> Turn signal indicator lights come on with key
GeorgeKopf
post May 26 2025, 04:25 PM
I'm wring my 1973 wiring harness and have a bunch of things installed which seem to be working correctly (i.e. headlights (high & low beam), headlight motors, turn signals, running lights, tail lights)
But (IMG:style_emoticons/default/bootyshake.gif) the turn signal indicators are always on!
I've traced the flow of current from the fuse panel (red with white stripe) to the hazard switch, from there (red) to the relay and from there to the turn signal indicators (blue with white stripe).
47 is the relay
31 is the hazard switch
22 is the turn signal lights
26 is the steering column switch
I have two relays and both seem to work fine. When I pull out the hazard switch the indicators and lights all blink. When I set the turn signal that side blinks.
I have two hazard switches and both behave the same way. As soon as I connect the red and red/white wires the turn signal indicators come on.
With the knob pushed in, I have continuity between the red/white (power in) and the red (power out to the relay).
With the knob pulled out, I have continuity between the black/red (power in) and the red (power out to the relay). (IMG:style_emoticons/default/confused24.gif)
More information:
I have cleaned all grounding studs.
I disassembled one of the relays and cleaned it.
If I disconnect all of the wires from the hazard switch except for the red/white and the red, the signal indicators come on and stay on. Doesn't this mean that my relay is bad? It should be getting power so that it can feed the turn signal indicators when the turn signals are set.
It seems that the relay is allowing the input power to the blue/white wires when it shouldn't.
If so, is there a good way to test or repair them?
Thanks in advance for any advice.
George
GeorgeKopf
post May 29 2025, 07:47 AM
@Spoke
Do you open up a stock EP26 and modify it to connect the C pin to ground?
Thanks
George
Spoke
post May 29 2025, 08:24 AM
Jerry
QUOTE(GeorgeKopf @ May 29 2025, 09:47 AM) *
@Spoke
Thanks
George
Yes. I show how to make the mod on my website if you want to do the mod yourself.
GeorgeKopf
post May 29 2025, 09:52 AM
QUOTE(Spoke @ May 29 2025, 08:24 AM) *
First of all, you are the man! Thank you for being so generous with your time and expertise.
Second, I'll buy one of your LED relays. Would you prefer that I do it through your website?
Thanks.
George
Spoke
post May 29 2025, 08:00 PM
Jerry
QUOTE(GeorgeKopf @ May 29 2025, 11:52 AM) *
Thanks.
George
Yes. The website is the easiest way.
GeorgeKopf   Turn signal indicator lights come on with key   May 26 2025, 04:25 PM
904svo   jUST A wag check that the brown wire is connect to...   May 26 2025, 05:21 PM
Superhawk996   Simplified wiring diagram from Spoke Take note...   May 27 2025, 05:26 AM
Superhawk996   If I disconnect all of the wires from the hazard...   May 27 2025, 05:29 AM
rfinegan   ON or blinking? My problems have allows been a bad...   May 27 2025, 05:51 AM
Superhawk996   See diode in the flasher circuit. ?? There is...   May 27 2025, 06:00 AM
rfinegan   My bad, not a diode but replacement did fix my lig...   May 27 2025, 08:55 AM
GeorgeKopf   @Superhawk996 Thanks for the simplified diagram. ...   May 27 2025, 07:11 PM
Superhawk996   If you’ve already tried 2 flasher relays, and it...   May 27 2025, 10:33 PM
GeorgeKopf   @Superhawk996 I was thinking how I might bench t...   May 28 2025, 08:46 AM
Superhawk996   Do you know which connector on the unit represen...   May 28 2025, 09:34 AM
Spoke   But :bootyshake: the turn signal indicators are a...   May 28 2025, 09:17 AM
GeorgeKopf   @Spoke If I remove the flasher relay, the indica...   May 28 2025, 09:40 AM
Spoke   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 28 2025, 02:43 PM
rfinegan   I did use a LED ready hazard flasher, so when I up...   May 28 2025, 11:32 AM
GeorgeKopf   @rfinegan This is very good information. I...   May 28 2025, 11:51 AM
GeorgeKopf   @Spoke You said: "An easy workaround which...   May 28 2025, 07:15 PM
Superhawk996   Between 49 and C:......resistance is 850 ohms......   May 29 2025, 02:42 AM
Spoke   My flasher relay is only labeled: ....49 49a.......   May 29 2025, 07:30 AM
GeorgeKopf   @Spoke Do you open up a stock EP26 and modify it...   May 29 2025, 07:47 AM
Spoke   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 29 2025, 08:24 AM
GeorgeKopf   Yes. I show how to make the mod on my website if ...   May 29 2025, 09:52 AM
Spoke   Yes. I show how to make the mod on my website if...   May 29 2025, 08:00 PM
GeorgeKopf   I'll buy one of your LED relays. I installe...   Jun 8 2025, 07:37 PM
GeorgeKopf   Before I start a new thread ..... <edit> I...   May 31 2025, 04:34 PM
GeorgeKopf   @Spokes <edit> I just found the answer on...   May 31 2025, 07:09 PM
Spoke   @Spokes <edit> I just found the answer o...   May 31 2025, 09:05 PM
BillC   [quote name='GeorgeKopf' post='3208274' date='May...   Jun 2 2025, 07:09 PM
Superhawk996   :trophy: Good job doing the basic troubleshootin...   Jun 9 2025, 07:52 PM
- Lo-Fi Version Time is now: 28th July 2026 - 12:57 AM
