> Help with 6 heat exchanger mounting brackets
sixaddict
post Jun 14 2025, 09:10 AM
So finalizing engine details and need a little help with mounting brackets.
This picture shows mounting bracket in place.
The bracket on this side is MIA…maybe
Next is outboard…
Attached ImageAttached Image
Could some post what I should be seeing if correct. Zoom in on last pic and you can see outboard bracket. Trying to also determine where that attaches.
Thanks…..
fixer34
post Jun 14 2025, 01:33 PM
Yes, I believe the tab on the one side is to clamp the cables in place, not mount to the case.
On a different note, I see you installed turbo valve covers on the exhausts. If you ever plan to check/adjust the valves with the engine in the car (and bolted up) you need to mill/shave some of the fins around a couple bolts. Otherwise they won't clear the trailing arm frame mounts. There are a couple threads about it.
Ask me how I know..
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: porschetub
- Lo-Fi Version Time is now: 15th June 2025 - 10:20 PM
