> WEBER 40 - 914-6 or 911T Carbs, They seem to be the correct carbs but not stock?
ctc911ctc
post May 30 2025, 07:25 PM
1970 914-6 all stock
All,
I am down to the last thing for this engine re-fresh: CARBS
They seem to be in very good condition and since they are missing the Porsche factory mark I am guessing that they were 'cored' on a rebuild sometime prior to my ownership
OR
Are 914-6 carbs NOT market like 911 carbs are???????
Anyway, I have not gone too deep since they are in great shape - the gaskets seem good, the floats are the brass kind but in perfect shape, the bowls are very clean,,,,,,
Can I get some direction on:
1. what to look for in a recently rebuilt carb
2. where is a good reference for setup prior to installation
Any other opinions would be well received,
Thank you Teeners
YES I KNOW
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Pictures will be added later
Graydingo
post Jun 1 2025, 08:29 AM
QUOTE(ctc911ctc @ May 30 2025, 06:25 PM) *
1. general cleanliness, correct seals and washers, and of course if it runs right.
2. The defacto source for 3c knowledge when it comes to Porsche is on Performance Oriented (web site)
Familiarize your self with the best lean setup. You need to set up linkage correctly and go through all the other procedures like setting the float bowls and using the syncrometer to balance vacuum.
The car's timing, idle and carb setup are all related, if one is off, nothing runs right.
QUOTE(brant @ Jun 1 2025, 06:08 AM) *
I’m not aware of any aftermarket 3 barrel carbs made other than pmo version
As pictured above, the more rough version of the weber 3c body casting was made in the USA in the 90s by Carter which Weber purchased to try to enter the USA auto market. Recently there are Spanish version of Weber 3c as well. The early 911 Weber carbs are all made in Italy and it's stamped on the side.
Also "reedmoral by Lantech" is apparently a chinese knockoff of the weber 40 ida 3c"
ctc911ctc   WEBER 40 - 914-6 or 911T Carbs   May 30 2025, 07:25 PM
rick 918-S   :agree: :ttiwwp: :driving:   May 30 2025, 09:00 PM
euro911   See if you can find a copy of this factory Weber T...   May 30 2025, 09:28 PM
sixnotfour   What Porsche marking are you referring to ? they...   May 30 2025, 10:21 PM
porschetub   1970 914-6 all stock All, I am down to the last...   May 31 2025, 12:05 AM
930cabman   clean em up and run em   May 31 2025, 06:01 AM
rgalla9146   Cary When I worked on the car 25 years ago (...   May 31 2025, 08:42 AM
ctc911ctc   Cary When I worked on the car 25 years ago ...   May 31 2025, 04:32 PM
brant   I’m not aware of any aftermarket 3 barrel carbs ...   Jun 1 2025, 07:08 AM
Graydingo   1970 914-6 all stock Can I get some direction o...   Jun 1 2025, 08:29 AM
brant   Don’t forget to measure and adjust accel pumps a...   Jun 1 2025, 08:57 AM
914Sixer   China now making replacement carbs.   Jun 1 2025, 09:46 AM
73-914   China now making replacement carbs. :lol4: :ro...   Mar 12 2026, 11:25 AM
ctc911ctc   Here are the pictures I promised, first, here is t...   Jun 1 2025, 07:22 PM
ctc911ctc   ..................Continued................. Insi...   Jun 1 2025, 07:25 PM
sixnotfour   Not Even Italian.... Those are from PMO way back w...   Jun 1 2025, 07:41 PM
sixnotfour   :shades2:   Jun 1 2025, 08:19 PM
sixnotfour   :shades2:   Jun 1 2025, 08:20 PM
ctc911ctc   :shades2: Almost matching…………huh……....   Jun 1 2025, 08:24 PM
porschetub   :shades2: Almost matching…………huh……...   Jun 4 2025, 09:13 PM
mskala   I am not an expert but I remember hearing a lot of...   Jun 5 2025, 06:16 AM
brant   I don’t know what stoddard was doing Assume the...   Jun 5 2025, 06:33 AM
mate914   I had Paul Abbot(sp) convert a set of carbs to IDS...   Jun 5 2025, 09:20 AM
brant   I had Paul Abbot(sp) convert a set of carbs to ID...   Jun 5 2025, 09:32 AM
ctc911ctc   ****UPDATE**** Sooooo.......it would seem that on...   Jun 5 2025, 10:10 AM
rgalla9146   Those are replacement newer production carbs. ...   Jun 5 2025, 11:34 AM
mskala   You can borrow my float level gauge and I have som...   Jun 5 2025, 02:00 PM
Graydingo   Yeah those aren't PMO, Carter was making those...   Jun 5 2025, 03:51 PM
sixnotfour   Yeah those aren't PMO, Carter was making thos...   Jun 7 2025, 08:30 AM
DennisV   Are 914-6 carbs NOT market like 911 carbs are????...   Jun 5 2025, 04:37 PM
sixnotfour   "S" is Best..   Jun 12 2025, 06:48 AM
sixaddict   Just an FYI I have a set of original set of 914-6...   Jun 12 2025, 07:11 AM
sixnotfour   He has it handled Im just messin around...   Jun 12 2025, 07:20 AM
sixnotfour   :beer2:   Jun 12 2025, 08:23 AM
ctc911ctc   RE: WEBER 40 - 914-6 or 911T Carbs   Feb 15 2026, 02:47 PM
ctc911ctc   :bump:   Mar 10 2026, 07:35 PM
ctc911ctc   SORRRY - pictures are in the Preview but not in th...   Mar 11 2026, 04:06 PM
930cabman   One side very rich should provide a clue to what...   Mar 11 2026, 04:38 PM
ctc911ctc   Fixed the pictures within the last post - BUMP   Mar 12 2026, 07:02 AM
Superhawk996   www.914world.com/bbs2/index.php?showtopic=376092...   Mar 12 2026, 07:38 AM
930cabman   I'd go back to the basics and check everything   Mar 12 2026, 02:11 PM
rudedude   If you have had them all apart you shouid know wha...   Mar 12 2026, 05:36 PM
Superhawk996   If you have had them all apart you shouid know wh...   Mar 13 2026, 06:35 AM
gereed75   Just curious - does it seem to start/ run better w...   Mar 13 2026, 11:40 AM
930cabman   Just curious - does it seem to start/ run better ...   Mar 13 2026, 04:05 PM
sixnotfour   :blink:   Mar 13 2026, 10:56 PM
sixnotfour   back to square 2.. square 1 check that when #1 is ...   Mar 13 2026, 10:58 PM
- Lo-Fi Version Time is now: 22nd October 2026 - 09:18 PM
