oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,367 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
76 2.0, 130,000 miles. I used to run Brad Penn 30 with high ZDDP, a very “ sticky” oil. It stopped the little bit of smoking from the exhaust. (probably worn rings). The newer oil is called Penn oil, and I don’t think it’s the same as the original Brad Penn formulation. Now the engine is smoking a little again. Can anyone recommend a replacement/equivalent oil to my old stickyBrad Penn oil?
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
I found if you remove you rear view mirrors it doesn’t smoke at all
Lo-Fi Version | Time is now: 16th June 2025 - 12:50 AM |
