| robkammer |
Jun 6 2025, 05:21 AM
Robbo ![]() ![]() Group: Members Posts: 270 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
All: The intermittent fuel pump issue still lingers on our BB. Can anyone tell me where the wire (or wires) that feed pins 12 and 14 on the 14 pin connector are routed from the battery? It's obvious that it goes into, and returns from the hole in the firewall. But does it go all the way to the dash, or just under the passenger seat?
And the color, is it red/white or red/yellow? This seems to be the cause of the problem. And check out my OBD 914 version below. Only way I could figure how to determine what was failing. Rob |
| Superhawk996 |
Jun 10 2025, 11:19 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
(IMG:style_emoticons/default/smilie_pokal.gif) keep using that meter.
Verify it after ignition switch swap again to make sure it isn’t bad wiring and excess voltage drop in the wire. |
robkammer D Jet issues continue Jun 6 2025, 05:21 AM
JeffBowlsby https://bowlsby.net/914/WiringHarnesses/doc...4_MA... Jun 6 2025, 08:04 AM
robkammer Thanks Jeff: I have those prints I believe, but yo... Jun 6 2025, 12:52 PM
Superhawk996 Rob
Everything you need is right here
It’s ... Jun 6 2025, 01:46 PM
robkammer Thanks for the print. I thought I had it solved as... Jun 8 2025, 08:17 AM
JamesM
Thanks for the print. I thought I had it solved a... Jun 8 2025, 12:32 PM
didenpx Can you describe the dropout to the fuel pump plea... Jun 8 2025, 08:42 AM
robkammer Thanks James, great drawings. I'll be back at ... Jun 9 2025, 04:24 AM
robkammer Here's the latest: Ran the tests again yesterd... Jun 10 2025, 03:47 AM
robkammer All: The switch is in, and all seems good. Tested ... Jun 10 2025, 03:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 10:18 PM |
