> What's the trick for installing targa seal
morehills
post May 27 2025, 03:08 PM
OK, I'm stumped. Videos show that you can pull the seal down the channel, or work it in by levering one edge over the channel, but I can't make either method work. I can pull the seal about halfway before it stops. Seal is just too stiff to lever it in from one side.
There must be an easier way. Using WD40 and silicon spray for lube. Any advice? Thanks, John
JeffBowlsby
post May 30 2025, 03:14 PM
To make a too rigid rubber seal more pliable, try soaking it in suntan oil for a few days, and set it out in the sun for the same period.
Superhawk996
post May 31 2025, 05:07 AM
QUOTE(JeffBowlsby @ May 30 2025, 05:14 PM) *
Or the vendors could just make them to the proper dimensions and out of the proper durometer rubber. Crazy idea I know. (IMG:style_emoticons/default/happy11.gif)
note: in defense of the vendors - to make the part to exact OE specs could end up raising the part price to a level that the market won’t bear.
I’ve said this before but here goes:
I’m grateful for the vendor community we have. Often times it is better to have a poorly fitting part vs no part (NLA)
However, it is beyond frustrating to pay good money for a part that clearly doesn’t fit like OE and subsequently has to be modified just to work. Similarly, as was pointed out in this thread, many don’t understand that what they are buying and trying to install is in actuality, quite different than OE.
@Jeffbowlsby the suggestion to warm the parts is a great suggestion BTW. In the assembly plants certain rubber parts are often warmed to make them more pliable and easy to manipulate and install.
morehills   What's the trick for installing targa seal   May 27 2025, 03:08 PM
DC_neun_vierzehn   Just put new seals on my top a month or so ago (91...   May 27 2025, 03:56 PM
morehills   I often find myself at a dead end and wonder how t...   May 27 2025, 04:04 PM
Superhawk996   I often find myself at a dead end and wonder how ...   May 27 2025, 05:23 PM
scallyk9   I installed these 914rubber seals a few years ago ...   May 27 2025, 04:20 PM
jim_hoyland   It was a two man job that last time I did it :) ...   May 27 2025, 04:20 PM
Puebloswatcop   I would recommend using wire lube (Available at mo...   May 27 2025, 05:49 PM
TonyVan   Just did this a couple of weeks ago. Also used liq...   May 27 2025, 06:07 PM
Chad911sc   Just did this a few weeks ago…forget the push pu...   May 28 2025, 09:05 AM
DC_neun_vierzehn   Just did this a few weeks ago…forget the push p...   May 28 2025, 03:02 PM
Chad911sc   Working on this 914 project :lol4: Every car has ...   May 28 2025, 04:06 PM
Superhawk996   Each time I go to fix something, I uncover a rats...   May 28 2025, 05:24 PM
Chad911sc   I guess I got spoiled with the first Porsche I bou...   May 28 2025, 05:45 PM
bdstone914   @Chad911sc What the story with this one?   May 30 2025, 06:24 AM
Chad911sc   That was one of 3 different Opel GTs that I had. M...   May 30 2025, 01:05 PM
Chad911sc   If you look at the picture below that one, you can...   May 30 2025, 01:08 PM
JeffBowlsby   To make a too rigid rubber seal more pliable, try ...   May 30 2025, 03:14 PM
Superhawk996   To make a too rigid rubber seal more pliable, try...   May 31 2025, 05:07 AM
- Lo-Fi Version Time is now: 5th June 2025 - 08:23 PM
