oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,377 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
76 2.0, 130,000 miles. I used to run Brad Penn 30 with high ZDDP, a very “ sticky” oil. It stopped the little bit of smoking from the exhaust. (probably worn rings). The newer oil is called Penn oil, and I don’t think it’s the same as the original Brad Penn formulation. Now the engine is smoking a little again. Can anyone recommend a replacement/equivalent oil to my old stickyBrad Penn oil?
Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,066 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
What's the important properties beside Zinc, that make you guys so dedicated to one brand or another?
I see some awfully cheap oils with significant zinc numbers. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,274 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Lo-Fi Version | Time is now: 13th August 2025 - 07:16 PM |
