| BillC |
Jun 2 2025, 06:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 745 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
The old thread asking this question got too long and disjointed, so I figured it would be best to start again with all the data stated concisely and in one post.
--------------------------------------------------------------------------------------------- The problem: I can't get my car to idle reliably under 1500-1600 RPM. If I adjust the idle bleed screw to lower the RPM, the engine will slow down and stall. The car:
| emerygt350 |
Jun 4 2025, 01:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,695 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Well, apparently a micro squirt is on the way so that should fix it if that is the problem.
| BillC |
Jun 4 2025, 03:00 PM
If it were me, I'd verify the above items, and the items Hawk listed, before swapping out the FI for carbs for testing or tearing down the engine. Not going to install carbs. That was just George's suggestion for testing to confirm the bad cam -- he said if it idled well with carbs but not D-Jet, it has to be the cam. George apparently does not like carbs and made more than a few comments about them. His primary suggestion is to rebuild the engine with the correct cam. Well, apparently a micro squirt is on the way so that should fix it if that is the problem. It's looking that way. The choices appear to boil down to either go MS or do a full rebuild. Engine drives too nicely to want to tear it down, so I'm just waiting on @JamesM to call me back with news. |
| JamesM |
Jun 4 2025, 08:06 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,286 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Engine drives too nicely to want to tear it down, so I'm just waiting on @JamesM to call me back with news. Getting closer, just have more people needing work done on old Porsches than I have time, space, and qualified manpower to keep up with at the moment. I have a system I need to build for one of our 2.3s that is waiting on it to go out the door, then I can start working on putting one together to build the d-jet maps. It sounds like your motor will most likely need some custom tuning but a base map from a stock motor should cover the basics and get you started. |
BillC Idle adjustment question, take two Jun 2 2025, 06:52 PM
BillC Anyone?
I think I answered all the questions and ... Jun 3 2025, 05:09 PM
Superhawk996 OK - I’ll copy and paste unanswered questions fr... Jun 3 2025, 05:50 PM
BillC
If I were you, I’d be going back and questionin... Jun 3 2025, 08:17 PM
Superhawk996
Yes, and I have no idea why. I wouldn't hav... Jun 4 2025, 12:45 AM
jcd914 It sounds like you may have this figured but I had... Jun 4 2025, 10:14 PM
Superhawk996 I’ll also repost this:
The thing is even some ... Jun 3 2025, 06:41 PM
BillC I called Dr. 914, George H., this afternoon, which... Jun 4 2025, 12:38 PM
JamesM
He strongly recommended that I plan on rebuildin... Jun 4 2025, 08:30 PM
rjames
Even if mixture is too rich, the car could still... Jun 4 2025, 01:38 PM
flxzcat I don't know anything about D-jet and as usual... Jun 4 2025, 05:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th August 2026 - 06:25 PM |
