> Stock oil cooler, Inlet/Outlet
Chad911sc
post Jun 4 2025, 11:40 AM
Which hole is the inlet for the stock oil cooler and which is the outlet. It flows up from the oil pump to one of the holes and into the stock oil cooler and then back into the engine. I need to know which one is which because my flow for my external oil cooler/fan combo is directionally dependent going through my oil thermostat. I was told it was outlet at the top and inlet on the bottom by the sales rep, but after looking closely at my case, it looks like the outlet is at the bottom.
I think the blue path is the outlet to the stock oil cooler, and the red path is the inlet back into the engine…is this correct??
BillC
post Jun 4 2025, 03:08 PM
Maybe you could get an air nozzle and try blowing into each hole, and see which one comes out the hole for the oil pressure relief valve -- pretty sure that would be the cooler inlet hole (if I remember the diagram correctly).
Chad911sc   Stock oil cooler   Jun 4 2025, 11:40 AM
DennisV   Which hole is the inlet for the stock oil cooler ...   Jun 4 2025, 12:01 PM
GregAmy   Just use one of these: https://tangerineracing.co...   Jun 4 2025, 01:58 PM
Chad911sc   I already have the full system built, just want to...   Jun 4 2025, 02:37 PM
BillC   Maybe you could get an air nozzle and try blowing ...   Jun 4 2025, 03:08 PM
Chad911sc   The engine is totally built and in the car with al...   Jun 4 2025, 03:14 PM
Superhawk996   I’m on the road and don’t have access to a cas...   Jun 4 2025, 07:20 PM
Chad911sc   Thanks for all your input, it is much appreciated....   Jun 4 2025, 08:01 PM
Superhawk996   One more caveat: you need to block off the OE oil...   Jun 4 2025, 08:11 PM
Chad911sc   I did do that when installing the fan housing. I p...   Jun 5 2025, 05:32 AM
Superhawk996   I did do that when installing the fan housing. I ...   Jun 5 2025, 06:08 AM
mate914   Blow through it. Matt Which hole is the inlet f...   Jun 5 2025, 06:07 AM
Chad911sc   Didn’t realize that…I’ll have to make some m...   Jun 5 2025, 06:18 AM
Superhawk996   Didn’t realize that…I’ll have to make some ...   Jun 5 2025, 06:41 AM
Chad911sc   Yeah the thermostat was missing from the system wh...   Jun 5 2025, 06:49 AM
Superhawk996   Head temp thread http://www.914world.com/specs/J...   Jun 5 2025, 07:09 PM
Chad911sc   The things I do for my car….nothing like some fr...   Jun 6 2025, 11:43 AM
Superhawk996   :beer2: :first: Way better   Jun 6 2025, 12:17 PM
Chad911sc   Thanks again for your guidance… My friend Scott ...   Jun 6 2025, 02:34 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:15 PM
