> Too much taper too soon on fuel line? 73 2.0 with FI
s13u74cr4
post Jun 11 2025, 07:40 PM
Since discovering my supply and return lines from the SS lines PO did are reversed been working to correct that. Now have all, correct I think, routing. But, since putting gas back in, she will not start. There is a little fuel going into the new fuel filter. Maybe that is correct but I get no indication she is even attempting to start. I hear some bubbling in the tank, that is it. What I did do is add a SS taper from Tangerine. You can sort of see it on the left there under the heat duct. Now I am wondering if where I put it, with maybe 8-10” of the smaller line into the filter is causing the problem? Causing too little fuel to flow?
Superhawk996
post Jun 12 2025, 07:56 AM
Make sure you’re plumbed properly at the 3 port pump
S = fuel inlet
D = fuel outlet (pressure)
R = excess fuel return internal to pump / air bleed to prime the pump internally (very little if any flow at this port)
Make sure your pump is connected with proper polarity and not running in reverse
- Lo-Fi Version Time is now: 19th August 2025 - 10:14 PM
