gtbarnes |
Newbie ![]() Group: Members Posts: 35 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States ![]() |
These are from my daily drivers(weekender). They are not cores, they are very nice. I have uo to 3 years use on them. Time for 1-2 blocker rings /seals on both. They both will shift without grind if you go sloooowly with the shift. A normal shift to 2nd will give that annoying little 'kick' feeling to your hand but no grind. No abuse and both have been on 4cyl engs. One of these will go back into a driver and the other one I'd like to sell. Shipping should be no problem with me. I will have pics of both of them apart(gasket thickness, fork wear, bearing surfaces...nos....You can choose either one. new rings should bring them to excellent, we will see how they look inside,.
Oh , I will not be removing the diff plate, there is absolutely no reason to do that, if one needed that I woulld question the whole thing.Bearings are fine and the seals were not leaking. The green one has the threaded boss for throttle ![]() ![]() ![]() |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,296 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
Is that spray paint over the front and back or something easily removable? Kinda strange to paint them in such a way. Suggest you remove prior to sale.
gtbarnes |
Is that spray paint over the front and back or something easily removable? Kinda strange to paint them in such a way. Suggest you remove prior to sale. Yes its showing that the parts dont get swapped/ mixed between the 2. I have 3 apart after that pic.(imagine if someone put the green(pinion)shaft into the 'red' case(ring gear) Thats not going to happen |
Lo-Fi Version | Time is now: 16th June 2025 - 05:16 AM |
