> Oil recommendation, Replace Brad Penn
oakdalecurtis
post Jun 12 2025, 10:52 AM
Oakdalecurtis
76 2.0, 130,000 miles. I used to run Brad Penn 30 with high ZDDP, a very “ sticky” oil. It stopped the little bit of smoking from the exhaust. (probably worn rings). The newer oil is called Penn oil, and I don’t think it’s the same as the original Brad Penn formulation. Now the engine is smoking a little again. Can anyone recommend a replacement/equivalent oil to my old stickyBrad Penn oil?
914werke
post Jun 12 2025, 11:18 AM
Actually the old Brad Penn (green oil) was rebadged A DECADE ago as PENN GRADE 1, Same formulation. Other than your car smoking ...again, after 10 years Id say it seems to have held up pretty well?
oakdalecurtis   Oil recommendation   Jun 12 2025, 10:52 AM
914werke   Actually the old Brad Penn (green oil) was rebadge...   Jun 12 2025, 11:18 AM
yeahmag   I can't recommend an oil to help your car stop...   Jun 12 2025, 11:35 AM
Front yard mechanic   I found if you remove you rear view mirrors it doe...   Jun 12 2025, 11:44 AM
oakdalecurtis   I found if you remove you rear view mirrors it do...   Jun 13 2025, 04:27 AM
oakdalecurtis   I’m thinking if trying Amsoiil zrod oil. I live ...   Jun 13 2025, 12:52 PM
emerygt350   You could try some of those magic sauces at the fl...   Jun 12 2025, 01:06 PM
Geezer914   I use Driven 15w/50w oil. You said your seeing sm...   Jun 12 2025, 02:45 PM
mb911   Amsoil z rod is now my go to   Jun 12 2025, 03:14 PM
Artfrombama   Castrol 20W50 was the recommended air cooled oil f...   Jun 13 2025, 01:41 PM
930cabman   Castrol 20W50 was the recommended air cooled oil ...   Jun 13 2025, 05:10 PM
Literati914   What's the important properties beside Zinc, t...   Jun 13 2025, 04:11 PM
Superhawk996   What's the important properties beside Zinc, ...   Jun 14 2025, 10:23 AM
GregAmy   Oil is a religion Amen, brother.   Jun 16 2025, 06:34 AM
Artfrombama   What's the important properties beside Zinc, ...   Jun 14 2025, 10:46 AM
bkrantz   In olden times, people used crazy stuff like this.   Jun 13 2025, 07:23 PM
930cabman   In olden times, people used crazy stuff like this...   Jun 14 2025, 10:15 AM
ClayPerrine   In olden times, people used crazy stuff like this...   Jun 16 2025, 06:13 AM
Geezer914   Driven oil is recommended by Jake Raby. He helped...   Jun 14 2025, 05:48 PM
carr914   In olden times, people used crazy stuff like this...   Jun 15 2025, 05:33 AM
mlindner   I've used Pen Grade 1 20w50 for the last five ...   Jun 16 2025, 07:41 AM
- Lo-Fi Version Time is now: 13th August 2025 - 07:13 PM
