| GeorgeKopf |
May 26 2025, 04:25 PM
Member ![]() ![]() Group: Members Posts: 263 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
I'm wring my 1973 wiring harness and have a bunch of things installed which seem to be working correctly (i.e. headlights (high & low beam), headlight motors, turn signals, running lights, tail lights)
But (IMG:style_emoticons/default/bootyshake.gif) the turn signal indicators are always on! I've traced the flow of current from the fuse panel (red with white stripe) to the hazard switch, from there (red) to the relay and from there to the turn signal indicators (blue with white stripe). 47 is the relay 31 is the hazard switch 22 is the turn signal lights 26 is the steering column switch ![]() I have two relays and both seem to work fine. When I pull out the hazard switch the indicators and lights all blink. When I set the turn signal that side blinks. I have two hazard switches and both behave the same way. As soon as I connect the red and red/white wires the turn signal indicators come on. With the knob pushed in, I have continuity between the red/white (power in) and the red (power out to the relay). With the knob pulled out, I have continuity between the black/red (power in) and the red (power out to the relay). (IMG:style_emoticons/default/confused24.gif) More information: I have cleaned all grounding studs. I disassembled one of the relays and cleaned it. If I disconnect all of the wires from the hazard switch except for the red/white and the red, the signal indicators come on and stay on. Doesn't this mean that my relay is bad? It should be getting power so that it can feed the turn signal indicators when the turn signals are set. It seems that the relay is allowing the input power to the blue/white wires when it shouldn't. If so, is there a good way to test or repair them? Thanks in advance for any advice. George |
| GeorgeKopf |
May 29 2025, 07:47 AM
| Spoke |
May 29 2025, 08:24 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Yes. I show how to make the mod on my website if you want to do the mod yourself. |
| GeorgeKopf |
May 29 2025, 09:52 AM
Yes. I show how to make the mod on my website if you want to do the mod yourself. First of all, you are the man! Thank you for being so generous with your time and expertise. Second, I'll buy one of your LED relays. Would you prefer that I do it through your website? Thanks. George |
| Spoke |
May 29 2025, 08:00 PM
Yes. I show how to make the mod on my website if you want to do the mod yourself. First of all, you are the man! Thank you for being so generous with your time and expertise. Second, I'll buy one of your LED relays. Would you prefer that I do it through your website? Thanks. George Yes. The website is the easiest way. |
| GeorgeKopf |
Jun 8 2025, 07:37 PM
GeorgeKopf Turn signal indicator lights come on with key May 26 2025, 04:25 PM
904svo jUST A wag check that the brown wire is connect to... May 26 2025, 05:21 PM
Superhawk996 Simplified wiring diagram from Spoke
Take note... May 27 2025, 05:26 AM
Superhawk996
If I disconnect all of the wires from the hazard... May 27 2025, 05:29 AM
rfinegan ON or blinking?
My problems have allows been a bad... May 27 2025, 05:51 AM
Superhawk996
See diode in the flasher circuit.
There is... May 27 2025, 06:00 AM
rfinegan My bad, not a diode but replacement did fix my lig... May 27 2025, 08:55 AM
GeorgeKopf @Superhawk996
Thanks for the simplified diagram. ... May 27 2025, 07:11 PM
Superhawk996 If you’ve already tried 2 flasher relays, and it... May 27 2025, 10:33 PM
I was thinking how I might bench t... May 28 2025, 08:46 AM
Superhawk996
Do you know which connector on the unit represen... May 28 2025, 09:34 AM
Spoke
But :bootyshake: the turn signal indicators are a... May 28 2025, 09:17 AM
GeorgeKopf @Spoke
If I remove the flasher relay, the indica... May 28 2025, 09:40 AM
Spoke
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 28 2025, 02:43 PM
rfinegan I did use a LED ready hazard flasher, so when I up... May 28 2025, 11:32 AM
GeorgeKopf @rfinegan
This is very good information. I... May 28 2025, 11:51 AM
GeorgeKopf @Spoke You said:
"An easy workaround which... May 28 2025, 07:15 PM
Superhawk996
Between 49 and C:......resistance is 850 ohms...... May 29 2025, 02:42 AM
Spoke
My flasher relay is only labeled:
....49
49a....... May 29 2025, 07:30 AM
GeorgeKopf Before I start a new thread .....
<edit> I... May 31 2025, 04:34 PM
GeorgeKopf @Spokes
<edit> I just found the answer on... May 31 2025, 07:09 PM
Spoke
@Spokes
<edit> I just found the answer o... May 31 2025, 09:05 PM
BillC
[quote name='GeorgeKopf' post='3208274' date='May... Jun 2 2025, 07:09 PM
Superhawk996 :trophy:
Good job doing the basic troubleshootin... Jun 9 2025, 07:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th July 2026 - 12:57 AM |
