| Chad911sc |
Jun 4 2025, 11:40 AM
Member ![]() ![]() Group: Members Posts: 293 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
Which hole is the inlet for the stock oil cooler and which is the outlet. It flows up from the oil pump to one of the holes and into the stock oil cooler and then back into the engine. I need to know which one is which because my flow for my external oil cooler/fan combo is directionally dependent going through my oil thermostat. I was told it was outlet at the top and inlet on the bottom by the sales rep, but after looking closely at my case, it looks like the outlet is at the bottom.
I think the blue path is the outlet to the stock oil cooler, and the red path is the inlet back into the engine…is this correct?? Attached thumbnail(s) |
| Chad911sc |
Jun 4 2025, 08:01 PM
Thanks for all your input, it is much appreciated. Your diagram is correct as I pulled off the hoses and the upper hole is the output from the oil pump path and the lower hole is the return back into the case.
You could be correct on your theory of the aftermarket external cooler compared to the factory cooler. I was just trying to fight the Florida heat ahead of time knowing how brutally hot and humid it is down here. I planned on placing a fresh air intake on the side of the passenger lower valance with a 3 inch hose to bring a cool supply of air into the cooler. Sometimes when you try to improve on a design, it ends up not working, but I’m hoping for the best. Thanks again for all your time and input, it has been much appreciated. |
Chad911sc Stock oil cooler Jun 4 2025, 11:40 AM
DennisV
Which hole is the inlet for the stock oil cooler ... Jun 4 2025, 12:01 PM
GregAmy Just use one of these:
https://tangerineracing.co... Jun 4 2025, 01:58 PM
Chad911sc I already have the full system built, just want to... Jun 4 2025, 02:37 PM
BillC Maybe you could get an air nozzle and try blowing ... Jun 4 2025, 03:08 PM
Chad911sc The engine is totally built and in the car with al... Jun 4 2025, 03:14 PM
Superhawk996 I’m on the road and don’t have access to a cas... Jun 4 2025, 07:20 PM
Superhawk996 One more caveat: you need to block off the OE oil... Jun 4 2025, 08:11 PM
Chad911sc I did do that when installing the fan housing. I p... Jun 5 2025, 05:32 AM
Superhawk996
I did do that when installing the fan housing. I ... Jun 5 2025, 06:08 AM
mate914 Blow through it.
Matt
Which hole is the inlet f... Jun 5 2025, 06:07 AM
Chad911sc Didn’t realize that…I’ll have to make some m... Jun 5 2025, 06:18 AM
Superhawk996
Didn’t realize that…I’ll have to make some ... Jun 5 2025, 06:41 AM
Chad911sc Yeah the thermostat was missing from the system wh... Jun 5 2025, 06:49 AM
Superhawk996 Head temp thread
http://www.914world.com/specs/J... Jun 5 2025, 07:09 PM
Chad911sc The things I do for my car….nothing like some fr... Jun 6 2025, 11:43 AM
Superhawk996 :beer2: :first: Way better Jun 6 2025, 12:17 PM
Chad911sc Thanks again for your guidance… My friend Scott ... Jun 6 2025, 02:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:47 PM |
