sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 951 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
So finalizing engine details and need a little help with mounting brackets.
This picture shows mounting bracket in place. ![]() The bracket on this side is MIA…maybe ![]() Next is outboard… ![]() ![]() Could some post what I should be seeing if correct. Zoom in on last pic and you can see outboard bracket. Trying to also determine where that attaches. Thanks….. |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,286 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Yes, I believe the tab on the one side is to clamp the cables in place, not mount to the case.
On a different note, I see you installed turbo valve covers on the exhausts. If you ever plan to check/adjust the valves with the engine in the car (and bolted up) you need to mill/shave some of the fins around a couple bolts. Otherwise they won't clear the trailing arm frame mounts. There are a couple threads about it. Ask me how I know.. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,853 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Yes, I believe the tab on the one side is to clamp the cables in place, not mount to the case. On a different note, I see you installed turbo valve covers on the exhausts. If you ever plan to check/adjust the valves with the engine in the car (and bolted up) you need to mill/shave some of the fins around a couple bolts. Otherwise they won't clear the trailing arm frame mounts. There are a couple threads about it. Ask me how I know.. (IMG:style_emoticons/default/agree.gif) why would want to solid mount to the HX on to the case ? but why it perfectly lines up on that case stub has got me baffled ??? . Pretty sure OP knows about the lower rocker covers ,cheers. |
porschetub |
[quote name='porschetub' date='Jun 15 2025, 03:57 PM' post='3210274']
[quote name='fixer34' post='3210221' date='Jun 15 2025, 07:33 AM'] Yes, I believe the tab on the one side is to clamp the cables in place, not mount to the case. On a different note, I see you installed turbo valve covers on the exhausts. If you ever plan to check/adjust the valves with the engine in the car (and bolted up) you need to mill/shave some of the fins around a couple bolts. Otherwise they won't clear the trailing arm frame mounts. There are a couple threads about it. Ask me how I know.. [/quote] (IMG:style_emoticons/default/agree.gif) why would want to solid mount to the HX on to the case ? but why it perfectly lines up on that case stub has got me baffled ??? . Pretty sure OP knows about the lower rocker covers ,cheers. Edit ,great pics supplied sixer ,confirms than bracket isn't there in that bunch of tressures you have ?? ,rest look like lower tin fitment ...think so as they are 6mm. Cheers. |
Lo-Fi Version | Time is now: 15th June 2025 - 10:28 PM |
