Cfletch |
Member ![]() ![]() Group: Members Posts: 168 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California ![]() |
Hey there everyone, working on getting my 6 conversion going here and I was able to hook up a temp fuel system in place of my tank while I am waiting on a few parts. I wanted to get the car to idle with its new fuel pump (not yet regulated down to 3.5psi) rated at 5 PSI max. I wanted to get the carb bodies full of fuel and get some pressure into the system and as soon as the pump turned on with the ignition the carbs essentially started dumping fuel down my intakes. Almost as if there was an internal leak causing fuel to just enter their respective cylinders. I'm new to down draft webers so this confuses me. I popped the top off of one of the carbs and noticed the fuel level was extremely low in the bowls so it was not like the needle and seat were stuck or a float was stuck causing it to overfill. Kind of stumped here as these carbs are rebuilt. Really any suggestions are good here. the float level was set, the needle and seats are good and not sticking at all.
I read somewhere but not in much detail that the bowls are vented? I have these little plunger-esq things in each vent tube that I have not yet pulled out. Would that be the source of my problem? If the bowls couldn't vent its just pressurizing the changes and causing the fuel to just leak down into the engine? |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,205 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Hey there everyone, working on getting my 6 conversion going here and I was able to hook up a temp fuel system in place of my tank while I am waiting on a few parts. I wanted to get the car to idle with its new fuel pump (not yet regulated down to 3.5psi) rated at 5 PSI max. I wanted to get the carb bodies full of fuel and get some pressure into the system and as soon as the pump turned on with the ignition the carbs essentially started dumping fuel down my intakes. Almost as if there was an internal leak causing fuel to just enter their respective cylinders. I'm new to down draft webers so this confuses me. I popped the top off of one of the carbs and noticed the fuel level was extremely low in the bowls so it was not like the needle and seat were stuck or a float was stuck causing it to overfill. Kind of stumped here as these carbs are rebuilt. Really any suggestions are good here. the float level was set, the needle and seats are good and not sticking at all. I read somewhere but not in much detail that the bowls are vented? I have these little plunger-esq things in each vent tube that I have not yet pulled out. Would that be the source of my problem? If the bowls couldn't vent its just pressurizing the changes and causing the fuel to just leak down into the engine? Congrats with another /6 conversion I would start by lowering the fuel pressure. I have run 2 - 3 psi maximum on Webers for many many years and have never run low on fuel. In this case, less is better. On my recent /6 conversion I found a couple 40 IDT carbs, spent a bit of time learning/rebuilding them. There seems to be a certain mystique with the 3C Webers, but my experience has been straightforward. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,902 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Hey there everyone, working on getting my 6 conversion going here and I was able to hook up a temp fuel system in place of my tank while I am waiting on a few parts. I wanted to get the car to idle with its new fuel pump (not yet regulated down to 3.5psi) rated at 5 PSI max. I wanted to get the carb bodies full of fuel and get some pressure into the system and as soon as the pump turned on with the ignition the carbs essentially started dumping fuel down my intakes. Almost as if there was an internal leak causing fuel to just enter their respective cylinders. I'm new to down draft webers so this confuses me. I popped the top off of one of the carbs and noticed the fuel level was extremely low in the bowls so it was not like the needle and seat were stuck or a float was stuck causing it to overfill. Kind of stumped here as these carbs are rebuilt. Really any suggestions are good here. the float level was set, the needle and seats are good and not sticking at all. I read somewhere but not in much detail that the bowls are vented? I have these little plunger-esq things in each vent tube that I have not yet pulled out. Would that be the source of my problem? If the bowls couldn't vent its just pressurizing the changes and causing the fuel to just leak down into the engine? Congrats with another /6 conversion I would start by lowering the fuel pressure. I have run 2 - 3 psi maximum on Webers for many many years and have never run low on fuel. In this case, less is better. On my recent /6 conversion I found a couple 40 IDT carbs, spent a bit of time learning/rebuilding them. There seems to be a certain mystique with the 3C Webers, but my experience has been straightforward. (IMG:style_emoticons/default/agree.gif) I run around 3psi with Zeniths ,before I set pump pressure with my regulator I checked the float levels with the PMO gauge . What I found without the regulator screwed down just over 3.6 psi showed on the gauge and had fuel just starting to overflow ,regulated back and all was fine ,haven't changed it since then. IMO 5psi is too high and will overcome the float valves ,I used the Holley 1 to 4psi LP regulator part # 12-803 with a qualiy gauge ,so far no issues . |
Lo-Fi Version | Time is now: 8th August 2025 - 09:36 AM |
