> 914World Classifieds Rules
> Fresh side shift Trans, Doing 4 - here is 2 of them
gtbarnes
post Jun 1 2025, 07:41 PM
These are from my daily drivers(weekender). They are not cores, they are very nice. I have uo to 3 years use on them. Time for 1-2 blocker rings /seals on both. They both will shift without grind if you go sloooowly with the shift. A normal shift to 2nd will give that annoying little 'kick' feeling to your hand but no grind. No abuse and both have been on 4cyl engs. One of these will go back into a driver and the other one I'd like to sell. Shipping should be no problem with me. I will have pics of both of them apart(gasket thickness, fork wear, bearing surfaces...nos....You can choose either one. new rings should bring them to excellent, we will see how they look inside,.
Oh , I will not be removing the diff plate, there is absolutely no reason to do that, if one needed that I woulld question the whole thing.Bearings are fine and the seals were not leaking. The green one has the threaded boss for throttleAttached Image Attached Image Attached Image
BillJ
post Jun 5 2025, 07:36 AM
Is that spray paint over the front and back or something easily removable? Kinda strange to paint them in such a way. Suggest you remove prior to sale.
gtbarnes
post Jun 5 2025, 10:51 AM
QUOTE(BillJ @ Jun 5 2025, 05:36 AM) *
Yes its showing that the parts dont get swapped/ mixed between the 2. I have 3 apart after that pic.(imagine if someone put the green(pinion)shaft into the 'red' case(ring gear) Thats not going to happen
gtbarnes
post Jun 5 2025, 11:09 AM
QUOTE(gtbarnes @ Jun 5 2025, 08:51 AM) *
LOL, I guess that was confusing! The original post was this...
"I am doing 1-2 blocker rings and seals on my 2 drivers. I have a 3rd trans from another I owned and am planning to do that one as well. I have one more to keep for backup. So if anyone wants one with new blocker rings/seals I can part with one. I have driven all 3 a lot and they only have slightly weak 1-2 rings and slight seal leaks. new blocker rings are amazing for improved shifting. I could do a 3rd grear ring if u want. Just make me an offer.
Basicaly..I am 'freshening up' my transmissions, all of them, at once, and I will have an extra if anybody needs it.
- Lo-Fi Version Time is now: 16th June 2025 - 04:57 AM
