> IDA3C Weber Troubleshooting
Cfletch
post May 31 2025, 09:24 PM
Hey there everyone, working on getting my 6 conversion going here and I was able to hook up a temp fuel system in place of my tank while I am waiting on a few parts. I wanted to get the car to idle with its new fuel pump (not yet regulated down to 3.5psi) rated at 5 PSI max. I wanted to get the carb bodies full of fuel and get some pressure into the system and as soon as the pump turned on with the ignition the carbs essentially started dumping fuel down my intakes. Almost as if there was an internal leak causing fuel to just enter their respective cylinders. I'm new to down draft webers so this confuses me. I popped the top off of one of the carbs and noticed the fuel level was extremely low in the bowls so it was not like the needle and seat were stuck or a float was stuck causing it to overfill. Kind of stumped here as these carbs are rebuilt. Really any suggestions are good here. the float level was set, the needle and seats are good and not sticking at all.
I read somewhere but not in much detail that the bowls are vented? I have these little plunger-esq things in each vent tube that I have not yet pulled out. Would that be the source of my problem? If the bowls couldn't vent its just pressurizing the changes and causing the fuel to just leak down into the engine?
Graydingo
post Jun 7 2025, 07:44 AM
He "deadend" it so he could check PSI. I think that was temporary.
OP needs the PMO pressure regulator. Many out there. Can get it with AN or hose barb.
It's really a bypass.
So FP--------> Fuel Filter --------> PMO regulator set to 3.5 PSI ---------> dual outlets to small inline filters ------_> each carb.
PMO regulator ------> return line.
Optional: Carb crossover line to equalize fp. (I don't run one but I've heard it can be helpful for overall performance.
Cfletch
post Jun 8 2025, 11:37 AM
QUOTE(Graydingo @ Jun 7 2025, 06:44 AM) *
Right, did that to check ma PSI if valves were shut, wanted to check and see how strong the pump would be. Anyway, yes today I plan to do: FP---Filter--regulator-- stock 6 hard line--- carbs. Im not doing a return line back to tank, blocked that off at the tank with a hose bolt combo.
I am using the return line as my feed because the return line diameter matches everything else and didn't want to mess around with going up and down sizes. I have a regulator mounted kind of near where the stock 914 4 fuel pump was, and then its going up through the metal to the stock 6 hard line which does the branch to both carbs. Because of that, no PMO regulator.
Cfletch   IDA3C Weber Troubleshooting   May 31 2025, 09:24 PM
brant   You should check and reset your float levels Mos...   Jun 1 2025, 06:14 AM
mate914   carb float needle not setting, Get extra because n...   Jun 1 2025, 06:58 AM
930cabman   Hey there everyone, working on getting my 6 conve...   Jun 1 2025, 07:36 AM
porschetub   Hey there everyone, working on getting my 6 conv...   Jun 1 2025, 02:28 PM
Graydingo   My vote would be stuck or faulty float needle. I n...   Jun 1 2025, 08:16 AM
Cfletch   What would be an official test on the needle/seat?...   Jun 1 2025, 10:48 AM
Graydingo   How are you verifying the bowl fullness? What do...   Jun 1 2025, 12:32 PM
flyer86d   I haven’t looked at mine but if your float needl...   Jun 1 2025, 12:33 PM
930cabman   Pierce has a float gauge kit if you need one. Easy...   Jun 1 2025, 12:50 PM
brant   I run 4 psi on the race car But bumpy and hard vi...   Jun 1 2025, 03:15 PM
Cfletch   Ok team here is an end of day update. My vents we...   Jun 1 2025, 05:25 PM
Graydingo   Sounds like you are making progress. Popping out...   Jun 1 2025, 06:38 PM
Cfletch   Sounds like you are making progress. Popping ou...   Jun 1 2025, 06:51 PM
930cabman   Are your float levels correctly set per gauge? per...   Jun 2 2025, 05:39 PM
Cfletch   I have on order a float level vial as well as the ...   Jun 2 2025, 08:38 PM
930cabman   I have on order a float level vial as well as the...   Jun 3 2025, 04:56 AM
Cfletch   A quick update with no real actual update on the c...   Jun 5 2025, 11:38 PM
930cabman   A quick update with no real actual update on the ...   Jun 6 2025, 04:55 AM
sixnotfour   In General everything about those carbs is not cor...   Jun 6 2025, 06:53 AM
Cfletch   In General everything about those carbs is not co...   Jun 6 2025, 10:37 AM
930cabman   In General everything about those carbs is not c...   Jun 6 2025, 12:37 PM
Cfletch   [quote name='Cfletch' post='3209150' date='Jun 6 ...   Jun 6 2025, 01:05 PM
porschetub   [quote name='Cfletch' post='3209150' date='Jun 6...   Jun 6 2025, 08:57 PM
porschetub   [quote name='Cfletch' post='3209150' date='Jun 6...   Jun 6 2025, 08:58 PM
sixnotfour   I apoligize wrong Weber carb problem post..   Jun 6 2025, 04:58 PM
brant   Are 135 mains the norm for a 2.7? I don’t have ...   Jun 6 2025, 05:02 PM
Cfletch   Are 135 mains the norm for a 2.7? I don’t have...   Jun 6 2025, 06:27 PM
sixnotfour   :beer1:   Jun 6 2025, 07:21 PM
Cfletch   :beer1: Looks like I'm right on the money t...   Jun 6 2025, 07:32 PM
Graydingo   He "deadend" it so he could check PSI. I...   Jun 7 2025, 07:44 AM
Cfletch   He "deadend" it so he could check PSI. ...   Jun 8 2025, 11:37 AM
930cabman   I am running FP ---- FF ------- PR-------GA ------...   Jun 7 2025, 04:27 PM
Cfletch   Hey friends, bit of an update for you all: I...   Jun 22 2025, 08:20 PM
930cabman   sounds like a victory, or getting close to it. The...   Jun 23 2025, 04:58 AM
gereed75   The airflow at idle is very dependent on idle spee...   Jun 23 2025, 05:20 AM
930cabman   I generally get about 4 - 5 on my snail when adjus...   Jun 23 2025, 09:01 AM
Cfletch   My goal today was to do the tach stuff so I could ...   Jun 23 2025, 06:29 PM
930cabman   My goal today was to do the tach stuff so I could...   Jun 24 2025, 04:45 AM
Cfletch   Kind of going back to this now that my suspensions...   Aug 5 2025, 10:06 PM
mb911   Does it smoke a lot? Wires in incorrect location? ...   Aug 6 2025, 04:32 AM
Cfletch   It definitely smells rich and is smoking a decent ...   Aug 6 2025, 01:56 PM
mb911   It definitely smells rich and is smoking a decent...   Aug 6 2025, 02:58 PM
- Lo-Fi Version Time is now: 8th August 2025 - 09:43 AM
