| barefoot |
Jun 8 2025, 06:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,484 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
For several years after After I but it all back together the car's been running fine, had to clean one carb once and that worked fine. Now it's getting worse won't idle, it just dies after I let off the throttle. Runs strong at higher loads but very poor at idle & low load. I've cleaned the carbs enough that think I could do it blindfolded. I know the points dwell is OK and I haven't touched the advance. Using a heat gun i can measure header pipe temps just before muffler and one cylinder on each bank is way lower temperature than it's neighbor after holding the rpm's just above idle speed.
Think I'll pull the carbs off and do a compression check just to rule out one thing. Can't even do a synchronize without a smooth idle. Is there someone in our group who is Dell 40 expert so i can send carbs off to ??? I've prided myself as a competent mechanic but this has got me on the edge. Not having fun anymore (IMG:style_emoticons/default/headbang.gif) Barefoot |
| rhodyguy |
Jun 9 2025, 06:53 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are the plugs wet? Have you checked plug wires for common resistance?
barefoot Dellorto blues Jun 8 2025, 06:39 PM
Osnabruck914 I run Dells on my 2.0L. Are you sure the O-rings ... Jun 8 2025, 08:04 PM
fixer34 Not familiar with carbs on a -4, but something doe... Jun 8 2025, 08:34 PM
infraredcalvin
Not familiar with carbs on a -4, but something do... Jun 9 2025, 09:09 PM
cgnj @Barefoot I am a Dellorto fanboy. Here are my que... Jun 8 2025, 11:45 PM
barefoot
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 9 2025, 04:55 AM
cgnj @Barefoot I will PM my contact info to you and so... Jun 9 2025, 10:50 AM
Osnabruck914 Another common culprit could be air leakage where ... Jun 9 2025, 12:46 PM
porschetub
Another common culprit could be air leakage where... Jun 10 2025, 11:07 PM
Literati914 I know a lot of guys would be against this.. but I... Jun 9 2025, 12:49 PM
Osnabruck914
I know a lot of guys would be against this.. but ... Jun 9 2025, 03:25 PM
cgnj @litertia914 Empi D 36,40,45. There were some revi... Jun 9 2025, 08:36 PM
L-Jet914
For several years after After I but it all back t... Jun 9 2025, 08:48 PM
barefoot Update:
tried driving it just down the street and... Jun 10 2025, 06:49 AM
Superhawk996 Apparently I’ve got an edit / operator error pro... Jun 10 2025, 03:29 PM
Superhawk996 Oops - duplicate :( Jun 10 2025, 03:33 PM
Superhawk996 FWIW - I’ve had issues in the past that requires... Jun 10 2025, 03:32 PM
dr914@autoatlanta.com the most competent mechanic in the world cannot de... Jun 11 2025, 03:16 PM
Osnabruck914 [quote name='dr914@autoatlanta.com' date=... Jun 12 2025, 10:27 AM
porschetub
[quote name='dr914@autoatlanta.com' date=... Jun 13 2025, 01:23 PM
anderssj :agree:
I’ve been running Dell’s (2xDRLA-40)... Jun 12 2025, 02:54 PM
cgnj @Osnabruck914 [b]@[url=http://www.914world.com/b... Jun 12 2025, 07:22 PM
nditiz1 This is the first time I think I have ever heard s... Jun 12 2025, 10:05 PM
930cabman my $5. says it's a clogged idle jet, one ... Jun 13 2025, 10:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 12:15 AM |
