> Oil recommendation, Replace Brad Penn
oakdalecurtis
post Jun 12 2025, 10:52 AM
Oakdalecurtis
76 2.0, 130,000 miles. I used to run Brad Penn 30 with high ZDDP, a very “ sticky” oil. It stopped the little bit of smoking from the exhaust. (probably worn rings). The newer oil is called Penn oil, and I don’t think it’s the same as the original Brad Penn formulation. Now the engine is smoking a little again. Can anyone recommend a replacement/equivalent oil to my old stickyBrad Penn oil?
Artfrombama
post Jun 13 2025, 01:41 PM
Castrol 20W50 was the recommended air cooled oil for eons, I use the Brad Penn 20W50 synthetic blend
I remember asking an old VW mechanic years ago for a recommended brand; "Any clean oil is better than dirty oil".
930cabman
post Jun 13 2025, 05:10 PM
QUOTE(Artfrombama @ Jun 13 2025, 01:41 PM) *
(IMG:style_emoticons/default/agree.gif) been using Castrol 20 50 for decades, never had a failure attributed to an oil issue
oakdalecurtis   Oil recommendation   Jun 12 2025, 10:52 AM
914werke   Actually the old Brad Penn (green oil) was rebadge...   Jun 12 2025, 11:18 AM
yeahmag   I can't recommend an oil to help your car stop...   Jun 12 2025, 11:35 AM
Front yard mechanic   I found if you remove you rear view mirrors it doe...   Jun 12 2025, 11:44 AM
oakdalecurtis   I found if you remove you rear view mirrors it do...   Jun 13 2025, 04:27 AM
oakdalecurtis   I’m thinking if trying Amsoiil zrod oil. I live ...   Jun 13 2025, 12:52 PM
emerygt350   You could try some of those magic sauces at the fl...   Jun 12 2025, 01:06 PM
Geezer914   I use Driven 15w/50w oil. You said your seeing sm...   Jun 12 2025, 02:45 PM
mb911   Amsoil z rod is now my go to   Jun 12 2025, 03:14 PM
Artfrombama   Castrol 20W50 was the recommended air cooled oil f...   Jun 13 2025, 01:41 PM
930cabman   Castrol 20W50 was the recommended air cooled oil ...   Jun 13 2025, 05:10 PM
Literati914   What's the important properties beside Zinc, t...   Jun 13 2025, 04:11 PM
Superhawk996   What's the important properties beside Zinc, ...   Jun 14 2025, 10:23 AM
Artfrombama   What's the important properties beside Zinc, ...   Jun 14 2025, 10:46 AM
bkrantz   In olden times, people used crazy stuff like this.   Jun 13 2025, 07:23 PM
930cabman   In olden times, people used crazy stuff like this...   Jun 14 2025, 10:15 AM
Geezer914   Driven oil is recommended by Jake Raby. He helped...   Jun 14 2025, 05:48 PM
carr914   In olden times, people used crazy stuff like this...   Jun 15 2025, 05:33 AM
- Lo-Fi Version Time is now: 16th June 2025 - 12:50 AM
