| RKramden |
Jun 7 2025, 06:59 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
Does anyone have any experience with the roll pin installation with the Renigade Hybrid axle kit? I have new roll pins from Pelican and they just don’t want to go into the stub axle or spacer as easy as on Ian Karr’s video. I could put it in a press, but that won’t work with the trans axle. I could try to press them on with the 6 bolts through the spacer, but I’m not sure if there is enough torque before they’ll strip. Any ideas would be appreciated before I screw something up….thanks blob:null/59e017c3-9e8c-41d4-8946-5651ae8e75d2/“
| rick 918-S |
Jun 8 2025, 05:01 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Does anyone have any experience with the roll pin installation with the Renigade Hybrid axle kit? I have new roll pins from Pelican and they just don’t want to go into the stub axle or spacer as easy as on Ian Karr’s video. I could put it in a press, but that won’t work with the trans axle. I could try to press them on with the 6 bolts through the spacer, but I’m not sure if there is enough torque before they’ll strip. Any ideas would be appreciated before I screw something up….thanks blob:null/59e017c3-9e8c-41d4-8946-5651ae8e75d2/“ ![]() Ok, I haven't seen this one before. What is that kit for? |
| stownsen914 |
Jun 8 2025, 06:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Also curious what that part is. A spacer or adapter?
A couple things I can thing of: Use a bench vise a press. Secure the part (like in a vise), hold the pin with a pair of pliers, and tap with hammer to get it started. Roll pins usually have one end with a little more of a taper. That's important since the diameter is larger than the hole. If there isn't enough taper, carefully give it one on a belt sander. Doesn't need much of a taper, just a tiny one. A grinder would be too aggressive. Needs to be smooth and even. |
RKramden Roll pins for CV joints Jun 7 2025, 06:59 PM
wndsrfr Just did this with Renegade kit. I made sure of a ... Jun 7 2025, 08:12 PM
wndsrfr duplicate edit. Jun 7 2025, 08:27 PM
bkrantz Maybe try freezing the pins (and warming the flang... Jun 7 2025, 08:17 PM
L-Jet914 Have you tried installing them with a roll pin pun... Jun 7 2025, 11:43 PM
Montreal914 Ok, I haven't seen this one before. What is th... Jun 8 2025, 10:52 AM
RKramden Montreal914 is correct about the axle. I ordered ... Jun 8 2025, 11:26 AM
rick 918-S Never saw these. In my case I would still need one... Jun 8 2025, 11:59 AM
Chad911sc Had to exchange the roll pins on factory axles a f... Jun 8 2025, 09:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:31 PM |
