> Interference with shift rod, Interference with shift rod
914racer
post May 22 2025, 02:19 PM
I converted a 4 to 6 in a 71. I also have a short shifter and the necessary spacer installed. The shift rod in the tunnel is scraping a gusset and causing a loud squeaking when put in reverse or 1st and slightly less squeak sound going into 4th and 5th. I have a video taken in the tunnel showing how it's interfering with the shift rod. Has anyone else had this issue and have a solution other than drilling a hole with a hole saw on the top of the tunnel and grinding some of the gusset for clearance? Thanks
rudedude
post May 23 2025, 09:56 AM
All I had to do was loosen the shifter base and move it a tiny bit. It is probably rubbing on a sheet metal support in the tunnel.
- Lo-Fi Version Time is now: 25th May 2025 - 09:34 AM
