| RKramden |
Jun 7 2025, 06:59 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
Does anyone have any experience with the roll pin installation with the Renigade Hybrid axle kit? I have new roll pins from Pelican and they just don’t want to go into the stub axle or spacer as easy as on Ian Karr’s video. I could put it in a press, but that won’t work with the trans axle. I could try to press them on with the 6 bolts through the spacer, but I’m not sure if there is enough torque before they’ll strip. Any ideas would be appreciated before I screw something up….thanks blob:null/59e017c3-9e8c-41d4-8946-5651ae8e75d2/“
| wndsrfr |
Jun 7 2025, 08:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Just did this with Renegade kit. I made sure of a good taper on the ends of the pin with the bench grinder and then pressed them in with large bench vise.
RKramden Roll pins for CV joints Jun 7 2025, 06:59 PM
wndsrfr duplicate edit. Jun 7 2025, 08:27 PM
bkrantz Maybe try freezing the pins (and warming the flang... Jun 7 2025, 08:17 PM
L-Jet914 Have you tried installing them with a roll pin pun... Jun 7 2025, 11:43 PM
rick 918-S
Does anyone have any experience with the roll pin... Jun 8 2025, 05:01 AM
stownsen914 Also curious what that part is. A spacer or adapte... Jun 8 2025, 06:50 AM
Montreal914 Ok, I haven't seen this one before. What is th... Jun 8 2025, 10:52 AM
RKramden Montreal914 is correct about the axle. I ordered ... Jun 8 2025, 11:26 AM
rick 918-S Never saw these. In my case I would still need one... Jun 8 2025, 11:59 AM
Chad911sc Had to exchange the roll pins on factory axles a f... Jun 8 2025, 09:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:06 PM |
