| 914xr75 |
Jun 4 2025, 08:56 PM
Member ![]() ![]() Group: Members Posts: 232 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
I posted a few weeks ago about leaking reservoir tubes under the gas tank. I replaced those and the leaking stopped. I bled the calipers, but did not bleed the master cylinder. This was the first time I had about 5% stopping power and the pedal went to the floor, not sure if you'd call it spongy, but there was no resistance. That was a couple weeks ago.
Today I replaced the master with a 17mm ATE, rebuilt one of the front calipers, replaced the front soft lines. The rear steel lines still looked good, so I left them. I bled the new master. It took about an hour of pushing out air bubbles, and two quarts of brake fluid into the system to complete the MC bleeding. Once done, the pedal was still pillow soft. Now on to the caliper bleeding--I purchased the Motive pressure bleeding system. Pumped it up to 5 psi as recommended by Ian Karr. About 30 seconds later the Motive bottle was at 0 psi. There aren't any fluid leaks in the brake system. I replaced the reservoir seal and added Teflon tape to the fitting in the Motive hose. Still loses pressure. I tried the HF bleeder you hook up to your compressor. For 3 minutes about 5% fluid and 95% air entered the bottle. About 8 ounces of fluid came out. That is where I left off after a full day of brake work. Then I thought, did I cross the reservoir lines? I don't believe I did that, and I don't think that would cause my situation. Any help you can offer would be greatly appreciated. Sean |
| 914xr75 |
Jun 6 2025, 10:10 AM
Update------defective brand new Motive Power Bleeder!!! Last night I couldn't understand how the Motive system was telling me I had a leak. I had rock solid pedal pressure after my second bleed.
I checked everywhere--near pedal cluster, under gas tank, master, all calipers, everywhere. Even though I could not hear any leak in the Motive bottle, lines, and adapter cap, I decided my Unsolved Mystery might be the new Motive. Called all my neighborhood Euro car cronies to see if they were home for a quick couple minutes. Went to Norm's place and hooked it up to his modern BMW 8 series. 10 psi in and watched the needle slowly go down. Mystery solved. Thanks for everyone's help. A new Motive will arrive in a week from their customer service dept. Hopefully that one is not defective. |
914xr75 Need help--Brake pedal goes all the way to floor after several new parts replaced Jun 4 2025, 08:56 PM
Artfrombama Are you bleeding from the TOP of the calipers? Jun 4 2025, 09:06 PM
porschetub
I posted a few weeks ago about leaking reservoir ... Jun 4 2025, 10:00 PM
infraredcalvin Fluid is going somewhere, did you plug the overflo... Jun 4 2025, 10:02 PM
rjames Where did you find a 17 mm ATE MC?! Good find... Jun 4 2025, 10:56 PM
76-914
Where did you find a 17 mm ATE MC?! Good find... Jun 5 2025, 04:03 PM
914xr75 rjames--long tube method is brilliant! Pelican... Jun 5 2025, 06:42 AM
davep Your profile does not list a 914, so that does not... Jun 5 2025, 07:11 AM
fiacra
Your profile does not list a 914, so that does no... Jun 5 2025, 01:36 PM
PanelBilly Did you plug the air vent on the top of the reserv... Jun 5 2025, 05:39 PM
914xr75 Tonight's update. Pulled the tank again to loo... Jun 5 2025, 09:58 PM
fiacra
Tonight's update. Pulled the tank again to lo... Jun 6 2025, 09:00 AM
emerygt350 How did you bleed the mc? If that's not done ... Jun 6 2025, 04:20 AM
davep The reservoir cap or the reservoir itself has to h... Jun 6 2025, 08:03 AM
914sgofast2 Was the 17mm master cylinder NOS or a recently man... Jun 6 2025, 08:34 AM
fiacra
Update------defective brand new Motive Power Blee... Jun 6 2025, 10:59 AM
914rrr I'll likely not have a pedal pusher assistant,... Oct 15 2026, 08:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th October 2026 - 04:26 AM |
