> WEBER 40 - 914-6 or 911T Carbs, They seem to be the correct carbs but not stock?
ctc911ctc
post May 30 2025, 07:25 PM
1970 914-6 all stock
All,
I am down to the last thing for this engine re-fresh: CARBS
They seem to be in very good condition and since they are missing the Porsche factory mark I am guessing that they were 'cored' on a rebuild sometime prior to my ownership
OR
Are 914-6 carbs NOT market like 911 carbs are???????
Anyway, I have not gone too deep since they are in great shape - the gaskets seem good, the floats are the brass kind but in perfect shape, the bowls are very clean,,,,,,
Can I get some direction on:
1. what to look for in a recently rebuilt carb
2. where is a good reference for setup prior to installation
Any other opinions would be well received,
Thank you Teeners
YES I KNOW
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Pictures will be added later
sixnotfour
post Jun 1 2025, 08:20 PM
ctc911ctc
post Jun 1 2025, 08:24 PM
QUOTE(sixnotfour @ Jun 1 2025, 08:20 PM) *
Almost matching…………huh……..are they off of the same car?
porschetub
post Jun 4 2025, 09:13 PM
QUOTE(ctc911ctc @ Jun 2 2025, 02:24 PM) *
Wonder if they are "S" spec carbs ?? ,reason being with a stock motor it wouldn't be even half decent with 32mm vents ,if the jetting collates to the vents I would say the engine has uprated cams and 2.2 B&Ps atleast ,just saying ok.
For example, I fitted 32mm vents to my 2.2 T, it certainly wasn't a happy combo and reduced to 30mm and that's the way it is today with minor changes to jets .
This was a common conversion way back as the stock motor was somewhat lacking in power ,Stoddard did heaps of these upgrades for a while.
See how you go ,cheers.
ctc911ctc   WEBER 40 - 914-6 or 911T Carbs   May 30 2025, 07:25 PM
rick 918-S   :agree: :ttiwwp: :driving:   May 30 2025, 09:00 PM
euro911   See if you can find a copy of this factory Weber T...   May 30 2025, 09:28 PM
sixnotfour   What Porsche marking are you referring to ? they...   May 30 2025, 10:21 PM
porschetub   1970 914-6 all stock All, I am down to the last...   May 31 2025, 12:05 AM
930cabman   clean em up and run em   May 31 2025, 06:01 AM
rgalla9146   Cary When I worked on the car 25 years ago (...   May 31 2025, 08:42 AM
ctc911ctc   Cary When I worked on the car 25 years ago ...   May 31 2025, 04:32 PM
brant   I’m not aware of any aftermarket 3 barrel carbs ...   Jun 1 2025, 07:08 AM
Graydingo   1970 914-6 all stock Can I get some direction o...   Jun 1 2025, 08:29 AM
brant   Don’t forget to measure and adjust accel pumps a...   Jun 1 2025, 08:57 AM
914Sixer   China now making replacement carbs.   Jun 1 2025, 09:46 AM
73-914   China now making replacement carbs. :lol4: :ro...   Mar 12 2026, 11:25 AM
ctc911ctc   Here are the pictures I promised, first, here is t...   Jun 1 2025, 07:22 PM
ctc911ctc   ..................Continued................. Insi...   Jun 1 2025, 07:25 PM
sixnotfour   Not Even Italian.... Those are from PMO way back w...   Jun 1 2025, 07:41 PM
sixnotfour   :shades2:   Jun 1 2025, 08:19 PM
sixnotfour   :shades2:   Jun 1 2025, 08:20 PM
ctc911ctc   :shades2: Almost matching…………huh……....   Jun 1 2025, 08:24 PM
porschetub   :shades2: Almost matching…………huh……...   Jun 4 2025, 09:13 PM
mskala   I am not an expert but I remember hearing a lot of...   Jun 5 2025, 06:16 AM
brant   I don’t know what stoddard was doing Assume the...   Jun 5 2025, 06:33 AM
mate914   I had Paul Abbot(sp) convert a set of carbs to IDS...   Jun 5 2025, 09:20 AM
brant   I had Paul Abbot(sp) convert a set of carbs to ID...   Jun 5 2025, 09:32 AM
ctc911ctc   ****UPDATE**** Sooooo.......it would seem that on...   Jun 5 2025, 10:10 AM
rgalla9146   Those are replacement newer production carbs. ...   Jun 5 2025, 11:34 AM
mskala   You can borrow my float level gauge and I have som...   Jun 5 2025, 02:00 PM
Graydingo   Yeah those aren't PMO, Carter was making those...   Jun 5 2025, 03:51 PM
sixnotfour   Yeah those aren't PMO, Carter was making thos...   Jun 7 2025, 08:30 AM
DennisV   Are 914-6 carbs NOT market like 911 carbs are????...   Jun 5 2025, 04:37 PM
sixnotfour   "S" is Best..   Jun 12 2025, 06:48 AM
sixaddict   Just an FYI I have a set of original set of 914-6...   Jun 12 2025, 07:11 AM
sixnotfour   He has it handled Im just messin around...   Jun 12 2025, 07:20 AM
sixnotfour   :beer2:   Jun 12 2025, 08:23 AM
ctc911ctc   RE: WEBER 40 - 914-6 or 911T Carbs   Feb 15 2026, 02:47 PM
ctc911ctc   :bump:   Mar 10 2026, 07:35 PM
ctc911ctc   SORRRY - pictures are in the Preview but not in th...   Mar 11 2026, 04:06 PM
930cabman   One side very rich should provide a clue to what...   Mar 11 2026, 04:38 PM
ctc911ctc   Fixed the pictures within the last post - BUMP   Mar 12 2026, 07:02 AM
Superhawk996   www.914world.com/bbs2/index.php?showtopic=376092...   Mar 12 2026, 07:38 AM
930cabman   I'd go back to the basics and check everything   Mar 12 2026, 02:11 PM
rudedude   If you have had them all apart you shouid know wha...   Mar 12 2026, 05:36 PM
Superhawk996   If you have had them all apart you shouid know wh...   Mar 13 2026, 06:35 AM
gereed75   Just curious - does it seem to start/ run better w...   Mar 13 2026, 11:40 AM
930cabman   Just curious - does it seem to start/ run better ...   Mar 13 2026, 04:05 PM
sixnotfour   :blink:   Mar 13 2026, 10:56 PM
sixnotfour   back to square 2.. square 1 check that when #1 is ...   Mar 13 2026, 10:58 PM
- Lo-Fi Version Time is now: 22nd October 2026 - 09:18 PM
