 AM
Member ![]() ![]() Group: Members Posts: 249 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region
OK..I've read a bunch of semi-recent articles online regarding electric air conditioning kits in cars. One was a 911 that is employing a rather pricey euro-kit and the owner seemed pleased... Most articles focus on the large current draw and the overall (in)efficiency of the kits on the whole. Yet, I can't help but feel that the 914 (tiny car) is a perfect application for such a kit - particularly if your engine can push a larger alternator. (Mine is a v6 and would have no problem doing so).. Allows you to frunk-mount the compressor and simplify the overall install (yes, big gauge wires are required, but in my case at least.. no interior exists so no worries)
Plus relatively cheap kits are waaay-abundant. So thoughts, insights, experience? (IMG:style_emoticons/default/idea.gif) |
| VaccaRabite |
May 20 2025, 02:42 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,946 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
As long as your alternator can push the power, its a great option.
A stock alternator won't do it, and there is not a commercially available alternator that will push enough power for a T4 based 914. There are custom rewound units that will push enough power. I'm not up enough on /6 stuff to know about their alternators. Certainly any V8/Subaru/etc conversion will be able to have an alternator that could push enough power. Zach |
| Spoke |
May 21 2025, 08:47 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,438 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I'm not up enough on /6 stuff to know about their alternators. I have the 175A alternator on my 930 from the Classic Retrofit eAC system. After installing the alternator I noticed voltages below 12V at low idle. After some investigation it turns out the engine needs to be above 1k rpm for the alternator to produce adequate voltage. |
slowrodent Electric A/C anyone? May 20 2025, 11:37 AM
76-914 Keith @914Toy did it and loved it before he sold... May 20 2025, 11:44 AM
As long as your alternator can push the power, it... May 20 2025, 05:26 PM
VaccaRabite
I'm not up enough on /6 stuff to know about ... May 22 2025, 06:25 AM
ClayPerrine Mine is in process. I have the compressor kit, and... May 20 2025, 03:07 PM
Chris914n6 On a car the size of a 914 the compressor won... May 20 2025, 04:23 PM
On a car the size of a 914 the compressor won... May 20 2025, 05:30 PM
Montreal914 Regardless of cabin size, using a stock 3.2 altern... May 21 2025, 07:50 AM
ClayPerrine
[quote name='mepstein' post='3206454' date='May 2... May 21 2025, 08:06 AM
Chris914n6
[quote name='mepstein' post='3206454' date='May ... May 22 2025, 12:14 PM
[quote name='mepstein' post='3206454' date='May ... May 22 2025, 01:03 PM
Steve
[quote name='mepstein' post='3206454' date='May ... Aug 29 2025, 04:10 PM
Shivers Has anyone here had success swapping to a GM or ot... May 20 2025, 06:51 PM
ClayPerrine On Elwood (the original six) I have considered upg... May 20 2025, 08:40 PM
Shivers
On Elwood (the original six) I have considered up... May 20 2025, 09:48 PM
burton73
On Elwood (the original six) I have considered up... May 21 2025, 12:16 PM
Superhawk996 Problem solved May 20 2025, 10:04 PM
mate914
Problem solved
That's pet mode. I like it. ... May 21 2025, 06:02 AM
Montreal914 @Steve :popcorn: May 20 2025, 11:11 PM
Shivers @Superhawk996
That’s funny Phil :D
12V 4400... May 21 2025, 08:12 AM
Jack Standz
Has anyone here had success swapping to a GM or o... May 21 2025, 08:44 AM
Shivers
Has anyone here had success swapping to a GM or ... May 21 2025, 08:53 AM
Steve I would use a standard modern compressor on a wate... May 21 2025, 10:44 AM
mepstein Paint it black and it will look like a small cargo... May 21 2025, 01:51 PM
Shivers It’s a Gurney Bubble to fit my fat head. That’... May 21 2025, 02:05 PM
Highland Could one use a battery to power the compressor an... May 21 2025, 06:12 PM
Could one use a battery to power the compressor a... May 21 2025, 06:47 PM
Root_Werks
Could one use a battery to power the compressor ... May 22 2025, 10:27 AM
Highland
[quote name='mepstein' post='3206620' date='May 2... May 22 2025, 12:35 PM
Root_Werks
[quote name='mepstein' post='3206620' date='May ... May 22 2025, 01:05 PM
Superhawk996
So maybe I'm showing my ignorance, but a 60... May 30 2025, 07:19 AM
Chris914n6 It's a typical hybrid. So there is the tractio... May 22 2025, 05:45 PM
Superhawk996
It's a typical hybrid. So there is the tracti... May 30 2025, 07:21 AM
Steve I did some more testing at 70 degrees in the garag... May 29 2025, 09:52 PM
mate914 Hi
Can I see a pic of the under dash evaporator in... May 30 2025, 05:38 AM
JmuRiz
Hi
Can I see a pic of the under dash evaporator i... May 30 2025, 10:13 AM
Steve
Hi
Can I see a pic of the under dash evaporator i... May 30 2025, 10:33 AM
Steve This looks like my compressor on Amazon. https://... May 29 2025, 10:26 PM
nditiz1 Adding some facts into this thread.
The CR AC wil... May 30 2025, 05:38 AM
Steve
The CR AC wi... May 30 2025, 11:03 AM
nditiz1 Steve, I didn't know you built a setup. That ... May 30 2025, 03:17 PM
Steve, I didn't know you built a setup. That... May 30 2025, 05:00 PM
mepstein @Steve
Steve - Where are you mounting the condens... Aug 28 2025, 08:07 PM
Steve
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 28 2025, 11:05 PM
Steve
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 29 2025, 09:56 AM
[b]@[url=http://www.914world.com/bbs2/index.php?... Aug 29 2025, 10:04 AM
Steve
[quote name='Steve' post='3221744' date='Aug 29 2... Aug 29 2025, 11:11 AM
Steve
[quote name='Steve' post='3221744' date='Aug 29 2... Sep 3 2025, 04:15 PM
[quote name='Steve' post='3221744' date='Aug 29 ... Sep 3 2025, 04:31 PM
Steve The only issue I am dealing with now is I used a 4... Aug 29 2025, 09:44 AM
Dave_Darling
... I used a 4 gauge crappy non copper Amazon Chi... Aug 31 2025, 11:50 PM
Steve
... I used a 4 gauge crappy non copper Amazon Ch... Sep 1 2025, 09:52 AM
mepstein I bought a CR unit to put in my 914-6. The evapora... Aug 29 2025, 11:21 AM
mepstein When the units first came out ten years ago, I wor... Aug 29 2025, 05:24 PM
Steve
When the units first came out ten years ago, I wo... Aug 29 2025, 08:05 PM
914sgofast2 Why not just add a deep cycle battery in the rear ... Aug 30 2025, 12:08 AM
Steve
Why not just add a deep cycle battery in the rear... Aug 30 2025, 07:10 AM
Steve Nice to know a USA electric compressor is now avai... Aug 31 2025, 07:37 PM
Steve I was recently looking at the Southern Rods web si... Nov 22 2026, 11:53 AM
mepstein Steve - I thought you had the Griffiths condenser ... Nov 22 2026, 12:07 PM
Steve
Steve - I thought you had the Griffiths condenser... Nov 22 2026, 12:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 12:25 PM |
